Tip & How-To about Washing Machines
WHIRLPOOL Duet & Duet HT washing machine shows F/02 error code on display?
This error is shown on the display due to:--
Drain time exceeding more then 8 minutes, the water valves will stop functioning and the the water valves turns off and "F/02" will be displayed on the screen.
NOTE: in some cases it has been noticed that 4 minutes the "Suds" error displays, and then 4 minutes later the F02 error displays.
This Will Help.Good Luck.
Washing Machines Logo
F21 code
F21 = Long Drain
If the drain time exceeds 8 minutes the water valves turn off. NOTES: ? After 4 minutes the "Sd" error will be displayed, then 4 minutes later the "F/21" error code will be displayed. ? Press STOP two times to clear the display.
Possible Causes/Procedure 1. Check the drain hose and make sure it is not plugged or kinked. 2. Unplug washer or disconnect power. 3. Check the electrical connections at the pump and make sure the pump is running. 4. Check the drain pump filter for foreign objects. 5. Plug in washer or reconnect power. 6. If the above does not correct the problem, go to step 7. 7. Unplug washer or disconnect power. 8. Replace the pump.
Jan 06, 2011 | Kenmore Washing Machines
what is F-21?
Hi
F21 error means that the drain time has exceeded 8 minutes; this will turn off the water valves. Error code SD means LONG DRAIN. This error appears when the drain time exceeds 8 minutes and the water valves turn off. After 4 minutes the "Sd" error will be displayed, and then 4 minutes later the F21 error code will be displayed. Press PAUSE/CANCEL two times to clear the display. Please Check the drain hose and make sure it is not plugged or kinked. If the drain hose if fine then unplug the washer and check the electrical connections at the pump and make sure the pump is running. Check the drain pump filter for foreign objects. To access the drain pump and filter remove the front kick panel and trace the drain hose to the bottom of the washer, drain pump would be located there. If you are not able to access it, then replace the back panel as well. Plug in washer or reconnect power. If the issue is still not resolved then you would need to replace the drain pump. Hope this helps... Please post back if you need more information.
Daniel
Jan 02, 2011 | Kenmore HE2 Plus Front Load Washer
what does F21 mean on the digital screen?
Hi
Error F21 means F21 error means that the drain time has exceeded 8 minutes; this will turn off the water valves. Error code SD means LONG DRAIN. This error appears when the drain time exceeds 8 minutes and the water valves turn off. After 4 minutes the "Sd" error will be displayed, and then 4 minutes later the F21 error code will be displayed. Press PAUSE/CANCEL two times to clear the display. Please Check the drain hose and make sure it is not plugged or kinked. If the drain hose if fine then unplug the washer and check the electrical connections at the pump and make sure the pump is running. Check the drain pump filter for foreign objects. To access the drain pump and filter remove the front kick panel and trace the drain hose to the bottom of the washer, drain pump would be located there. If you are not able to access it, then replace the back panel as well. Plug in washer or reconnect power. If the issue is still not resolved then you would need to replace the drain pump.
Daniel
Jan 01, 2011 | Kenmore Elite 45986 Front Load Washer
I cleaned the pump filter after getting sud error. now i get F 21 code.
Press the pause cancel button 2 times this should clear it. If it does not and the filter and drain hose are clear you will need to replace the pump.
F21 Fault Code Repair
LONG DRAIN
NOTES:
LONG DRAIN
NOTES:
LONG DRAIN
NOTES:
Nov 03, 2010 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
F02 Error message
57f1973.jpgUse a nutdriver (1/4th in) to get that bottom panel off.001354b.jpgaab6887.jpg
Jul 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
190 people viewed this tip
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
