Tip & How-To about Coffee Makers & Espresso Machines
Descaling espresso machines, Never use any Vinegar as descaling agent
In order to proceed with decaling of the espresso machine you need to have the solution appropriate for decaling an espresso machine.
Different brands of espresso machines, like Krups, Saeco, Gaggia e.t.a. have their own brands of decaling solutions. You should know that all of these are similar products so you can use them in all different bands if you don't have the one of you specific brand without any problem. So if you have Krups machine and you can only find Saeco decaling solution you can use it with the same results.
One thing you should have in mind Never use any Vinegar as a decaling solution since this will destroy some parts of the machines not instantly but in long term since vinegar is corrosive to this parts.
So the first thing is to remove any water fitters or small softeners that are included in you water tank. Fill the water tank with water up to maximum, dissolve your solution in the water you do need only two to three spoonfuls of solution.
Switch on the machine and wait to warm up. When the machine is ready you can turn the water knob and start getting some water in a pot. Leave it for a couple of minutes and then again the same. Do these until you draw off all the water with dissolve solution. After that leave the machine for more than 20 minutes. Remove then the remaining water with solution from the water tank, rinse it and fill it with fresh water. Now draw again continuously hot water from the machine in order to rinse it completely.
The last portion of hot water taste it to be sure that is pure clean and if not refill the water tank again and perform another rinsing.
Now the machine is ready to be used again.
Try to do decaling every 20 to 30 days.
If you plan to leave the machine unused for along time perform a decaling in order to avoid the possibilities of having the machine stuck when you will try using it again after a long time.
A machine which is used frequently every day is more secure to work fine even without any decaling but machines which are used rarely is more possible to have problems of stacking out in water outlet or coffee outlet.
Coffee Makers & Espresso Machines Logo
I have been told there is a place in the back of the machine to insert a screw in order to lock the tray in position for shipping. Directions pretty please?
Try supplying brand and model information. None of the coffee makers I work on have such a screw. If it's not a coffee maker try asking in the appropriate category.
Oct 23, 2015 | Coffee Makers & Espresso Machines
how do I clean my Saeco Vienna SuperAutomatica Coffee Maker, Espresso Machine
Jun 29, 2010 | Saeco Vienna SuperAutomatica Coffee...
Descaling De Longhi IFD Expresso Coffee Maker
Different brands of espresso machines, like Krups, Saeco, Gaggia e.t.a. have their own brands of decaling solutions. You should know that all of these are similar products so you can use them in all different bands if you don't have the one of you specific brand without any problem. So if you have De longi , Krups machine and you can only find Saeco decaling solution you can use it with the same results.
Mar 20, 2010 | Coffee Makers & Espresso Machines
descaling
Ok guys this is my own opinion on descalling and I have to tell you firstly I have been repairing saeco machine for over 8 years so I think I know a bit about them by now. Scheduled Descalling to me is a waste of time and money, now I'M NOT saying to "never descale your saeco" but when that descale light or word comes up on your machine it does not necessarily mean your machine needs to be descaled. Your Saeco machine DOES NOT have a magical sensor inside that tells you there is calcium build up inside the boiler. All Saeco machine use a timer device built into the Electronic main board. As a pre set number of coffee's are made, Saeco has set a timer to bring up either a light or Symbol on screen to tell you your machine is in need of a descale. Now with different countries , States and living conditions not all water outlets consist of the same water purities, so how can Saeco say at a certain time your machine needs descalling? . I can only go by experience where I repair machines in Australia (Melbourne) and I have had many machines fail due to being constantly descalled. How many of you have been having a good run from your machine until the day you thought you had better off descale your magic deluxe as it hadn't been done in a while. Upon descalling the machine you hear and see water leaking from the unit and Bang , the machine stops dead , or if your very lucky you shut the machine off just in time before the circuit board gets wet and you send the Deluxe to Saeco and now your up for a new boiler and service.
What had happened is that in time the seals of the boiler have broken down and the calcium lining the boilers internal walls have been sealing the boiler from leaking. Upon cleaning the boiler , calcium is removed and the seals don't hold and you know the rest. I have personally given a machine to a family member and told them never to descale just to see what happens ( will the boiler go , or water stop flowing due to blockages? ) I can honestly tell you that this machine was made in 1996 and I had replaced the boiler 8 years ago , to this day the machine has not missed a beat and no leaks on boiler. Ah they hardley use it I hear you say , quite the contrary , Italian family, machine used every day and even taken once in a while to their local social gatherings making coffees for over 30 people. I also have a customer who every so often after 2 years will come back for a new boiler fitted ( machine used in pannel beating shop ) I told him to try not doing any descaling until he could see any water flow restrictions. It's been over 3 years now and I havent seen the machine back yet but I do time to time come across him and ask how the Saeco is going , he says "all is well". Now not doing a descale at all is madness as I have had many blocked or semi clogged boilers due to high calcium deposits ( expecially around the beach coast areas ) But if you feel that your machine is pumping a little less water and the brewer is clean form any blockages then a well deserved descale is probably needed. With older machines you only need to reset the descale light or display if not needed. With other types like Saeco Incanto you need to only go through the descale process without the additive or cleaning fluid introduced into the water tank and decsale will reset.I hope I have shed some light on this issue and I'm not trying to say Saeco are pulling the wool over your eyes when it comes to descaling. I am going by my experiences only and what I have seen during my time with these machines. Enjoy your Coffee.
Mar 12, 2010 | Saeco Magic De Luxe Espresso Machine
Decalcify?
I had the same problem with a Saeco Royal Digital. I ran the decalcifying liquid through the machine with the automatic descaling program as per the instructions on the bottle and the DECALCIFY message stayed up.
I solved it by going to the menu and selecting "Signal Descal." and toggling it from No to Yes. I escaped back to the menu and git the usual "Select Product".
Hope this helps.
Nov 05, 2007 | Saeco Royal Professional Espresso Machine
2,319 people viewed this tip
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
