Tip & How-To about Cell Phones
Factory Reset for Centro and Treo 755p
If you've set a password on your smartphone, any hard reset will automatically become a Factory Reset. With this method, you'll enter a password and then perform a hard reset.
1.On your smartphone, launch the Security application.
2.If the Password box says "Unassigned," tap the box and create a password for your smartphone. Press Applications to exit the Security application.
3.Now that a system password is established, we'll perform a hard reset to complete the factory reset. With the device face down, remove the battery door. Removing the stylus may make it easier to remove the battery for the next step.
4.Remove the battery. Then put the battery back in.
5.When the Palm logo appears, press and hold Power/End until the black status bar at the bottom of the screen fills and disappears, and then release Power/End.
6.If you performed this reset correctly, you should see a white screen with black text saying "reformatting in progress" (any other activity - such as the Palm OS logo and then the Applications launcher appearing - means the reset was performed incorrectly; try again). Your smartphone will appear to reset again after the "reformatting in progress" screen disappears.
7.When the Erase all data? prompt appears, press Up to confirm the Factory reset.
8.When the language selection screen appears, select the same language you selected for your desktop software. The Factory reset is now complete.
Cell Phones Logo
Is there a way I can revert my Palm Treo 650 back to original factory settings
Factory Reset for Treo 700p and 680 smartphones
3.Once the password has been set, disconnect your smartphone from the AC charger and take off the battery cover. Do not remove the battery yet.
4.Hold down Power/End .
5.While holding down Power/End , remove the battery. Then insert it again.
6.While still holding Power/End , the screen will show the Palm logo and a progress bar. Then the circular Palm Powered logo will appear. Release the power button when you see the Palm Powered logo.
Keep holding the Power button during this screen. When you see this screen, you can release the Power button.
7.A message will appear warning that you are about to erase all the data stored on your smartphone. Press UP.
8.If you performed this reset correctly, the screen will go blank after several minutes, and you will not be able to turn on your device. The charging LED will not light up. (any other activity - such as the Palm OS logo and then the Applications launcher appearing - means the reset was performed incorrectly; try again) 9.Your device will appear "dead." To wake up your smartphone, perform a soft reset.
if u like plz comment
Mar 11, 2010 | Palm Treo 650 Handheld
113 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
