Tip & How-To about Ovens
Electric Oven Problems - What not to Use in Your Electric Oven
If you have an electric oven, there is one thing that you do not want to do. It does not matter if you have a wall electric oven, a wall double electric oven, or a freestanding electric oven. If the heating element in your oven is electric you do not want to do this.
After normal use of your oven the broiler pan, the oven racks, and the drip pans in the bottom of the oven can become soiled to the point where they will not clean properly anymore. Many people try to make the inside of their oven “look” better and give it a cleaner look by wrapping or covering these things with aluminum foil.
While this may give the oven a good clean look it also creates a problem for you and your oven. Aluminum foil is highly conductive and will “short” the electric elements in your oven if it comes in contact with them. This short means that the electricity will flow through the element and out of it at one point in an uncontrolled manner. This will cause a surge through the element to that point, which will cause the element to fail.
What many people also fail to realize is that the foil they wrap around these thing can move as the oven heats and cools. So even though the foil is far away from the element when you wrap it on, it can move till it comes in contact with the element and then in a moment it is too late to correct.
It has also come to my attention that some people may use aluminum pans in the bottom of the oven to catch any spillover that may happen. In my opinion that is just as bad as the foil wrap. These pans will warp with the heating and cooling also. If you can get a pan on the bottom rack and your food on the top rack, then you are good... the aluminum cannot get to the element in anyway...
If you have racks, pans, or other things in your oven that are too dirty and bother you…you are better off to buy new rather then take the chance on ruining your day in a flash.
http://www.fixya.com/support/r4388324-oven_fault_codes_ge_xl44_oven
http://www.fixya.com/support/r4391163-range_stove_oven_door_glass_replacement
http://www.fixya.com/support/r4404788-electric_oven_problem_oven_will_not_shut
http://www.fixya.com/support/r4319588-electric_oven_problems_not_use_in
http://www.fixya.com/support/r4154940-fault_codes_admiral_range_stove_oven
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
Ovens Logo
I try to turn on and when I do the temp starts going backwards until it is off. The clock will do the same things after I try resetting the breaker.
is there a time bake or something similar on it,sounds like it's stuck on that cycle,next time send the model number,could have a bad touch pad or clock assy. stuck on a time cycle so no matter what you do it's counting down
Nov 21, 2010 | Frigidaire 30 in. Electric Gallery Series...
Viking Double Electric Oven VEDO127T
Probably a faulty heater element, some ovens have more than one element in the compartment, so it is possible you only have part heat.
Dec 01, 2008 | Viking 27" Professional Select Built-in...
4,109 people viewed this tip
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
