Tip & How-To about Cell Phones
Factory Reset for Palm TX handhelds
If you've set a password on your handheld, any hard reset will automatically become a Factory Reset. With this method, you'll enter a password and then perform a hard reset.
1.On your handheld, launch the Prefs application. Under General, select Security.
2.If the Password box says "Unassigned," tap the box and create a password for your handheld.
3.Once the password has been set, remove the stylus. Disconnect your handheld from the AC charger, if connected.
4.On your handheld, hold down the Power button.
5.While holding down the Power button, use the stylus to press the RESET button on the back of your handheld.
6.While still holding the Power button, the screen will show the Palm logo and a progress bar. Then the circular Palm Powered logo will appear. Release the power button when you see the Palm Powered logo.
Keep holding the Power button during this screen. When you see this screen, you can release the Power button.
7.A message will appear warning that you are about to erase all the data stored on your smartphone. Press UP.
8.You'll see a series of Palm logo screens, then a prompt to tap onscreen targets. The Factory Reset is complete.
Cell Phones Logo
need instructions on a hard reset
  1. While still holding the Power button, the screen will show the Palm logo and a progress bar. Then the circular Palm Powered logo will appear. Release the power button when you see the Palm Powered logo.
  2. A message will appear warning that you are about to erase all the data stored on your smartphone. Press UP.
  3. You'll see a series of Palm logo screens, then a prompt to tap onscreen targets. The Factory Reset is complete
Mar 03, 2011 | Palm TX Handheld
How do I reset my palm z22 to factory settings?
  1. On your handheld, launch the Prefs application. Under General, select Security.
  2. If the Password box says "Unassigned," tap the box and create a password for your handheld.
  3. Once the password has been set, remove the stylus. Disconnect your handheld from the AC charger, if connected.
  4. On your handheld, hold down the Power button.
  5. While holding down the Power button, use the stylus to press the RESET button on the back of your handheld.
  6. While still holding Power button, the screen will show the Palm logo and a progress bar. Then the circular Palm Powered logo will appear. Release the power button when you see the Palm Powered logo.
    887_palmlogo_progressbar.gif spacer.gif 887_poweredcircle.gif Keep holding the Power button during this screen. spacer.gif When you see this screen, you can release the Power button.
  7. A message will appear warning that you are about to erase all the data stored on your smartphone. Press UP.
  8. You'll see a series of Palm logo screens, then a prompt to tap onscreen targets. The Factory Reset is complete.
Apr 15, 2010 | Palm Z22 Handheld
Is there a way I can revert my Palm Treo 650 back to original factory settings
Factory Reset for Treo 700p and 680 smartphones
If you've set a password on your smartphone, any hard reset will automatically become a Factory Reset. With this method, you'll enter a password and then perform a hard reset.
On your smartphone, launch the Security application.
2.If the Password box says "Unassigned," tap the box and create a password for your smartphone.
3.Once the password has been set, disconnect your smartphone from the AC charger and take off the battery cover. Do not remove the battery yet.
4.Hold down Power/End .
5.While holding down Power/End , remove the battery. Then insert it again.
6.While still holding Power/End , the screen will show the Palm logo and a progress bar. Then the circular Palm Powered logo will appear. Release the power button when you see the Palm Powered logo.
8.If you performed this reset correctly, the screen will go blank after several minutes, and you will not be able to turn on your device. The charging LED will not light up. (any other activity - such as the Palm OS logo and then the Applications launcher appearing - means the reset was performed incorrectly; try again) 9.Your device will appear "dead." To wake up your smartphone, perform a soft reset.
if u like plz comment
Mar 11, 2010 | Palm Treo 650 Handheld
146 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
