Tip & How-To about Cell Phones
Factory Reset for LifeDrive mobile managers
1.Move the Power switch to the On/Off position and hold it there.
2.While holding the Power switch, tilt your device so you can see the bottom (where the power and HotSync cables connect). Use the stylus to gently depress the RESET hole on the bottom right.
3.You'll see a screen that says "Warning Erase all data?" Using the 5-way navigator, press LEFT. Note: This is a special option that does not appear on the "Warning" screen.
4.Your mobile manager will take about 30 minutes to reformat the Program Memory and Internal Drive.
5.When finished, your device will take you through a series of screens to calibrate the digitizer and set the time and date.
Cell Phones Logo
how do i do a hard reset on a magellen maestro 4040?
  • 1 Slide the Magellan GPS unit's powericon1.png switch to the off position, if your GPS has a two-way slide-style switch. Hold the switch in the off position for 8 seconds or more to reset the device.
  • 2 Slide the switch to the reset position if your GPS has a three-way switch. These switches feature "Reset," "Off" and "On" labels. Hold the switch on the reset position for 10 seconds to initiate a reset.
  • 3 Inspect your GPS for a reset pin hole if the unit has a push-down power button rather than a switch -- check the bottom and sides of the device for a pin-sized hole. Insert a pin or a straightened paperclip into the hole, pushing until you feel a slight pop. Hold the pin or clip down for 10 seconds and the GPS will reset.
  • Read more: http://www.ehow.com/how_5635240_reset-magellan-gps.html#ixzz33LpAdUJE
    Jun 01, 2014 | GPS
    Performing a Standard Reset
    1. Slide the power switch all the way to the left (with the Nuvi's screen facing you).
    2. Hold the switch in the position for at least eight seconds.
    3. Push the switch to the right to power the Nuvi back on.
    Performing a Factory Reset
    1. Turn your Nuvi off by sliding the power switch to the left.
    2. Press your finger against the bottom right corner of the touchscreen. Hold your finger in this position.
    3. Slide the power switch to the right to turn the Nuvi back on. Continue to hold you finger against the screen until you see the factory reset prompt. Tap "Yes" to perform the factory reset.
    Good luck
    Sep 09, 2010 | GPS
    my view wont do anything, when i turn it on the only thing it does is turn the dial light blue, nohing else, when i plu it in, nothing. the blue light will stay on for however long the battery lasts, is there anyhting i can do to fix it?
    Solutions are in order of increasing probability of data loss AND device recovery.
    Screen messages are loose approximations
    A Soft Reset
    1. Hold Power switch up for 5 seconds.
    2. Screen displays "Goodbye".
    3. Restart
    B. Hard Reset
    1. Hold Power Switch for 30 seconds
    2. Restart
    C. Recovery Mode
    1. Hold Power Switch for 5 seconds to switch device Off
    2. Move switch to Hold
    3. Press and hold Home button
    4. Connect USB cable to device
    5. Screen displays "USB" in small type and "16 MB Format" shows up in My Computer
    6. Copy firmware files to "16 MB Format" drive letter
    7. Disconnect USB cable
    8. Screen displays "Firmware update"
    9. Restart device
    C. Force Format (This one wipes the data partition. Make sure all needed music/pictures/video exist elsewhere)
    3. Press and hold top/North/up of Scroll Wheel
    5. Screen displays "Format and lose data"
    6. Press right/East on Scroll Wheel to confirm
    7. Screen displays "Formatting"
    8. Restart device
    D. Manufacturing Mode (included for completeness only)
    3. Press and hold centre of Scroll Wheel button
    5. Windows detects a new hardware device
    6. ???
    7. ???
    8. ???
    Dec 27, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
    my sandisk mp3 is frosen on the meau and wont trun
    1. Push the "Power" switch downward into the "Hold" position.
    2. Press and hold the "Menu" and "Record" buttons at the same time until the device resets.
    3. Push the "Power" switch upward all the way to turn it back on.
    OR
    1. Grab a steady hold around the device.
    2. Push the "Power" upward and hold it there until it powers off.
    3. Power the device back on by releasing the power switch and then pushing it upward again.
    OR
    1. Unscrew the screws on the back of the device (or simply push the lid off if it is a model without screws.)
    2. Take out the batteries from the slot and wait until the screen goes black.
    3. Insert the batteries the same way they were mounted and attached the lid again.
    4. Push the power switch upward to turn on the device.
    Oct 01, 2009 | SanDisk Sansa e250 MP3 Player
    sansa e250 not working!
    Try this;
    Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
    http://rapidshare.com/files/67740173/e200fw01.00.12.exe____
    You need to put the device into "recovery mode" before you run the tool.
    - Turn the device off (hold power for 20 seconds)
    - Slide the hold switch into "hold" position.
    - Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
    Then run the recovery tool. Select format when prompted.
    Please RATE my solution at the bottom.
    Best of Luck.
    Nov 21, 2007 | SanDisk Sansa e250 MP3 Player
    122 people viewed this tip
    Top Cell Phones Experts
    Computer Repairing
    Computer Repairing
    William Alequin
    Are you a Cell Phone Expert? Answer questions, earn points and help others
