Tip & How-To about Cell Phones
SIM card Rejected ? orvSIM Card unaccepted?
The SIM card is the small card inside your phone that establishes the network connection. In almost all cases, your operator or service provider is the best source of assistance with SIM card problems.
Your phone may display a SIM card error message if:
  • The SIM card is out of alignment. If the phone has recently been dropped, bumped, or opened, the SIM card may need adjusting. Follow the SIM card installation instructions in your user guide.
  • The PUK (Personal Unblocking Key) code is entered incorrectly multiple times. This can inactivate the SIM card. If inactivation appears to be permanent, contact your operator or service provider for a new SIM card.
  • You have recently changed service providers. In this case, either your SIM card or your phone may be configured for your previous operator and may require reconfiguring. Please contact your current operator or service provider for assistance.
If none of the situations above apply and you continue to receive this error message, your SIM card may be damaged. Please contact your operator or service provider to have the SIM card tested and/or replaced.
Cell Phones Logo
please do help me in this i want to recover my sim because its puk is blocked can u tell me any way how to rcover it?
Hi there, i suggest you please contact your service provider for the PUK CODE. PUK code is protect your sim card. For more details please read the below topic. Its much clear to you.
1. My phone is requesting a PIN/PIN2/PUK/PUK2 code.
Your phone is equipped with one or more codes to protect it against unauthorised use. The PIN and PUK codes actually protect the SIM card, a small card inside your phone that establishes the network connection.
In most cases, your operator or service provider is the best source of assistance with PIN and PUK codes.
  • The most common code is the PIN (Personal Identification Number) code, which you set yourself and can activate and inactivate by following the instructions in your user guide.
  • The PIN2 code is a PIN code which acts as a second layer of protection for certain features of your phone. It functions in the same way as the PIN code, and more information is available in your user guide.
  • If the PIN code is entered incorrectly multiple times, your phone may request a PUK (Personal Unblocking Key) code. The PUK code is an 8-digit code provided by your operator or service provider.
  • If the PIN2 code is entered incorrectly multiple times, your phone may request a PUK2 code.
Please contact your operator or service provider for assistance with your PIN and/or PUK codes. If you have already contacted your service provider and the code provided did not work, you will have to obtain a new SIM card from your operator or service provider.
^ Top
2. My phone is requesting a security code.
Your phone is equipped with one or more codes to protect it against unauthorised use. Please note that the security code, which protects the phone itself, differs from the PIN code, which protects the SIM card.
If your phone is prompting you for a security code and you have not activated one, please try the following:
  • Enter the default security code: 12345. Only try this once.
If your phone still requests a security code, please bring it to the nearest Nokia care point for inspection. You can find care point addresses from the drop-down menu at the bottom of Repair.
Please note:
  • Some operators configure phones so that they only work with their brands' SIM cards. In this case, if you enter the wrong code three or more consecutive times, the phone may lock permanently. If this happens, contact your operator or service provider for assistance.
  • In other cases when you enter the wrong code three or more consecutive times, the phone switches to a "sleep mode" and does not accept any entries for the next 15 minutes. In this case, power the phone off, then back on, let it sit idle or untouched for 15 minutes, then try again or bring it to a Nokia Care point.
^ Top
3. My phone displays "SIM card rejected" or "SIM card unaccepted".
The SIM (subscriber identity module) card is a small card inside your phone that establishes a network connection. The SIM card is provided by your operator or service provider. In most cases, they are the best source of assistance with SIM card problems. Your phone may display a SIM card error message if:
  • You have recently changed service providers. In this case, either your SIM card or your phone may be configured for your previous operator and may require reconfiguring. It may also be that your phone is configured so that it cannot be used with a SIM card from a different operator or service provider. Please contact your current operator or service provider for assistance.
If none of the situations above apply and you continue to receive this error message, your SIM card may be damaged. Please contact your operator or service provider to have the SIM card tested and/or replaced. Or alternately, bring your phone to the nearest Nokia care point for inspection. You can find Care point addresses from the drop-down menu at the bottom of Repair.
Thanks & hope its helpful for you.
Mar 10, 2010 | Cell Phones
phone is requesting a PIN / PIN2 / PUK / PUK2 code.
Once my Mobile asked for PUK Code,I contact the Mobile Network Service provider they Provided me that.So You can get it from them.....
Sep 13, 2010 | Cell Phones
when i switch on shows enter puk no. my no. is 9432596108
^ Top
Please note:
^ Top
Mar 10, 2010 | Nokia 3120 Cellular Phone
they ask me for pin code PUK CODE
Your phone is equipped with one or more codes to protect it against unauthorized use. The PIN and PUK codes actually protect the SIM card, a small card inside your phone that establishes the network connection.
call your cell phone provider to get this number. hope this helps :)
Nov 24, 2008 | Nokia 2760 Cellular Phone
236 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
