Tip & How-To about Washing Machines
Washing Machine Maintenance
Once a year you should take the time to give the washer machine that serves you so well a little bit of tender loving care. This bit of time may prevent you from having washing machine problems in the future. If you can prevent just one washing machine repair it will be well worth your time. While you are doing the preventive maintenance, you also can do a bit of washing machine cleaning as well.
Washing machines are not fun to fix, here are some things that will help you to prevent that emergency repair.
-Check the hoses on the back of the washing machine for cracks, rust or corrosion on the connecting fittings, blisters on the hoses, and or leaks.
-Cracks in the hoses are signs of a breakdown of the rubber and aging
-Blisters are a sign that the water is getting through the inner lining of the
hose
-If your have corrosion then you either had or have a leak
-If left go the hose may be very difficult to remove in the future
-Check that your washer is setting solidly on the floor and is level.
-Out of level and flopping washers can help to cause out of balance
banging, noise, etc.. leading to premature failure of the washer
-Check to make sure that there is no water that drips from the inside of the washer when it is off.
-Dripping water is a sign that the solenoid valve or water inlet valve is
starting to wear and not closing properly. Replace the valve before is fails
completely.
This also is a good time to run your washer through a cleaning cycle. There are different things to use to clean the washer. One of the good old “green” standby’s is plain old vinegar. Dump a cupful in the washer and run through a short cycle. Other cleaning solutions could include things like Clorox, or other household detergents. There also are commercial cleaning products for cleaning washer machines also.
By doing these things once a year you will help to make sure that your washer will give you the best service possible.
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no
http://www.fixya.com/support/r3867591-washer_troubleshooting_water_not
http://www.fixya.com/support/r3864434-washing_machine_door_jammed
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
Washing Machines Logo
what is a TLC?
Tender Love and Care.
Jan 09, 2014 | Cars & Trucks
I have a Hitachi WH 18 DFL cordless impact driver, which I love. I was doing a little bit of heavy drilling, and now the drill bit is stuck. The sleeve extends as if to release the bit, but the bit do
My guess is that the bit twisted a little in the bit holder so the steel ball is bound. If the collar moves you could try a slide puller on the bit and see if you can impact it out with the slide puller. Or you could take the bit holder apart. There is a retaining ring that holds it all together right on top. Pull that off and a washer, spring and the collar will come off. Becarefull to watch for the steel balls on the spindle. They WILL fall out! Now hopefully the bit will come out. If not it may need to be twisted in the oposite direction that it got stuck when you were using it to break it free. Hope that helps and good luck!
Jan 19, 2012 | Dewalt 18 Volt Compact Drill Kit
What are the cost od replacenebt batteries? The offf board has alreadtv been replaced under warrant it is only one year old AND USED VERY LITTLE IN THE HOUSE, IS IT A LEMON?
Did you purchase the chair or Medicare? This chair has small batteries that need tender loving care If you do not use it often you need to charge the chair at least once a week and always put it up fully charged. Once the batteries get weak then no chair charger will pick them up. Check with a local battery warehouse or similar supply store for 2 12/12 batteries. Hope this helps
Aug 16, 2010 | Pride Go Chair Travel Power Chair
Whirlpool Ultimate Care II Super Capacity Plus
BETWEEN THE MOTOR AND TRANSMISSION THERE IS A COUPLING THAT SERVES AS THE BELT PART # 285753A REPLACE THAT WILL SOLVE YOUR PROBLEM
Apr 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
5,367 people viewed this tip
Top Washing Machines Experts
