Tip & How-To about Plumbing
LEAKE FAUCET
TURN OF WATER
1 SMALL FLAT SCREW DRIVER POT PLASTIC CAP.
2 REMOVE PHILLIPS SCREW .
3 REMOVE NUT (CRESENT WRENCH)
4 PULL PIECES OUT IF HAS SCREW ON BOTTEM REMOVE SCREW TO TAKE OF SEAL.
Plumbing Logo
Search Fixya...
    • Test the dripping water with your hand to make sure that it is the hot water side that is leaking. Lay a rag over the sink drain to keep parts from falling down it. Locate the hot and cold shutoff valves under the sink and turn the knobs clockwise by hand until they close. If the knobs remain stiff, use a pair of pliers to gently turn them until the knob begins to move, then finish turning by hand.
    • 2
      Pry the decorative cap off the faucet top with a small thin, flat-head screwdriver. Remove the cap that has the "H" letter on it. Depending upon the handle screw configuration, use a flat-head or Phillips-head screwdriver to remove the handle screw. Gently pry up on the handle from all angles and pull it up and off the splines of the stem.
    • 3
      Use a crescent wrench to turn the hot water stem nut counterclockwise until it comes completely off the stem shaft. Wiggle the stem with your fingers and pull it out of the faucet. If the washer on the bottom of the stem is deformed, it indicates the source of the leak. However, remove the old seat from the faucet base with an Allen wrench or a seat removal tool.
    • 4
      Wipe out the inside of the seat housing with a rag. Replace the seat with the new one included in the repair package, using an Allen wrench or seat removal tool.
    • 5
      Place the new hot water stem shaft into the valve seat, and start the stem nut in by hand, turning it clockwise. Finish tightening the stem nut with the crescent wrench, but only to a moderate firmness -- do not over-tighten it. Place the handle back over the stem shaft and tap it down until it seats firmly. Replace the handle screw and tighten it with a screwdriver.
    • 6
      Turn the hot and cold water supply knobs counterclockwise until they are fully open. Turn the hot water faucet knob to the "On" position and check for leaks.
Jul 09, 2013 | Computers & Internet
Dripping bath faucet circa 1985. Can't ID model but appears to have 2 screws holding front of casting to main body for disassembly . Faceplate is square in shape and black in color HELP!
  • 1 Close the hot and cold water valves in the cabinet beneath the sink to shut the water supply off to the bath faucet.
  • 2 Remove the bath faucet's handle to access the valve cartridge. The faucet handle is removed by first detaching the handle's insert cap using the tip of a screwdriver or utility knife to expose the handle screw. Remove the handle screw with a Phillips screwdriver, then pull the handle off the valve cartridge stem.
  • 3 Loosen and remove the cartridge valve nut with an adjustable wrench. Some faucet models retain the valve cartridge with a snap ring and are removed with snap ring pliers.
  • 4 Pull the old valve cartridge out of the bath faucet base, using pliers.
  • 5 Insert the new replacement valve cartridge into the faucet housing and replace the nut or snap ring removed in Step 3, using an adjustable wrench or snap ring pliers.
  • 6 Reinstall the faucet's handle onto the valve cartridge post, then secure the handle's screw, using a screwdriver.
  • 7 Replace the insert cap into the handle to cover the handle's screw hole.
  • 8 Turn on the hot and cold water valves beneath the sink to restore the water supply.
  • Jun 15, 2011 | Kohler Plumbing
    HOW DO I INSTALL A SEAL KIT
    A metal ball controls the temperature and flow of water from the spout in the vast majority of Delta single-lever faucets. That ball rests on three rubber seals, each seal suspending the ball with a single spring. Over time, wear on the seals, the springs and even the ball itself typically results in leaks. Thankfully, repairing the faucet is relatively simple, and Delta even makes repair kits with the replacement parts needed for each model.
    Turn off the valve that controls the main water supply. The valve is located next to the water meter, inside or outside the house, and must be twisted in a clockwise direction.
    Remove the plastic cap from the center of the faucet's handle by prying the cap free with the blade of a dull knife or a flat-head screwdriver, then remove the screw in the center of the faucet handle with a Phillips-head screwdriver. Pull the handle off the faucet assembly to remove it
  • Remove the single bonnet nut that surrounds the faucet valve with an adjustable wrench. Grip the bonnet nut at the base, which is ribbed to give the wrench a surface to grasp, and turn in a counterclockwise direction to remove it.
  • Remove the circular, white plastic cam that surrounds the top of the faucet, pulling it off and revealing a rubber seal, which you also remove. Next, pull the metal ball out of the faucet assembly and pry out the ball's supporting rubber seals and their springs with a screwdriver (the springs slide onto the bottom of each seal, so they will come out along with the seals).
  • Slide one replacement spring onto each of the three replacement seals that come with the Delta repair kit for your faucet model, then insert each seal into the assembly. Insert the replacement ball from the repair kit, then cap it by putting the replacement rubber seal over the ball, followed by the plastic cam
  • Place the bonnet nut over the faucet valve, then tighten the nut with an adjustable wrench. Position the handle onto the end of the faucet, then insert a screw into the center of the handle, tighten it with a Phillips-head screwdriver and, finally, press the decorative plastic cap over the screw.
  • Turn on the valve that controls the main water supply by twisting the valve in a counterclockwise direction to complete the repair
  • Jan 28, 2011 | Delta & Single Handle Shower Faucet
    Leaking Kitchen Tap
    I am assuming that your kitchen tap is leaking through the spout
    if it is single lever you will need to remove the crown and spout by removing a small erasure size cap on the housing right under the spout or up near the back of the ever then use a hex wrench to remove the set screw( plug the drain holes do it does not go down the drain)
    turn the water off (hot and cold ) under the sink
    remove the set screw and lift off the lever
    at his point you can take an adjustible wrench(channel lock and tighten the big ring nut that holds the cartridge in place
    temorairly put the handle back on and put the handle in the off position turn the water on under the sink and see if it stopped leaking
    if it still leaks you have to turn the water back off and remove the lock nut then the cartridge and go to big box store with old cartridge and name of mfg and get a new one and install
    If you have seperate hot and cold valves on top of sink deermne which is leaking by turning one off with oher on undr the sink
    once you have determined which it is (hot or cold)
    take a phillips head screw driver( remove plastic clear cap on top of faucet handle with sharp crewdriver of knife blade) and remove the screw holdin the handle on to the stem(turn counter clock wise
    be sure to turn water of under snk on both faucet risers after removing acrylic handle you then take an adjustible wrench and remove the crown nut turn counter clockwise until it comes off over stem
    remove stem( looks like size of a pretzel about six inches long with washers on side and one on end
    take the stem to local hardware(ace) or big box store and go to lumbing section ask clerk to inspect and recommend replacement washers or replacement stem (if needed)
    go back reinstall and tighten crown nut snug( open (turn counter clockwise) tem valve before you snug it down with crown nut
    install acrykic or chrome handle with brass phillips screw then ut cap on and turn on water and check for leaks
    good luck
    Dec 30, 2008 | Home
    88 Honda Accord left front turn signal assembly
    *The Turn signal on the Side of the car next to the headlight*
    1. Open the retractable headlights.
    2. Remove the plastic shroud around the headlight: two screws in front and one on each side.
    3. Look to the outside of the headlight and you will see a single screw in a small plastic cover on the front inside edge of the signal light assembly. The headlight prevents you from getting at the screw straight-on. I broke it loose with an offset phillips screwdriver, and then backed it out with a regular phillips.
    4. Remove the plastic cover, and you will see two screws. Remove them.
    5. Now you can pull the turn signal assembly forward and out.
    6. To remove the bulb holders from the assembly, twist counterclockwise and pull out.
    7. Pull straight outward to remove the bulbs. To assemble, follow the steps in reverse. Note that there are two plastic rods on the back end of the turn signal assembly that you will insert into two holes in the channel of the fender
    *The turn signal in the bumper*
    1. You will need a phillips head And Flat head screw driver, right below the turn signal there is a panel that you can pop out, (or its allready gone, Looks like a Fog light can go in there.)
    2. once u find that, (Pretty easy to find) Look directly up in there., there is styrofoam up there and u will also notice a little hole,
    3. Stick the Phillips head screw driver in that hole and turn it counter clockwize, The screw will not fall out,
    4.once it feels like the screw is loose put the flat head in between the turn signal lense and bumper, the side where you unscrewed it and SLOWLY pry it out,
    4. once out, just twist the plug and replace light bulb
    to replace just reverse instructions
    Jun 29, 2008 | 1988 Honda Accord 4 Door
    406 people viewed this tip
    Top Plumbing Experts
    Paul Carew
    Tom Chichester
    Are you a Plumbing Expert? Answer questions, earn points and help others
