Tip & How-To about Cell Phones
Factory Reset for Tungsten T5 handhelds
If you've set a password on your device, any hard reset will automatically become a Factory Reset. With this method, you'll enter a password and then perform a hard reset.
1.On your handheld, launch the Prefs application. From the list that appears, under General, select Security.
2.If the Password box says "Unassigned," tap the box and create a password for your handheld.
3.Once the password has been set, hold down the Power (on/off) button on your device.
4.While holding down the Power button, turn over your device so that you can see the back of it. Still holding the Power button, use an unfolded paper clip or a similar small object to gently press the RESET hole (where?). Keep holding the Power button throughout.
5.While still holding the Power button, the screen will show the Palm logo and a progress bar will appear at the bottom. Then the circular Palm Powered logo will appear. Release the power button when you see the Palm Powered logo.
Keep holding the Power button during this screen. When you see this screen, you can release the Power button.
6.A message will appear warning that you are about to erase all the data stored on your handheld. Press UP.
7.You may see a screen that says "Reformatting in progress. This may take several minutes." This screen will remain for several minutes (up to 10 minutes). Don't do anything while this is happening.
8.If you performed this reset correctly, the screen of your device will go blank after several minutes, and you will not be able to turn on your handheld. The charging LED will not light up. (any other activity - such as the Palm OS logo and then the Applications launcher appearing - means the reset was performed incorrectly; try again)
9.Your device will appear "dead." To wake up your handheld, perform a soft reset.
Cell Phones Logo
screen locked and unable to unlock
Turn off . Press and hold POWER + ENTER button for reset menu.
Select
Factory reset with Volume Down button and press Power to reset. All data will be lost! there is an alternate method too friend
Use this method to hard reset your Samsung GT-S Galaxy mini phone: Enter *2767*3855#. Warning! All your data including contacts, messages etc. will be lost! Copy all your necessary data/Contacts/Messages etc. to SIM or make backup to your PC before full reset! Take out SIM card before full reset.
Samsung GT-S5570 Galaxy mini download mode if you want to install eg. Gingerbread
Press and hold Volume DOWN + HOME + POWER ON S5570
Restart your device to clear any temporary software bugs
If you know the hard reset with buttons / keys, pls leave a comment. All comments are welcome!
Your device freezes or has fatal errors
If your device freezes or hangs, you may need to close programs or reset the device to regain functionality. If your device is frozen and unresponsive, press and hold [Power] for 8-10 seconds. The device will reboot automatically.
If this does not solve the problem, perform a factory data reset. In Idle mode, open the application list and select Settings :Privacy
:Factory data reset :Reset phone : Erase everything.
Clear storageā€¢ : Erase the credential contents from the device and reset the password
Set an unlock pattern
Once you set a screen lock, your device will require an unlock code each time you turn it on or unlock the touch screen
Settings Location and security Set screen lock : Pattern
If you forget your PIN or password, bring your device to a Samsung Service Centre to reset it.
Set an unlock PIN code
Settings Location and security :: Set screen lock : PIN
Set an unlock password
Settings Location and security :Set screen lock : Password.
You can hard reset software firmware update your Samsung GT-s Galaxy mini phone
Hope it helps u
Dec 08, 2013 | Samsung Cell Phones
Is there a way I can revert my Palm Treo 650 back to original factory settings
Factory Reset for Treo 700p and 680 smartphones
If you've set a password on your smartphone, any hard reset will automatically become a Factory Reset. With this method, you'll enter a password and then perform a hard reset.
On your smartphone, launch the Security application.
2.If the Password box says "Unassigned," tap the box and create a password for your smartphone.
3.Once the password has been set, disconnect your smartphone from the AC charger and take off the battery cover. Do not remove the battery yet.
4.Hold down Power/End .
5.While holding down Power/End , remove the battery. Then insert it again.
6.While still holding Power/End , the screen will show the Palm logo and a progress bar. Then the circular Palm Powered logo will appear. Release the power button when you see the Palm Powered logo.
7.A message will appear warning that you are about to erase all the data stored on your smartphone. Press UP.
8.If you performed this reset correctly, the screen will go blank after several minutes, and you will not be able to turn on your device. The charging LED will not light up. (any other activity - such as the Palm OS logo and then the Applications launcher appearing - means the reset was performed incorrectly; try again) 9.Your device will appear "dead." To wake up your smartphone, perform a soft reset.
if u like plz comment
Mar 11, 2010 | Palm Treo 650 Handheld
115 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
