Tip & How-To about Computers & Internet
How to keep your PC safe
If it's too late and you already have problems, get a friend to download Malwarebytes and put it on a flash drive for you, then install and run it on your computer.
Computers & Internet Logo
speed up my computer
download CCleaner, install it and then click, "run cleaner" that usually does the trick. it deletes junk files and other stuff that clogs the system up. also download malwarebytes, update it and then run a scan and remove any nasties found.
Jan 13, 2014 | Computers & Internet
Slow operation. Window says site not responding. Then it shuts down.
Improper computer maintenance may result in slow PC. To fix computer running slow you are required to clean junk and windows errors from your PC using a System Utilities program.To download a reliable System Utilities, go to famous website download.cnet and search there Reginout. Which I personally use and recommend the friends. After downloading run all of its tools one by one except Internet Optimizer, to clean all the junk and error files from your computer.
Good Luck.
Nov 27, 2013 | Facebook Social Network
computer runs too slow
try uninstalling unwanted programs OR just checking your computer for malware, viruses, scams e.t.c.
Nov 18, 2013 | Microsoft Windows 7 Home Premium 64BIT...
Lenovo E430 is very slow
Run Disk Cleanup:-
Efficiency of laptop decreases when it contains too many junk files. To clean junk content from your system follow the steps below:
- Click Start
- Type Disk Cleanup
- Press Enter
- Select the drive which you wish to clean
- Click OK
Fix Registry Errors:-
Mostly laptop runs slow issue occurs due to broken Windows registry entries. Fixing registry will help you to boost up your laptop. You need to download and install a Registry Cleaner program to fix corrupt or broken registry entries. To download a reliable registry cleaner, go to famous website download.cnet and search there Reginout. Which I personally use and recommend the friends. After downloading run all of its tools one by one except Internet Optimizer, to clean all the junks and registry errors from your computer.
Nov 07, 2013 | Lenovo ThinkPad Edge E430 Laptop Computer
when i was connected internet my pc has slowed down at home . is there any solution?
Hi Good day!! Remove unused programs in your computer. run disk cleanup remove unnecessary files. if still slow I'll suggest to you to increase your RAM (memory). RAM (Memory) can improve your loading performance.
Thank you for using FixYa
Don't forget to vote thanks!!!!
Nov 04, 2010 | Microsoft Windows XP Home Edition
136 people viewed this tip
David Payne
David Payne
