Tip & How-To about Computers & Internet
INSTALLING A VIDEO CARD
Before getting started
  1. Difficulty of installing computer video card should be a 2 out of 5.
  2. Write down important information from the top or bottom of the card such as the Model Number, Serial Number and specifications.
  3. Ensure you are familiar with ESD and its potential dangers.
  4. When physically installing the video card, ensure the computer is powered down and unplugged.
  5. Finally, verify that the computer has an available AGP slot and/or PCI slot for the video card. If you are planning on taking out your previous video card to install the new video card ensure that the slot will be compatible with your video card. Some computer cases have a proprietary AGP slot causing only certain video cards to be compatible with the computer.
Set Jumpers
While today most Video Cards are configured or setup through either software or through Plug-n-Play, if your Video Card has jumpers verify that the jumpers are properly set. The jumpers generally determine the IRQ resource settings.
Additional information about resource settings can be found on our resource page.
Install into Expansion slot
Today, Video cards are capable of connecting into a PCI or AGP slot. Locate an available slot within the computer and gently push the card into the slot until it snaps and holds place. Once the card is in the slot, place a screw into the top of the card to hold the card into position.
Additional information about the computer bus or expansion slots can be found on ourcomputer hardware bus page.
BIOS setup
Once the Video Card has been successfully physically installed into the computer, place the case back onto the computer and connect the keyboard, monitor and power to the computer (we recommend that you do not connect all the cables yet, if problems are experienced you may have to disconnect all the cables again).
If your computer has an on-board video card, determine if the Video card can be disabled through BIOS. Turn the computer back on and as it begins booting, enter BIOS setup. If this option is not present in BIOS we recommend your review documentCH000193.
Additional help and information about the BIOS can be found on our BIOS page.
Software setup
After the card has been installed, your video card should have included software drivers for your operating system.
If the video card did not include drivers or the drivers appear not to work, you can find a listing of drivers on our video card driver page.
Computers & Internet Logo
Having difficulty connecting the jvc gr-d370 to my computer using Windows Media. What must I do to retrieve the video from the camcorder using the USB cable?
I had this same issue. I solved it. The USB cable will NOT work to transfer video. You need a IEEE-1395 fire wire cable. I purchased the internal card and cable for under $20.00 for my DELL computer direct from dell. After you connect your camcorder to your computer, I clicked on windows photo gallery. Then in top left corner, click file and "import from camera or scanner. Your camcorder must be on video mode and play mode. Your computer should recognize the camcorder, click on it and then it will give you options, like you can upload and record direct onto DVD. I liked the option of uploading manually because if there are blank sections on the DV tape, the computer will stop uloading. Hope this helps.
Dec 28, 2010 | JVC GR-D370 Mini DV Digital Camcorder
I need to know what kind of video card is in my computer
Hi Good day!! You can check it in "DXDIAG" here are the step to check it:
1. Click "Start"
2. Click "Run" and then type this dxdiag and then ok. now you should be on Direct X Diagnostic Tools box
3. There are five tabs there choose "Display" now you can view your video card installed in your pc!!
Hope my soltion help you!! Thanks!!
Oct 16, 2010 | Gateway 510 X (10272197) PC Desktop
vertical green line down center of picture when on skype
See section A. Skype in the info below to setup the Audio & Video.
Also send this to your family and friends so they have their computer setup properly.
Web Camera's have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype
http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/
set it up as follows:
Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
Then click on the Video Settings.
The camera, if Installed Properly, it will come up and show a video picture.
Then, on the bottom of the page click save.
The camera and audio should function properly. Your friends and Family will now be able to see and hear you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger
http://www.soft32.com/download_30.HTML
Go to Messenger at the top left and click on it.
Next go down to Preferences and click on it.
Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
Next go to the Test Audio section and (in blue writing) click on "Open the call setup assistant" and follow the instructions on the left window.
C. Windows Live Messenger:
http://download.live.com/Messenger
After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
Then on the Windows Live messenger window on the right side, click on " "Show Menus." And then click on "Show the Menu Bar".
Next go to the Menu Bar on right side, click on " "Action."
Go to "TOOLS" and click "Audio and Video Setting" and follow the instructions.
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
D. AIM (AOL) Messenger:
http://dashboard.aim.com/aim
On the VIM sign-in window click on Edit.
Then click on Settings Enhanced IM.
Next click on Enhanced IM.
Then click on Audio Video.
The Audio and Video portion has drop downs so you can select the proper audio card and video camera installed in you computer.
The Audi Video drop downs are
Microphone
Speaker
Camera
The audio and camera should function now.
Additional information to use with VIM settings.
Adjust Your Audio and Video Settings:
In order to adjust your audio and video settings, please follow the steps given below:
1. Click the Audio and Video Settings button directly below the My Buddy or My Camera window. If you are currently
Participating in an AOL Live Video IM session, a message will display: You must disconnect the current AOL Live Video IM
Conversation before running setup. Would you like to disconnect now? Click the Yes button.
2. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working
Properly. Follow the on-screen prompts.
Notes:
The first time you use AOL Live Video IM, a message will display: Would you like to first check your audio and video settings? Click the Yes button.
The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly.
images in AOL Live Video IM may appear reversed, or as a mirror image (text may appear backwards) when you look at your own camera feed or at the
Picture-in-picture (PIP) display.
After making the settings your ready for a chat and video talk with your Family and Friends.
Hope this helps. Bud
Apr 11, 2010 | Microsoft LifeCam VX-3000 Web Camera
Contact Number
Hi, You can import phone data from a Subscriber Identity Module (SIM) card to the address book application on your BlackBerry smartphone.
Contacts in the address book can be saved to the SIM card individually. You cannot import data from the address book to the SIM card.
To import a single contact, complete the following steps:
1)On the BlackBerry smartphone Home screen, open the Address Book.
2) Display the menu and select SIM Phone Book. The SIM phone book is loaded.
3) Select the contact you want to import, then select Add to Address Book.
4) In the New Address screen, add any additional information.
Import all contacts, complete the following steps:
1) On the BlackBerry smartphone Home screen, open the Address Book.
3) Display the menu and select Copy All To Address Book.
4) Go back to the Address Book and make sure all the entries are displayed.
After adding information to ddress book you can able to veiw contact list, I hope this information will be helpfull.
Oct 14, 2009 | RIM BlackBerry Bold 9000 Smartphone
364 people viewed this tip
David Payne
David Payne
