Tip & How-To about Audio Players & Recorders
How to watch Blu-ray movie on your HDTV
Blu-ray movies always provide people with outstanding visual and aural experiences, so you can imagine how wonderful it is to watch BD movies on your widescreen HDTV with your families sitting on the couch comfortably in your living room. Roughly, the ways people used to watching Blu-ray movies are various, and the straightest method is connecting a Blu-ray disc player to a HDTV for playback. However, People also have other solutions even though they have no Blu-ray player, including using an Iomega hard disk media player or a WDTV Media player, Popcorn Hour, Xbox 360, or other media players or devices as a medium, or using an external hard drive to store the BD files and then connect it to HDTV to watch the movies, or using the HDMI port or an S-Video cable to watch videos from PC to HDTV, etc.
Since Blu-ray movies have strict copy protections (AACS, BD+, region code), as well as these intermediates have their requested video formats, for example, some supports mpeg4, divx, and xvid, some supports AVI or WMV, and some supports MKV or others. It is essential to remove BD protections and rip Blu-ray to an appropriate format for playback on HDTV through these in-between devices. You may ask: "what is your method to do format conversion?" Well, the following paragraphs will shed some light on this question.
Software you will need:
Pavtube Blu-Ray Ripper
To find a step-by-step instruction in the following:
Step 1: Install and launch this program, and afterwards you can click "DVD Rom", "DVD Folder" or "IFO/ISO" icon to load your Blu-ray files.
Step 2: Select subtitle and audio track
Click on the pull down menu of "Subtitle", then all the subtitles in the BD movie will be listed out, including language and subtitle ID, you can select one according to your own needs.
Click the drop-down list of "Audio", and then all the info about audio tracks are shown clearly, including language, audio codec(turehd and dts master audio are both supported as well), stream ID, and audio channel, you can choose whatever you like to do conversion.
Step 3: Select output format
Click on the drop down menu of "Format" to select output format. Which one to choose is depending on the compatible formats of your media players or devices that you used to transfer BD files to your HDTV. For instance, if your player is capable of playback .m2ts files, you can choose "Copy"- "Directly Copy", and this option will keep the original quality of your BD content to full extent. If your device allows HD playback, and supports h.264 mp4 format, and then this one would be the correct selection for you. The rest can be done in the same manner.
Directly Copy:
H.264 HD Video .mp4:
Step 4: Set advanced settings
Please notice that this step is unavailable if you have chosen "Directly Copy" in Step 3. Click on "Settings" button, and then you will be able to adjust audio and video parameters including codec, aspect ratio, bit rate, frame rate, sample rate, and audio channels in the popup window as below. 5.1 channels are supported to keep the stunning surround sound of the BD movie.
Step 5: Click "Convert" button to start BD ripping
Once finished, the output files can be found out via clicking on "Open" button effortlessly, and then you can use your own ways to watch Blu-ray movies on your HDTV, such as connecting your PC to your HDTV via S-Video or HDMI cables, or adding them to your media players for playback on the HDTV, or whatever. Just Enjoy it.
For more: http://www.pavtube.com/blu-ray-ripper/
Can Acer Iconia Tab A700 play 1080p Blu-ray movies? Blu-ray to Iconia Tab A700-Rip Blu-ray movies for Iconia Tab A700 Convert Blu-ray Disc/ISO movies to MP4 for Iconia Tab A700 playback Summary: If you want to watch 1080p Blu-ray Disc/ISO movies on Acer Iconia Tab A700, you can try Pavtube Blu-ray Ripper or Blu-ray Ripper for Mac. Pavtube Iconia Tab A700 Blu-ray Ripper is the best Blu-ray to Iconia Tab A700 converter. Acer Iconia Tab A700 has a 1.3GHZ Nvidia Tegra quad-core processor, 1GB RAM, and either 32GB or 64GB of storage. Those specs alone make it a worthy contender among Android tablets but Acer is topping it off with a 10-inch, 1920 x 1200 resolution "IPS quality" panel. Question: Can Acer Iconia Tab A700 play 1080p Blu-ray movies? Answer: No, if you want to Blu-ray Disc/ISO movies on Iconia Tab A700, First, you need to know about what formats supported by Iconia Tab A700. Acer Iconia Tab A700 formats as below: Audio: MP3/WAV/WMA/eAAC+ player Video: XviD/MP4/H.264/H.263 player Then, you need to do is convert 1080p Blu-ray movies to Iconia Tab A700 support video formats with Pavtube Blu-ray to Iconia Tab A700 converter, here i recommend: "MP4 format". Below guide will present you a best way to watch Blu-ray movies on Acer Iconia Tab A700 buy using Blu-ray to Iconia Tab A700 Converter. You can download and install Blu-ray to Iconia Tab A700 Converter or Blu-ray to Iconia Tab A700 Converter for Mac. Step-by-step guide: How to convert/rip Blu-ray DVD movies to Acer Iconia Tab A700? Step 1. Run Pavtube Blu-ray Ripper as the best Blu-ray to Acer Iconia Tab Converter, and load Blu-ray/DVD movies from BD/DVD disc, BD/DVD folder, or BD/DVD IFO/ISO to the program. Step 2. Choose video format for Acer A700, click "Format > Android > Acer Iconia Tab A700 Video(*.mp4)". The preset profile is specially designed for Acer A700 and supplies Full-screen playback. Step 3. Settings friendly format for Acer Iconia Tab A700. Click "Settings" to do some adjustment. Click "Size" to input 1920*1200 as the output video size. Step 4. Click "Convert" to start rip Blu-ray DVD movies to MP4 for Iconia Tab A700 playback with the powerful Blu-ray to Iconia Tab A700 Converter. After conversion, you can transfer/stream the converted Blu-ray movies to Iconia Tab A700. Now, you can watch Blu-ray DVD movies on Acer Iconia Tab A700. http://www.foxreal.com/blu-ray-ripper/
Just buy or get ANY video converter, if pc to slow to run..
Jul 09, 2012 | Acer Iconia Tab A50010S32u Notebook
my BD530 player doesn't play all movies clearly. Some come cover good others re all snowy
When properly connected to a High Definition display or TV, Blu-Ray Disks (BD) should play crystal clearly. Inserting an old "non-Blu-Ray" disk (or the original "DVD") in the Blu-Ray player will display a comparatively "fuzzy" picture. This is the difference between High Definition and Standard Definition. A "BD player" can not "upgrade" the picture quality on DVDs to that of a BD or High Definition picture.
Rent, purchase or choose Blu-Ray Disks (BD) whenever a choice is offered to view the High Definition version of a movie or video. Selecting the DVD version will provide the lower quality or Standard Definition version of the same movie or video.
Check the covers or disk itself to determine if the movie or video is in DVD or BD format. That will tell you what you can expect for picture quality.
I hope this helps & good luck! Please rate my reply - thank you.
Mar 17, 2011 | LG Super Blu BH200 Blu-ray and HD-DVD...
Blu-ray to Android Phone Converter-Blu-ray DVD to HTC/Google/Motorola With Android phone on hand, have you ever thought of getting your Blu-ray disc movies and DVD disc movie to your Android phone, and then watch them any time as you like? With the new update of Aunsoft Blu-ray Ripper, it is no longer a hard task to take movies on your smartphone. Aunsoft Blu-ray Ripper, as a Blu-ray to Android phone converter, provides quick output profiles for you to choose according to your usage. No matter you are using Motorola Droid X, HTC Hero, Google Nexus One, Samsung Fascinate, HTC Legend, HTC Touch Pro, HTC Supersonic EVO or HTC Droid Incredible, you can find the related profile on the converter. Load Blu-ray/DVD movies: You can load Blu-ray disc or DVD movie directly from BD/DVD Rom, or Blu-ray file structure folder or DVD-Video file structure folder from computer hard drive to the convert for conversion. Load ISO/IFO for conversion: Directly load DVD ISO and DVD IFO to the Blu-ray to Android phone converter for converting to MP4 for your smartphone. With the help of Virtural Drive Pro, you can also convert Blu-ray ISO to Android phone. Rip disc main movie or extras for conversion: The Blu-ray to Android phone converter displays the main movie of the Blu-ray/DVD disc. You can convert the main title to play on your Android phone, or rip the extras for fun on your phone. Convert BD/DVD with forced subtitles: If your Blu-ray disc or DVD disc includes forced subtitles, you can choose to watch output videos with the related forced subtitle, since you are familiar with the language. It makes it more convenient for watching movies on Android phones with the wanted subtitles. Why choose Aunsoft Blu-ray Ripper as Blu-ray to Android phone converter? - One click to choose video for your Android smartphone. - Automatically remove BD/DVD copy protections like region code, ACCS, BD+, CSS. - Easy conversion for Blu-ray/DVD with forced subtitles. - Work on Windows XP, Windows Vista, Windows 7. (For Mac version, have a look at Mac Blu-ray to Android phone converter.) What's new? - Added output profiles for Android phones like Motorola Droid X, Google Nexus One, HTC Hero. - Support converting Blu-ray/DVD with forced subtitles. Download Aunsoft Blu-ray Ripper as your Blu-ray to Android phone converter, and you can make full use of your Blu-ray/DVD movies and watch them on Android phone freely.
Jul 19, 2010 | Cell Phones
230 people viewed this tip
 Grubhead
Grubhead
