Tip & How-To about Computers & Internet
System speed up
First simple go to my computer properties and system properties wll be opend then go advanced option and click there performance setting and after one window will be opend then click on visual effects and choose
"adjust for best performance"
Computers & Internet Logo
virtual memory too low
  1. Click Start, right-click My Computer, and then click Properties.
  2. In the System Properties dialog box, click the Advanced tab.
  3. In the Performance pane, click Settings.
  4. In the Performance Options dialog box, click the Advanced tab.
  5. In the Virtual memory pane, click Change.
  6. Change the Initial size value and the Maximum size value to a higher value, click Set, and then click OK.
  7. Click OK to close the Performance Options dialog box, and then click OK to close the System Properties dialog box.
I hope this helps you with your issue. Don't forget to rate. Have a great day!
Feb 26, 2010 | Acer Computers & Internet
How to change Data Execution Prevention (DEP) settings in Windows 7? Data Execution Prevention (DEP) is a feature that protects our system from viruses and other security threats. The Windows constantly monitors the programs running on our system and closes them if they perform any malicious activity. But sometimes we want a certain program(s) to run even if the Windows alerts us that it is a malicious one. To change Data Execution Prevention settings in Windows 7 follow these simple steps: 1) Right click on the My Computer icon on your Desktop and select Properties. Fig. 1 2) The System window opens now. Here click the Advanced system settings link in the left pane as highlighted below: Fig. 2 3) The System Properties window opens now. Here click the Settings... button under Performance section under Advanced tab Fig. 3 4) The Performance Options dialog box opens now. Here select Data Execution Prevention tab and then click on the radio button Turn on DEP for all programs and services except those I select option and click Add button Fig. 4 5) Now select the Executable file (i.e. the .exe file of the program you want to add) that you want to add and click Open button Fig. 5 Note: If you try to add an executable file which cannot be turned off it's DEP feature, then you will receive a warning as shown below. Fig. 6 6) In the same way, to remove an executable file from the list select that file and click Remove button. 7) Click Apply and then OK button in the Performance options window 8) Click OK button in System Properties window 9) Close System window. Thanks for reading.
Jan 28, 2011 | Computers & Internet
virtual memory is low computer is very slow
hello frnd, you can increse your virtual memory manually...
1.go to properties of my computer
2.go to advance tab...
3. there is option to change virtual memory.
4.click on it and change virtual memory accordingly..
hope this will help you
Jun 30, 2009 | Dell Dimension 2400 PC Desktop
virtual memory
yes upgrading your ram (random access memory) helps alot
also incressing your virtual memory paging file might work if it is set 2 low.
Windows XP loadTOCNode(2, 'resolution'); 1. Click Start, right-click My Computer, and then click Properties. 2. In the System Properties dialog box, click the Advanced tab. 3. In the Performance pane, click Settings. 4. In the Performance Options dialog box, click the Advanced tab. 5. In the Virtual memory pane, click Change. 6. Change the Initial size value and the Maximum size value to a higher value, click Set, and then click OK. 7. Click OK to close the Performance Options dialog box, and then click OK to close the System Properties dialog box.
Dec 07, 2007 | Acer Aspire 3000 Notebook
203 people viewed this tip
David Payne
David Payne
