Tip & How-To about Cell Phones
How to switch on your phone
Long press of switch ON button.
Cell Phones Logo
studio 166. How do I cancel toner display?
To erase the Toner symbol:-
Step 1:- Switch off the machine.
Step 2:- Press 0 and 8 buttons and switch on the machine
Step 3:- AD will appear on the display
Step 4:- Press 695 and then start button
A value either 1 or 0 will display
If it is 0 make it 1 and press interrupt button
If it is 1 make it 0 and press interrupt button
Switch off and on to check.
To erase the spanner symbol:-
Step 2:- Press 0 and 8 buttons and sitch on the machine
Step 4:- Press 251 and then start button
A value will appear on display
Press 0 now and then interrupt
Now AD appears on the display.
Press 252 and repeat the step 4
Press 253 and repeat the step 5
Switch off and on to sheck
Jan 05, 2016 | Toshiba Office Equipment & Supplies
how do you re program a replacement remote for the APS997A
To program remote; ignition on, press and release programming switch 3 times, you will hear one chirp( channel 1),press the lock button, press and release the switch 1 time ( two chirps, channel 2), press the unlock button, press and release switch 1 time ( three chirps) press green remote start button,press and release switch 1 time ( 4 chirps) press option button. Turn ignition off.Test
May 27, 2011 | Car APS997A Two-Way Remote Start and...
5BCR07P PROGRAMMING INSTRUCTIONS
Ignition on, press and release programming switch three times,you will hear one chirp ( channel1), press lock button on remote, press and release switch 1 time ( two chirps, channel 2) press unlock button, press and release switch 1 time (3 chirps), press green remote start button, press and release switch 1 time ( 4 chirps),press option button. Turn ignition off, test.
After pressing the corresponding buttons on the remote programming sequence above ,you should hear confirming chirps from the alarm.
Sep 29, 2010 | 5BCR07P Remote Replacement Transmitter for...
how to i turn off the service now light on a 03 vw golf
To reset the message displays, turn the ignition switch on. Press and hold the odometer reset button "A" located below the speedometer. Turn off the ignition while holding the button. "OEL" will display on the indicator. Press and hold the lower digital clock reset button "B" until five dashes appear in the display. If needed, press the odometer reset button until "IN 01" appears and then press the clock reset button until five dashes appear. If needed, press the odometer reset button until "IN 02" is displayed and then press the clock reset button until five dashes appear. To exit reset mode, turn the ignition switch on and when "IN 01" appears, turn the ignition switch off.
1. Switch ignition ON.
2. Press and hold odometer reset button below speedometer.
3. Switch ignition OFF and release odometer reset button. OEL will now
display.
4. Press and hold the lower digital clock set button or the analog clock set
button until five dashes (-----) appear in display.
5. If necessary, pree odometer reset button to proceed to the IN 01 display
(15,000 mile maintenence) and reset using the clock button.
6. If necessary, repeat procedure to reset IN 02 (30,000 mile maintenence)
display.
7. To end reset mode: switch ignition ON; when display IN 01 appears, switch ignition OFF.
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
Mar 19, 2009 | 2000 Volkswagen Golf
how to format phone memory N95?
Method:1
1. Switch off the phone.
2. Hold down the following three buttons: Green (call answer button, * button, and ‘3′ button.
3. While holding these buttons, press the power button and switch on the phone.
4. When the message ‘Formatting’ appears on the screen, release all of the buttons.
Method: 2 ( Hard Format)
2. Hold down *#7370# button.
Method: 3 Soft Reset
2. Hold down *#7780# button.
Jan 13, 2009 | Nokia N73 Cellular Phone
88 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
