Tip & How-To about Microwave Ovens
How to check the High Voltage transformer in a microwave.
When your microwave is dead, you have checked the fuse and it is ok along with the power to the unit, and the control panel is dead, you probably have a bad transformer. It is the large device behind the control panel which has a laminated core. It will be hooked to the mains and supply power to various circuits.
Remove the power and the cover. Remove at least one wire from each side of the transformer. Check with a DMM for resistance. The primary, side hooked to the mains, should have continuity and low resistance, probably only several ohms. The secondary should have higer resistance but probably less than 100 ohms. If this checks out you need to see my tip at http://www.fixya.com/support/r4223574-microwave_oven_will_not_heat . Do not try to check the secondary under power as it will be at several thousand volts and is dangerous unless you are properly trained to do this!
If the transformer checks bad you can get a new one at a good price at http://www.repairclinic.com.
hardrocko
Thanks for using FixYa
Microwave Ovens Logo
GE xl1800 I have checked both fuses and still no power to the control panel. What is the next failure?
someone needs to follow the voltage into the unit--- The voltage goes to fuse and then to inverter that drives the unit---fyi if unit is not real expensive a repair may not be practical----use some precautions if not familiar with this kind of appliance.
Jun 08, 2012 | GE XL1800 1100 Watts Microwave Oven
we have magic chef Over the Range Microwave Oven Model: MCO153U. Microwave was dead and no power
The original problem, was probably caused by a bad door switch along with the fuse, now there is a good chance the control panel is damaged, you will need a professional to assess if the item is worth fixing.
Apr 21, 2012 | Magic Chef Microwave Ovens
no power to Samsung SMH 9151
The main fuse in the microwave oven has probably blown.
Mar 28, 2012 | Samsung SMH9151 Microwave Oven
microwave is totaly dead
YOU WANT TO CHECK POWER FIRT AT THE OUTLET MAKE SURE YOU STILL HAVE 120 VOLTS THERE.. IF SO AND PLUG IS GOOD ON 98% OF THE MICROWAVES OUT THERE IS A 20 AMP fuse located in control panel of unit... check there with the power disconnected and may have a blown fuse...if that is good you most likely have a blown control on unit ...
hopw this helps good luck...
Jan 05, 2011 | Hotpoint RVM1325BW Microwave Oven
Microwave Oven completely dead
Check if there's a fuse on the front panel.i'f had it on other makes.replace fuse and it should be ok.
Feb 22, 2007 | Kenmore 62702 Microwave Oven
1,447 people viewed this tip
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
