Tip & How-To about Refrigerators
Refrigerator Maintenance Tips
Keeping your refrigerator performance at its best is something that takes some thought and some time to do. Here are some things that will help your refrigerator to run like a new refrigerator for many years.
If you still have a very old manual defrost refrigerator, then make sure that you turn off the refrigerator and defrost it whenever more then ½” of ice builds up on the inside of the box.
If you have a self-defrosting refrigerator then you need to check that no frost is building up on the inside. If frost is evident, then you need to check to see why it is there. There is a problem with the defrost part of your fridge. Also check the drain pan that is usually under your refrigerator. It is a good idea to clean this once a year.
A good time to clean the drain pan is when you also clean the condenser coils. The coils are usually underneath the refrigerator. They can be cleaned by using compressed air to blow the dirt out or by using a vacuum to pull the dirt out.
Next check the door seals on your refrigerator. Clean your seals with warm soapy water and inspect them to make sure they are not torn, and that they seat tightly against the frame of the refrigerator. If the seals are leaking it will cause the refrigerator to run much more and possibly not even be able to cool properly.
For your refrigerators best performance you need to make sure that all of the proper cleaning and service is done at least once a year. This holds true for all size refrigerators. Cleaning and maintaining your refrigerator is easy to do if you do it regularly and do not let it go till the refrigerator does not work anymore.
http://www.fixya.com/support/r4327013-refrigerator_efficiency
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r4326731-new_refrigerator_size_or_refrigerator
http://www.fixya.com/support/r4326586-new_refrigerator_refrigerator_depth
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
http://www.fixya.com/support/r4020581-moving_refrigerator_best_way
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
http://www.fixya.com/support/r4588788-refrigerator_or_freezer_not_cooling_or
Refrigerators Logo
96 GMC Sonoma 4.3engine still will not start.I now see oil or transmission fluid slowly leaking right at where the transmission and engine connect.Rubber **** on engine side coming down, small drip th
With replacing all those parts an not fixing the thing ,your best bet , take it to a qualified repair shop. Some place that test's an not guesses .
Dec 30, 2017 | 1996 GMC Sonoma
fidge and freezer not keeping things cold
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 03, 2011 | Refrigerators
HI. I have an old Armana botton freezer frig. The freezer is not keeping things frozen. I have cleaner the coils etc. In the toe space there is a little box with a red botton on it. Do you know what that is for. I turned it a little and the freezer was working better but not that good. ANy thoughts on that button. Thanks so much. M
heatman101
Jun 30, 2011 | Amana Easy Reach AFD2535DE Bottom Freezer...
Daewoo FDF-358 fridge is taking a couple freezer is taking a couple of days to freeze solid and the fridge is just not keeping anything cold ..... fan in the freezer is not iced over, there is no feel of cold air when you open the fridge door only the freezer section........can it be fixed? and if so any ideas on the cost of the repairs would be cause i'm on a really tight budget. thanx
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Mar 10, 2011 | Daewoo Refrigerators
It's not keeping things cold or frozen
Refrigerator
heatman101
Mar 05, 2011 | Hotpoint HSS25GFP Side by Side...
17,666 people viewed this tip
Top Refrigerators Experts
Marvin
Marvin
Gil Shultz
