Tip & How-To about Washing Machines
Bosh Dryer Lint Problem
When your bosh dryer stops working and the lint light filter turns on ,close door and start again.This time push door and hold so that the door is closed more tightly.This time dryer should work.
To fix this ,remove the door then remove hinge bracket .Under the bottom part of the bracket insert plumbing ruber gasket.This will adjust the dryer door,it should close more tightly.
Lint light should not turn on again and dryer should work fine.
Please let me know is this works for you.
Since the adjustments of my dryer door, I have not had any problems.
If you have any questions, just ask.
P.S- I know it may sound weird to do this, but since I had adjusted the door this way, the dryer does not turn off during drying sessions.
leco
Washing Machines Logo
THE LIGHT WILL NOT COME ON WHEN THE DOOR IS OPENED AND THE DRYER WILL NOT STOP WITH THE DOOR OPEN
The dryer has a switch in the door that is activated when the door is opened/closed, replace this switch or check the connector to it or the wiring.
Oct 25, 2016 | Kenmore Dryers
Lint Filter Light comes on and cycle is interupted
Depending on how old this is or how much it is used depends how much lint has built up inside
the air flow tube. I have seen where you look inside where the lint screen is and beneath it with screen removed there is nothing but lint, in which case the dryer thinks the screen is clogged. You might have two screws on the inside of the drum that hold the screen holder in place. First remove the lint screen
and hold the little door that closes when you remove the screen, open the little door and look down inside it with a flash light, if you see a lot of lint, like I said you might be able to remove the holder
and clean this area out, also take a coat hanger and bend a little piece at the end and use this to get most of the lint out of this area and the tube that Leeds down from this area. If this can be done
and you get this area clean and it still happens, you might have to clean the entire area the tube
and the back tube,the tube leeding to the outside of the house and vent. Any questions please post back.
Mar 27, 2009 | Bosch Axxis WTA 3510 Electric Dryer
3 beeps and lights flash when I push the start button
The door is not compltely closing. Make sure to push it in hard around the clasp areas. If yours has a light, the light should turn off and on as you open and close the door.
Sep 10, 2008 | Frigidaire FEQ1442ES Electric Dryer
Bosch Dryer lint filer warning
The Bosch Dryer has a temperature probe in the heater exit and in the exhaust area visible when you open the door. If the temperature difference between the two gets to high, the lint filter is assumed to be plugged and the alarm goes off.
It seems that the temperature probe at the heater, can end up with a faulty connection to the control panel over time due to corroded contacts or lint build up. When this happens the control panel thinks the filter is clogged and it may also not turn on the heating elements properly. Remove the back cover over the heating element (12 screws) and then remove the one screw holding the red wiring connection to the dryer body. You can then wiggle out the wiring connection and clean / unplug and replug in the connector for the sensor. (plug with two small wires only). A little hard feeding the connector back through the hole so take your time and don't damage the wires). Should all work again. May want to inspect inside the heater at same time and make sure the overheating switch is not tripped. ( press in the red button).
May 21, 2007 | Bosch WTMC3510UC Gas Dryer
153 people viewed this tip
Top Washing Machines Experts
