Tip & How-To about Microsoft Office Outlook 2007 for PC
I cannot access my Verizon mail _ Verizon.net server responded: Authentication failed.
Hi.
The following tip applies to users that want to access Verizon mail using an e-mail managing software as for example Outlook, Outlook Express, Eudora and similar.
The checkup procedure and server settings can also be used to setup your verizon email on a mobile or on a PDA.
If the Verizon server responded: Authentication failed, that means that either your ID, or your password had not been recognized.
Ensure that Caps Lock is not on.
ID and password are case sensitive, ensure that you use capitals only if needed.
Ensure that you entered the right user ID and password for your mail.
The ID must be your Verizon email address, or the first part of the Verizon email address (before @ sign). Password must be your Verizon email password.
If for example the address is MyMail@verizon.net , then try first putting id MyMail@verizon.net , if that does not work, try again with MyMail as ID.
The format that is supposed to work on Verizon is MyMail@verizon.net.
Ensure that the server settings you are using are correct:
1. Incoming mail server (POP3) - incoming.verizon.net.
2. Outgoing mail server (SMTP) - outgoing.verizon.net.
Ensure that you have not set the Log on using Secure Password Authentication (SPA)
Ensure that ports are POP3 PORT: 110. SMTP PORT: 25
Turn off any active firewall or security software. Also ensure that your router is not blocking port 110 (for POP server) or port 25 (for SMTP).
If all that does not work, then there may be an issue that depends on Verizon server. Also try calling Verizon online to find out if there is any additional issue that can affect your account.
Regards.
Microsoft Office Outlook 2007 for PC Logo
Is it possible to access Outlook Express emails from MS Outlook?
Use this DBX to PST Converter software to convert dbx to pst files in easy steps.This tool allows users to convert the multiple DBX formats with their respective attachments to an MS Outlook. It can maintain the all email properties of DBX file into PST after the conversion of files too. The email structure of file contains To, Cc, Bcc, From, sender, receiver, etc. all will remains same. It provides an accurate 100% result of conversion of DBX files into a PST. This application allows user to preview the valuable email data items and users are able to verify the content of mails.It is a safe and a reliable solution for users to convert their DBX files and archive them into PST.
For Free demo version, you can visit :- DBX to PST Converter
Feb 27, 2017 | Express Computers & Internet
Message recall
Outlook Express 6 was intended as a way to download your mail and view it locally on the computer its used on. In most cases mail accessed with Outlook Express was done so using POP account settings, resulting in the mail being deleted off the main mail server (in your case, verizon) and leaving only the copy of that email sitting on your computer in Outlook Express.
Of course if you were using more customized mail settings, its possible to keep the mail from being deleted from the server and have access to it from other computers or being logging into your mail account through a web browser like Firefox or Chrome, etc.
So to answer your question... If the email still exists on the server (verizon) then yes it can be done. But then accessing your account via the web would be far easier than doing it with Outlook Express.
On the other hand, if the email cannot be seen on your verizon account online, then accessing it with Outlook Express will not be possible. If its not there, its not there.
If the email physically exists on your computer in Outlook Express, then regardless of the account it was received through, it should still be there. If you changed your computer logon information, you might have inadvertently switched identities, resulting in your mail appearing to be gone. It could still be safe and sound, but hiding under another mail identity. You can find this by looking in your menu in Outlook Express for switching identities. If you see more than one identity available, switch to another and look for your mail.
I hope this helps.
Aug 20, 2012 | Microsoft Outlook Express
I would like to set up outlook express with my yahoo account
Access a Free Yahoo! Mail Account with Outlook Express Using YPOPs!
To access a free Yahoo! Mail account with Outlook Express using the YPOPs! desktop utility:
* >> Step by Step Screenshot Walkthrough
* Install YPOPs! and make sure it is running.
* Open Outlook Express.
* Select Tools ' Accounts... from the menu in Outlook Express.
* Click Add and select Mail....
* Type your name.
* Click Next >.
* Enter your Yahoo! Mail address ("hmmzl34@yahoo.com", for example).
* Click Next > again.
* Make sure POP3 is selected under My incoming mail server is a ___ server..
* Enter "localhost" under Incoming mail (POP3, IMAP or HTTP) server:.
o If "localhost" does not work, try "127.0.0.1" instead.
* Type "localhost" under Outgoing mail (SMTP) server: as well.
o If "localhost" does not work, again try "127.0.0.1" instead.
* Click Next >.
* Type your Yahoo! Mail user name under Account name:.
o The user name is your Yahoo! Mail address sans "@yahoo.com". In this example, the user name is "hmmzl34".
* Enter your Yahoo! Mail password under Password:.
* Click Next >.
* Click Finish.
* Highlight localhost in the Internet Accounts window.
* Click Properties.
* Type "Yahoo! Mail" under Mail Account.
* Click OK.
* Click Close.
Useful YPOPs! Options
I recommend you also double-click the YPOPs! system tray icon to change a number of useful settings.
You can make YPOPs! ignore messages in the Bulk Mail folder of your Yahoo! Mail account, for example, tell it not to mark downloaded messages as read, fetch sent mail or have YPOPs! put a copy of outgoing mail in your Yahoo! Mail Sent Items folder.
Access Free Yahoo! Mail with Outlook Express Using IzyMail
To set up a Yahoo! Mail account in Outlook Express via IzyMail:
* Make sure your Yahoo! Mail account is registered with IzyMail.
* Type your name.
* Click Next >.
* Enter your full Yahoo! Mail address ("hmmzl34@yahoo.com", for example).
* Make sure IMAP is selected under My incoming mail server is a ___ server..
* Type "in.izymail.com" under Incoming mail (POP3 or IMAP) server:.
* Enter "out.izymail.com" under Outgoing mail (SMTP) server:.
* Click Next >.
* Type your complete Yahoo! Mail address under Account name: ("hmmzl34@yahoo.com", for example).
* Now type your Yahoo! Mail password in the Password: field.
* Click Next >.
* Click Finish.
* Highlight in.izymail.com in the Internet Accounts dialog.
* Click Properties.
* Go to the Servers tab.
* Make sure My server requires authentication is checked under Outgoing Mail Server.
* Go to the IMAP tab.
* Make sure Store special folders on IMAP server is checked.
* Type "_Sent" under Sent Items path:.
* Enter "_Draft" under Drafts path:.
* Click OK.
* Now click Close.
* Click Yes to download the list of Yahoo! Mail folders to Outlook Express.
* Click OK.
Oct 15, 2010 | Yahoo Messenger
unable to access email account on acer net book . i have a laptop running blueyonder broadband,when i try to connect my netbook to my outlook express email account i get unable to access the mail server.
Hi
This sounds like your user account settings are not correct and need to be input via the account management section to look like the following:
  • Customer Email format - user.name@blueyonder.co.uk
  • Outgoing Mail Server - smtp.blueyonder.co.uk
  • Outgoing server type - SMTP
  • Incoming mail server - pop3.blueyonder.co.uk
  • Incoming server type - POP3
  • Password - for example, Rich4rd1
  • Thanks
    Taz
    Oct 30, 2009 | Acer Aspire One Netbook 8.9" Notebook
    1,447 people viewed this tip
    Top Microsoft Computers & Internet Experts
    micky dee
    Piyal Perera
    Piyal Perera
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
