Tip & How-To about Kitchen Ranges
Maintenance for your Range, Stove, or Oven
Keeping your cooking appliances in the top working condition, takes a little bit of tender loving care from you. You use them everyday and they need to be taken care of properly to continue to give you the best performance possible.
Most people are aware that they can remove the parts and pieces on the tops, but do not know that the knobs can easily be removed to clean them and behind them. By simply pulling out away from the appliance, most knobs can be removed. This allows you to easily clean the knob and the area behind it.
The tops of many newer appliances often need special care. Watch out for abrasive cleaners. Many of the cream type cleaners have particles in them that are abrasive. A good glass cleaner will often work well for many of the different types of tops.
Oven can be cleaned with an oven cleaner. Be sure to give the oven cleaners enough time to work. The hard burnt residue that is left in the oven will take time to penetrate through.
Be patient and do not get in a hurry. My advice is to not use the self cleaning mode on your oven, I have seen many, many, people looking for help because their oven has failed to operate correctly, or even unlock, after running the self cleaning feature.
Another thing that gets overlooked many times is the oven light. The bulb blows out and it is not missed until you need it. Check you oven light to make sure that it is working. These also are not a normal light bulb. They are designed to withstand the high heat of the oven environment. It is a good idea to get a replacement bulb and have it on hand just in case yours burns out at a bad time. Change the bulb is really very simple if you have the replacement bulb available when you need it.
These simple things will help you to keep your cooking appliances in top working condition. They serve you well everyday. Give them some attention to keep them working for you.
http://www.fixya.com/support/r4388324-oven_fault_codes_ge_xl44_oven
http://www.fixya.com/support/r4391163-range_stove_oven_door_glass_replacement
http://www.fixya.com/support/r4404788-electric_oven_problem_oven_will_not_shut
http://www.fixya.com/support/r4319588-electric_oven_problems_not_use_in
http://www.fixya.com/support/r4154940-fault_codes_admiral_range_stove_oven
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
Kitchen Ranges Logo
what is a TLC?
Tender Love and Care.
Jan 09, 2014 | Cars & Trucks
my whirlpool bottom element does not work . the element is enclosed. do i get at it from the side or bottom.the model is xlp34900 electric stove
Make sure cook had it set to bake, not broil (broil on runs top element), renters often forget that . First turn off electricity to the stove, breaker or fuse. I always confirm its off by trying a burner, doesn't heat in 30 seconds confirmed off.
Element loops from the back wall, held up by a little standard.
Usually there is a small screw under where the element goes into the back wall on each side, there is a little metal plate there that the screw holds down, remove the screw and plate and pull out element a little bit and will see where wire has a slip on connector onto element, slip those off, carefully unsnap little support (like clips to it) or unscrew from oven bottom. Then go to appliance parts dealer. Not appliance repairman but every time I did this it was always nearly the same exact way.
Jan 13, 2011 | Whirlpool Accubake RF362LXTT Electric...
please tell me how this appliance works. Thank you. Mary Jane Howroyd Kitchen Aid Crock Pot
Make sure that what you are cooking is something that can be cooked in a slow cooker. Put all the ingrediants into the pot, plug it in and set it to either Low -This setting is the most used setting. Usually takes 8 hours or so depending on what you are cooking. High -This setting is faster and usually cooks in half the time as Low, but meats aren't as as tender cooked on this setting. Also make sure you put in enough liquid. You usually want the pot filled 2/3 with whatever liquid you are using to cook with.
Dec 27, 2010 | KitchenAid Crock Pots & Slow Cookers
Senseo won't turn on after running vinegar thru it to clean.
If it doesn't respond at all then make sure the plug is in the wall socket and the wire isn't damaged. If it's plugged in properly, the wire is intact and other electrical appliances work OK when plugged into that same wall socket, the macine will need some tender love and care from a mechanic.
May 14, 2010 | Philips Senseo HD-7810 Coffee Maker
Kitchen Aid Stand Mixer won't release beater
I had this same problem as well.  The beater was stuck like glue to the rotating arm, and it would not budge with any amount of pressure.  I tried the cooking spray and it did nothing.  But today I put a rag in hot/boiling water and then carefully wrapped it around the top of the beater.  I let it sit for 10 minutes. Then I put the rag in hot water again and repeated the process for about another 5 minutes.  When this was done, I covered the beater in a towel (to protect it) and forcefully tapped (ok... I pounded) it with the flat side of my meat tenderizer (it was all I had...you could use a mallet or hammer).  It took a little bit of work because I had to hammer it from the bottom, then the side, then the top to get the little spoke guided through the shaft.  But it did finally come off.  After cleaning with hot water, I put the beater on again and noticed that it was still a little hard to get on/off.  So, I put a little bit of veg. oil on it, and it seems to be better.  Going forward, I will be sure to clean the top of the beater & arm after each use and then coat it with a little oil to keep from sticking.  Best of luck!
Feb 05, 2009 | KitchenAid K45SS Classic Stand Mixer
4,570 people viewed this tip
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
