Tip & How-To about Audio Players & Recorders
How to Reset Counter Canon i355 printer?
There are twomethods as follows :--
  • Method 1 : Manual for service mode
  • Unplug power cable from electric source and USB cable from computer.
  • Open the printer cover and hold power button.
  • Connect power cable to the electric source.
  • Close the printer cover then release power button.
  • Method 2: Manual for service mode
  • Turn off the printer. And disconnect the printer cable.
  • Press and hold the POWER button, turn on the printer.
  • The indicator LED should be green.
  • Press and release the RESUME button , the indicator LED should be orange.
  • Press and release the RESUME button again, the indicator LED should be green.
  • Release both buttons.
This will help.Good Luck.
waste ink absorber almost full
Hi there
You will need at some time to clean out the ink out of the pads, or it will make a big mess
Step 1: Manual for Service mode (1st method)
1. Unplug POWER and USB cables.
2. Open door, PRESS and HOLD the POWER button.
3. Connect the POWER cable.
4. Close door, then release POWER button.
5. Power ON your printer a usual (It should not blinking anymore)
Step 1: Manual for Service mode (2nd method)
2. PRESS and HOLD the POWER button,
3. Release the the POWER button
4. Power ON your printer a usual (It should not blinking anymore)
Step 2 : Software for Permanant (1st method)
1. Reconnect the USB cable and turn ON your Printer
2. Open "General Tools for iP1000",
http://www.printersiam.com/data/download/iP1500%20Service%20Tool.zip
All the Best Pineworks
Mar 11, 2010 | Canon Pixma iP6600D InkJet Photo Printer
it says that my absorber is full.what must I do?
Hi there
Mar 11, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Canon ip2000, waste ink absorber is full
Hi there
Mar 10, 2010 | Canon PIXMA iP2000 InkJet Printer
I keep getting message " waste ink absorber is almost full" where is this and how do I empty it?
I have checked your post and have found this problem for a similar canon that might help you:
"Here's the steps for reseting "Waste Ink Full" problem
http://www.printersiam.com/data/download/iP1000%20Service%20Tool.zip
3. Select (USB PORT)
4. Choose (SET DESTINATION 1)
It should be reseted already, but somehow it start blinking again if you ever unpluging AC POWER cable. So try the 2nd method by using ServiceTool for IP1500
Step 2 : Software for Permanant (2nd method)
2. Open "General Tools for iP1500",
4. Choose CLEAR WASTE INK COUNTER - MAIN
5. Choose CLEAR WASTE INK COUNTER - PLATEN"
Jun 27, 2009 | Canon PIXMA iP1600 Printer
canon pixma ip1000
I try this to my customer canon printer and it is working even i used only the step one method.
Here's the steps for reseting "Waste Ink Full" problem at iP1000
2. Open door of the printer, PRESS and HOLD the POWER button.
It should be working, coz my printer now now work normally
Apr 23, 2008 | Canon PIXMA Photo Printer
224 people viewed this tip
 Grubhead
Grubhead
