Tip & How-To about Video Game Consoles & Games
Broken Xbox 360 Fix [How to Repair Xbox 360]
Most of the xbox errors can be fixed easily.So do not worry If your getting 3 red lights error,if xbox 360 game freezing, or issues with xbox 360 when connected to a wireless router.
Enabling the port numbers of your xbox 360 on wireless router and few other issues are difficult to fix without knowledge. For simple issues like physical connectivity and other stuff you can do it your self.
While using any gaming device like xbox 360 or ps3 software issues and hardware issues are very common. So its better to learn how to repair your xbox 360 permanently.
I was rolling through all of the options when I had an issue with my 360 Xbox, but i couldn't get the steps. since I collected very little information on online forums. We'll take a look at what seems to be the best way to fix xbox 360 issues (how to repair xbox 360). Instead of doing an experiments. Its always better to take help of xbox 360 Repair Guides.
The usual cost of the repair can be as much as $150 plus and difficult part is shipping and handling, Still they do not guarantee the resolution.
Xbox 360 Repair guide is very helpful to troubleshoot your xbox 360, Its a great way to learn more about xbox pc, Most interesting thing is anybody who is not technically skilled can follow this easily. It also saves money.
After going through xbox repair guide I feel I am a expert in handling my gaming device now. So fix all your 360 xbox problems
xbox 360 expert Guide download.
Video Game Consoles & Games Logo
xbox-360 elite lower right hand red flashing led light code error E73
If you get the Xbox 360 1 red light message, it means that the problem is either with the DVD drive, or with the hard drive.
Fortunately, the Xbox 360 1 red light message is not something that you should worry about. In order to identify which of the two drives the Xbox 360 1 red light messages is referring to, just look the code number that the screen displays. DVD drive errors are identified with the codes E64, E65 and E66, whereas hard drive errors are identified with codes E67, E69 and E79.
Once you identify which error the Xbox 360 1 red light message is pointing to, fixing it is really easy. The guide available at Fix-xbox360.info will tell you what to do in each case, as well as what to do in case you get any of the other Xbox 360 lights messages. Check it out.
Jan 17, 2011 | Microsoft Xbox 360 Console
i am having a problem with my xbox360. a single red light problem and also in game,picture gets blurred and pixels gets stretched....help
Jan 08, 2011 | Microsoft Xbox 360 Console
has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
help me fix my xbox 360
Hello, the xbox 360 has an internal memory which is not expandable. The screen freezing and 3 red lights issue is a common error for Xbox 360 consoles when experiencing a general hardware error. These are caused by the solders for the GPU and some internal components are failing thus likely making the console not to function. Try to contact MS Xbox support for it to be fixed, if out of warranty you'll gonna have to pay $99 for repair. Cheers!
May 13, 2010 | Microsoft Xbox 360 White Console
Need a fix for 3 red lights on xbox360
Can't fix it yourself unfortunately. It is a hardware issue. This company can fix it for you.
http://www.nexicore.com/xbox/index.html
Nov 19, 2009 | Microsoft Xbox 360 Console
853 people viewed this tip
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
