Tip & How-To about Washing Machines
Why Is WHIRLPOOL Duet & Duet HT washing machine showing F/06 error code on display?
The error F/06 is shown on the display due toDrive Motor Tachometer Error in the washing machine. The motorspeed is not getting detected by the control board in themachine.
This will Help.Good Luck.
Washing Machines Logo
F6 error code whirpool duet
The F6 error code for this model indicates a drive motor tachometer error. The control board is unable to properly detect the motor speed.
Jan 09, 2016 | Washing Machines
whirlpoool front end loader washing machine showing an f 06 error
The F/06 is:
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
The tech. should check these:
Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
Check the Drive Motor
Check the MCU
Check the Wire Harness
Nov 04, 2012 | Whirlpool Washing Machines
error code f 06???? anyone???
f 06 Drive Motor Tachometer Error (The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high speed spin, the door will be unlocked after 3 minutes.
* Check wire harness connections between the Drive Motor/Tachometer and the Motor control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
* Check the Drive Motor
*Check the MCU
*Check the Wire Harness
I got this information off a website after searching for a F 02 error.
May 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
whirlpool washing machine really loud
hi there,
error f06 means Drive Motor Tachometer Error
for this u may
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Dec 10, 2008 | Whirlpool AWM6100 Front Load Washer
147 people viewed this tip
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
