Tip & How-To about Car Audio & Video
Factory radio with code and or safe mode
It seems like everyday someone is writing in with the problem of loosing the radio code or having changed a battery and now their radio comes up with "safe" or "code".
the registered owner of the vehicle needs to call the dealer and with the V.I.N. # ready for them (and in some cases, the radio serial number) to get the serial number of the radio it will have to be removed in some cases and in other it can be brought up on the screen of the radio. the dealer will know this and how to advise you to do so. request the code and procedure. Once you have this code and procedure, write the code and steps down in the owners handbook or other item that stays with the vehicle.
There is no master code that works for all radios. how it works is the dealer has a computer program that will generate the code from the serial # inputed into it. so each radio has it's own unique code.
I hope this helps everyone with this issue , for you will have saved the code and have it handy for that next battery change.
Car Audio & Video Logo
Radio code of an Honda Odyssey 2005 where find it
This code should be in the glove box on a small card, look in the owners book, i have found the codes in many places when looking, i have found then written by customer in book in radio section, also look in all books as the dealer will write code in maintence book, they write the color make ,model serial # and radio code.
The code comes on a card that says radio code , anti theft radio, it is the size of a credit card.i do not know why people remove it and loose it and then when someone buys it they have no idea until they need battery replaced or it goes dead.
look around good , if you can not find it then radio serial # is needed, which radio needs to be removed to get and then with ID and proof of ownership you can go to dealer and they will give you the code.
Dec 24, 2012 | Cars & Trucks
replacing the radio and was told i need a code to activate it.... If so what is the code...?
You must be replacing the radio with a stock PT cruiser radio. ( one that normally comes with the car, Not aftermarket.) recommend looking on back of radio for a radio ID number, then calling a dealer and giving them the VIN to the vehicle and the radio ID number. Once you do get the number, write it down and keep it somewhere Safe BESIDES in the car. This is a anti theft feature, so if someone steals your radio they wont be able to use it. Also if your battery every goes dead and your car looses power, you will need to re enter this number in the radio in order for it to work. ...best of luck
Jan 15, 2011 | 2002 Chrysler PT Cruiser
Mitsubishi Montero Sport Radio Code
Call your local MItsubishi dealership and ask for the service department.
<BR>They have a computer program where they punch in the serial number from your radio (you have to supply the number) and it will tell them the UNLOCK CODE for your radio. My dealership offered to give it to me free over the phone, if I knew my radio serial number. Enter the code using the buttons on your radio. And write the code down, this will show up everytime your radio looses connection to its power source - the car battery.
Mar 14, 2009 | 2001 Mitsubishi Montero
188 people viewed this tip
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
