Tip & How-To about Computers & Internet
Fixing Windows Updates that keep failing to install
This should work for most if not all MS updates. Try the following:
  • turn off Windows Update temporarily (may or may not be necessary)
    • go to a Command (cmd) prompt (Start, Run, cmd, OK)
    • type in, without quotes: "sc stop wuauserv" (or, "net stop wuauserv")
  • in Windows Explorer delete all files from the following folder: c:windowsSoftwareDistributionDownload
    • to get there, just copy and paste that path, above, into your Start, Run line and click OK or hit Enter
    • highlight all the files in there (press Ctrl-A) and either right-click and choose Delete or just press the Delete key on your keyboard. Don’t delete that folder itself, just all files and folders within it
  • turn the Windows Update service back on
    • type in, without quotes: "sc start wuauserv" (or, "net start wuauserv")
Computers & Internet Logo
How do I fix Windows 10 update 0x800705b4 error code?
This error commonly occurs within the operating system at the time of windows updates. If this error is not fixed, it will lead your system slow or even corrupt it.
This error may arise for the following reasons,
1. windows defender update
2.
Damaged system files.
3.
Third-party anti-virus and malware.
Solution for the windows 10 updates 0x800705b4 error code:
Right here are a few solutions for troubleshooting 0x800705b4 error code,
Method 1: Uncheck the "get updates for other Microsoft products when you updates windows" option:
• Open the "Windows Update" and click "Advance Options".
• Uncheck the "get updates for other Microsoft products when you updates Windows" Option if it's marked.
• Now the update process should complete successfully.
• You may run this process continuously until you get the "your device up to date" message.
• Once this message appears, again check/select "get updates for other Microsoft products when you updates Windows" Option.
Method 2: Temporarily disable the "Windows Defender"
• In case, the above solution doesn't work, you can disable the" Windows Defender" for temporarily.
• Type Defender in the search box and open the Windows Defender Desktop app.
• Click "Settings" and turn off the Real-Time Protection and Cloud-Based Protection options.
• Close the setting window and now the windows defender appears in red.
Note: After that do all the steps in solution 1 again, hope the update process will be successful this time. Once this issue is fixed, you can turn on both Real-Time Protection and Cloud-Based Protection.
Method 3: Run the Windows Update in "Clean Boot"
You should login computer as an administrator for performing "Clean Boot".
Method 4: Run the "Microsoft Update Troubleshooter" and Restart the Windows Update:
Still, if you having update issue, download the "Windows Update Troubleshooter" and Run.
After this, restart the "Windows Update Service".
Follow these steps for Windows Update Service restart,
• Open the Command Prompt(CMD)
• Type "net stop wuauserv" then press "enter"
• Wait for the confirmation message.
• Then type "net start wuauserv" then press "enter"
Hope the above solution will fix the update issue.
Jun 12, 2017 | Computers & Internet
how to update windows xp
Go to Microsoft Update and follow the appropriate instructions.
Jun 11, 2011 | LG Computers & Internet
Microsoft updates do not install
You have not said which OS you are using so; from http://support.microsoft.com/kb/943144
When you try to install Windows updates from the Windows Update Web site, the Microsoft Update Web site, or by using Automatic Update, you receive a message that the update is not installed successfully. Additionally, the update is not displayed in the update history.
You may experience this issue in the following scenarios:
Scenario 1 You try to install updates after repair a Windows XP installation by using the Windows XP CD.
Scenario 2 You perform the following operations before you try to install Windows updates:
You perform a new installation of Windows XP Service Pack 2 (SP2).
You visit the Windows Update Web site, or the Microsoft Update Web site.
Note When you visit the update Web site, the latest version of Windows Update software will be installed in your computer.
You install Windows XP Service Pack (SP3) without a restart.
You try to install Windows updates after the install of Windows XP SP3.
Then cause ;
This issue occurs because the Wups2.dll file that is included in the latest version of Windows Update is not installed correctly.
For scenario 1, the registry entries that correspond to the Wups2.dll file are missing after the repair install of Windows XP. The release version of Windows XP does not contain the Windows Update software.
For scenario 2, the registry entries that correspond to Windows Update are changed back to the Windows XP SP2 version if you did not restart the computer before you install Windows XP SP3. The registry entries for the Wups2.dll file are changed to pointing to the Wups.dll file that is included in the release version of Windows XP SP2.
To resolve this problem, use one of the following methods;
Method 1: Download and install the Windows Update Agent,
For an x86-based computer; http://download.windowsupdate.com/WindowsUpdate/redist/standalone/7.4.7600.226/WindowsUpdateAgent30-x86.exe
For an x64-based computer http://download.windowsupdate.com/WindowsUpdate/redist/standalone/7.4.7600.226/WindowsUpdateAgent30-x64.exe
Method 2: Register the Wups2.dll file,
To have MS register the Wups2.dll file in Windows for you, go to http://support.microsoft.com/kb/943144#FixItForMeAlways.
If you prefer to fix this problem yourself,
To register the Wups2.dll file in Windows, follow these steps:
1. Stop the Automatic Updates service. To do this, follow these steps:
a. Open the Command Prompt window. To do this, click Start, click Run, type cmd, and then click OK.
b. At the command prompt, type the following command, and then press ENTER:
net stop wuauserv
2. Register the Wups2.dll file. To do this, follow these steps:
a. At the command prompt, type the following command, and then press ENTER:
regsvr32 %windir%\system32\wups2.dll
Note For a computer that is running Windows XP Professional x64 Edition, type the following command, and then press ENTER:
regsvr32 %windir%\syswow64\wups2.dll
b. Click OK if you receive a verification message.
3. Start the Automatic Updates service. To do this, type the following command at the command prompt, and then press ENTER:
net start wuauserv
4. Exit the Command Prompt window. To do this, type exit at the command prompt, and then press ENTER.
Jun 02, 2011 | Microsoft Computers & Internet
Update KB946140 and Error Code 646
Sometimes MS update has compatibility issue.Better no to install cause sometimes it can create a bug (Blue Screen Crash) to your system.Try to restore yor windows 7 to an earlier point and the error message gone.Also try to turn off your automatic update so that you can choose your update to be installed.
Nov 09, 2009 | Microsoft Outlook with Business Contact...
I cannot download the new windows updates-I get an error message 646 and cannot find out what that means
Try the following steps to install the update successfully.
Stop the services pertaining to Windows Update.
1. Click Start, click All Programs, click Accessories, right-click Command Prompt, and select Run as Administrator.
2. If you receive a notification from User Account Control simply click Continue.
3. At the command prompt, type the following commands and then press ENTER after each command.
net stop wuauserv
net stop bits
net stop cryptsvc
4. Please do not close the Command Prompt window.
Rename folders pertaining to Windows Update
At the command prompt, type the following commands and then press Enter after each command:
ren %systemroot%\System32\Catroot2 Catroot2.old
ren %systemroot%\SoftwareDistribution SoftwareDistribution.old
Start services pertaining to Windows Update.
net start wuauserv
net start bits
net start cryptsvc
Close the Command Prompt window.
Download the standalone package file of the update “KB967043”
and install it.
Visit the following link to download the update:
http://www.microsoft.com/downloads/details.aspx?familyid=628280fe-e035-4274-85f2-393d9bad543c&displaylang=en
Restart the computer once the update is installed.
Let me know if this worked.
Oct 15, 2009 | Microsoft Windows Vista Home Premium with...
142 people viewed this tip
David Payne
David Payne
