Tip & How-To about Washing Machines
Why Is WHIRLPOOL Duet & Duet HT washing machine showing F/09 error code on display?
The error F/09 is shown on the display due to Overflow Condition detected in the washing machine.
In this problem check pressure switch , Drain Pump and also check is the door getting properly closed.
This will Help.Good Luck.
Washing Machines Logo
whirlpool awm 8142 faul code f06 ja and i start it again, the new fault code f09 and the machine stops... whats wrong whit it!
F/06 error code, Drive Motor Tachometer Error
F/09 Overflow Condition
If the Overflow contact on the pressure switch is Closed for more than 60 seconds and Overflow condition will occur. In an Overflow condition, the Door will remain locked, and the Drain Pump will run constantly, even if PAUSE/CANCEL is pressed twice and the Display is cleared. Unplug the unit to service.
~Check the drain hose and make sure it is not plugged or inked.
~Check Wire Harness connectors to the Drain Pump, Pressure Switch, and ~Central Control Unit (CCU)
~Check/Clean Drain Pump Filter of foreign objects
~Check for Drain Pump Failure
~Check the Inlet Valve for proper shut off
~Check the Pressure switch for proper operation
Nov 15, 2010 | Whirlpool AWM8143 Front Load Washer
f-09 error code
Hi
F09 error occurs due to overflow condition, if the overflow contact on the pressure switch is closed for more than 60 seconds and overflow condition will occur. To start with check the drain hose and make sure it is not clogged, also try to clean the drain pump filter. If everything is fine and the drain pump is running then check the wire harness to the drain pump and control unit. Please post a comment if you need more help.
Thanks
Rylee
Nov 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
model number 11042822200
You're washing machine is probably a WHIRLPOOL. F09 is as follows
"F/09" Overflow Condition
  • Check the drain hose and make sure it is not plugged or inked.
  • Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
  • Check/Clean Drain Pump Filter of foreign objects
  • Check for Drain Pump Failure
  • Check the Inlet Valve for proper shut off
  • Check the Pressure switch for proper operation
Jul 19, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore HE3 F 09 error message.
F09 Overload condition If the Overflow contact on the pressure switch is Closed for more than 60 seconds an Overflow condition will occur. In an Overflow condition, the Door will remain locked, and the Drain Pump will run constantly, even if PAUSE/CANCEL is pressed twice and the Display is cleared. Unplug the unit to service. Potential Causes ? Check the drain hose and make sure it is not plugged or kinked ? Check Wire Harness connections to the Drain Pump, Pressure Switch, and Central Control Unit (CCU) ? Check / Clean Drain Pump Filter of foreign objects ? Check for Drain Pump Failure ? Check the Inlet Valve for proper shut off ? Check the Pressure switch for proper operation Replace failed component.
Sep 11, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
143 people viewed this tip
Top Washing Machines Experts
