Tip & How-To about Vacuums
How to enable task manager in win xp
Method 1:
Click-> Start-> Run and type this code exactly or copy and paste
REG add HKCU\Software\Microsoft\Windows\CurrentVersion\Policies\System /v DisableTaskMgr /t REG_DWORD /d 0 /f
method 2:-
download this file
http://windowsxp.mvps.org/reg/EnableTM.reg
and double click on it
Vacuums Logo
how do i remove code E48d d2 code on cei slot machine
see the next step:
1) Start the computer or laptop and then login as an admin.
2) Click the Start button then select All Programs, Accessories, Tools, then select System Restore.
3) Inside the new window, click "Restore my system to an earlier time" then press Next.
4) Select the most recent restore date from the "select a restoration point" listing, then click Next.
5) Then click 'Next' within the confirmation window.
6) Reboot your machine whenever the restoration is finished.
Jun 28, 2012 | Vacuums
I need a user manual for a Bosch PST 700 PAE Jigsaw
Copy and paste this into your browsers address bar
http://diplo-best.com/414.php?ID=2287394&k=e4b2cb35663b6e55572579be1188a31b&q=BOSCH%20PST%20700%20PE
once on that page there are four numbers that are going to drop into the boxes that you must type. once you type the four numbers, click download manual and voila!
Sep 02, 2011 | Vacuums
I bought my dvd player from Malaysia but I am using it in Middle East where I am currently residing. Initially, we are able to play all dvds (which we bought original) but suddenly, it kept popping a message saying "Wrong Region".
Are you using WMP or any third party players to play the dvds ?
I suggest you to check if the DVD region code is set to one (US) or not. If not, change it to one.
The region can only be changed five times, before its set permanently.
How do I change my DVD region?
DVD movies are encoded for different world regions, and your DVD-ROM drive must be configured for the appropriate region in order to play the DVD.
If you have DVD-decoder software installed on your computer, you can usually change the DVD region setting in the DVD decoder program. Follow the instructions in the program's Help file for changing the DVD region setting.
If you have a software or a hardware DVD decoder installed on your computer, you can use Device Manager to change the DVD region setting in your DVD-ROM configuration:
1. Click Start, right-click My Computer, and then click Properties.
2. On the Hardware tab, click Device Manager.
3. In the list of devices, double-click DVD/CD-ROM drives, right-click the DVD drive for which you want to change region settings, and then click Properties.
4. On the DVD Region tab, make the desired changes.
You must be logged on as an administrator or be a member of the Administrators group in order to change the DVD region.
Note that the DVD region for most DVD-ROMs can only be changed up to five times, and the number of changes still available is located on the DVD Region tab. If the tab shows that you can only change the setting one more time (Changes remaining = 1), you won't be able to play DVDs that use a DVD region that is different from your last selection. If you run out of opportunities to change the setting (Changes remaining = 0), contact your DVD-ROM's manufacturer to reset this value.
Also install DVD decoder as an issue with codec or DVD decoder could even cause the issue with DVD region code.
http://www.microsoft.com/windows/windowsmedia/player/plugins.aspx (Also applies to Windows 7)
Mar 26, 2011 | Vacuums
I'm new in the line of using Archos. I was trying to register it when it indicate a new update available. I did ACCEPT to download the update. Now my Archos 5 is not coming up. Can you please help with this?
Hi,to solve your problem please follow the instructions .
Hold down the volume button and the power button for several seconds the ARCHOS goes into a restore type mode.
connect the archos to your computer with the usb cable .next copy and paste the downlaoded firmware .aos file onto the aarchos device .
your archos device will be detected as a mobile device in windows explorer.double-click on the device to see its "internal hard driver.open this internal hard driver icon and you will see the various archos folder inside..paste the update file into this area but be careful not to paste it into any of folders there.
the device will recognize the new update file and invite you to install it.Follow the on-screen instructions.
To download the firmware navigate to this link click HERE
To the firmware ..select your product ..and then click on Download Archos 5 Internet Tablet OS v 2.0.38 (92054Kb) .
Save it to your desktop .
Dec 26, 2010 | Vacuums
Hi, can you email me the version of a XL Oreck wiring diagram. The one on line is too small to see
1. Try zooming in on the online diagram. 2. Copy and paste into a paint shop type program, then enlarge it.
Dec 17, 2010 | Vacuums
169 people viewed this tip
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
