Tip & How-To about Washing Machines
WHIRLPOOL Duet & Duet HT washing machine shows F/H error code on display?
This error is shown on the display due to:--
Water not getting detected while entering the washing machine or
The other possibility is that the Pressure switch is got tripped but its not getting detected.
This happens because in 30 seconds if the control does not detect water entering to the washing machine then the valves will be turned off and the error code will be shown on the display panel.
To solve this problem you will have to check the drain pump.is it properly fitted or got loose or worn out or leaking. Also check the pressure switch hose is in good condition and properly connected to Tub and Pressure switch.
This will help.Good Luck.
Washing Machines Logo
hf flashing on screen and beeping loud
H/F error is due to :-- No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
TO RESOLVE THE PROBLEM :
Press PAUSE/CANCEL twice to clear the display. globul1a.gif If there is no water in the unit:
1. Make sure that both valves at the water source(s) are turned on all the way.
2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
3. Verify inlet valve operation
globul1a.gif If there is water in the unit:
1. Verify Drain pump operation
2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
globul1a.gif Verify there is not a siphon problem globul1a.gif Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU) globul1a.gif Check all hoses for possible leaks globul1a.gif Verify pressure switch operation
globul1a.gif Verify flow meter operation globul1a.gif Verify CCU operation
May 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
155 people viewed this tip
Top Washing Machines Experts
