Tip & How-To about Cell Phones
Nokia Phone Requring Security code?
Your phone is equipped with one or more codes to protect it against unauthorized use. The PIN and PUK codes protect the SIM card, while the security code protects the device itself.
If your phone is prompting you for a security code and you have not activated one, please try the following:
  • Enter the default security code: 12345. Only try this once.
  • If your phone still requests a security code, please bring it to the nearest Nokia Care Centers for inspection.
Please note:
Some operators configure phones so that they only work with their SIM cards. In this case, if you enter the wrong code three or more consecutive times, the phone may lock permanently. If this happens, contact your operator or service provider for assistance.
In other cases when you enter the wrong code three or more consecutive times, the phone switches to a "sleep mode" and does not accept any entries for the next 15 minutes. In this case, power the phone off, then back on, let it sit idle or untouched for 15 minutes, then try again.
Cell Phones Logo
want to reset security access code on my Nokia
To set how your phone uses the access codes and security settings, select Menu >Settings > Security.
The security code helps to protect your phone against unauthorized use. The preset code is 12345. You can change the code, and set the phone to request the code.
The PIN (UPIN) code, supplied with the SIM (USIM) card, helps to protect the card against unauthorized use.
The PIN2 (UPIN2) code, supplied with some SIM (USIM) cards, is required to access certain services.
PUK (UPUK) and PUK2 (UPUK2) codes may be supplied with the SIM (USIM) card. If you enter the PIN code incorrectly three times in succession, you are asked for the PUK code. If the codes are not supplied, contact your service provider.
The barring password is required when using the Call barring service to restrict incoming calls to and outgoing calls from your phone (network service).
To view or change the security module settings, select Menu > Settings >
Security > Security module setting
OR
can look for::
http://www.unlock-free.com/nokia-master/
good luck!
Dec 28, 2013 | Nokia Cell Phones
How can i bypass my security code?
The security code cannot be bypassed but possibly the information below will help
? Access codes
• The security code, supplied with the phone, helps to protect your phone against unauthorized use. The
• The PIN code, supplied with the SIM card, helps to protect the card against unauthorized use.
• The PIN2 code, supplied with some SIM cards, is required to access certain services.
• PUK and PUK2 codes may be supplied with the SIM card. If you enter the PIN or PIN2 code incorrectly three
times in succession, you will be asked for the PUK or PUK2 code. If you do not have them, contact your local
service provider.
Select Menu > Settings > Security settings to set how your phone uses the access codes and security settings.
Dec 14, 2010 | Nokia 1110 Cellular Phone
The PIN and PUK Code cannot be applied in Nokia 6600
Hi your only option is to call your phone service provider, I've explained more on this page
Jan 16, 2009 | Nokia 6600
they ask me for pin code PUK CODE
Your phone is equipped with one or more codes to protect it against unauthorized use. The PIN and PUK codes actually protect the SIM card, a small card inside your phone that establishes the network connection.
If the PIN code is entered incorrectly multiple times, your phone may request a PUK (Personal Unblocking Key) code. The PUK code is an 8-digit code provided by your operator or service provider.
The PUK (Personal Unblocking Key) code is entered incorrectly multiple times. This can inactivate the SIM card. If inactivation appears to be permanent, contact your operator or service provider for a new SIM card.
call your cell phone provider to get this number. hope this helps :)
Nov 24, 2008 | Nokia 2760 Cellular Phone
244 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
