Tip & How-To about Audio Players & Recorders
How do you delete photos from Sansa e200 MP3 Player?
If you go into Windows Media Player, you have to change the Library option from Music to Photos and THEN go into the Sync tab - should now display photos instead of music.
Alternatively, you can double-click My Computer, double-click the icon of the Sansa, and find the images or picture folder - you may have to change your usb mode to msc in order to view this folder (don't forget to change it back later, or not all of your files will show up when you want them to). ONLY delete image files - if you delete system files, your mp3 player will become unusable.
Or, you can follow the method reccomended by your manual - the full user's manual is available from Sanidsk's website:
Delete Photos and Video
The photos are stored in 2 locations on your Sansa…My Album and
Thumbnails. The instructions below for deleting photos and video from your
player were created using Windows XP with Windows Media Player 11.
To delete photos from your Sansa, please execute the following steps:
1) Connect your Sansa e200 to your computer
2) Select Open device to view files using Windows Explorer on initial
connection
3) Click the drive containing your photos
4) Click on the photo folder.
5) Highlight and delete the photos stored in My Computer\Sansa
e200\...\Photo\My Album and My Computer\Sansa
e200\...\Photo\thumbnail\My Album.
This will help.Good Luck.
bought a gpx8gb digital media player for my daughter for christmas. I have downloaded her cd's into itunes library. Now how do I get those songs onto her media player?
Check to see that when you rip a music CD that your music is not copy protected. The RIP function in your Windows Media Player will allow you to convert the music CDs you have purchased into either an MP3 or a WMA format.
To adjust the copy protection setting on your ripped music files,
  1. Open the Tools tab at the top of your Windows Media Player.
  2. Select Options and then select the Rip Music tab.
  3. Choose the type of music file as well as the quality with which you would like to save the music. (Your GPX player has the ability to play music files in both the MP3 and WMA format.)
  4. Make sure to use MTP when transferring copy protected WMA files.
If you are using Windows Vista with Windows Media Player 11, you will need to follow these instructions.
Note: You will be able to download purchased/subscribed songs to the unit.
  1. Start Windows Media Player 11 and then connect your unit to your computer. If you have not set up synchronization between your computer and this device, the Device Setup Wizard starts.
  2. In Device Setup - Configure Sync, write a name for your mp3 player.
  3. Click Finish. The window closes and the Sync feature in the Player is displayed.
  4. From the left pane of this Sync feature, you can select from Playlists or Library and you will see the content of these folders in the center pane.
  5. Select the songs or entire albums from the center pane.
  6. Drag these songs or albums into the Sync List, which is the right pane of the Sync feature.
  7. Click the Start Sync button on the Sync List pane.
  8. Repeat steps 4-7 for any other items that you want to copy to your unit.
If you are using Windows XP with Windows Media Player 10, you will need to follow these instructions.
  1. Start Windows Media Player 10 and then connect your unit to your computer. If you have not set up synchronization between your computer and this device, the Device Setup Wizard starts.
  2. In the Device Setup Wizard, select Manual.
  3. Click Finish. The wizard closes and the Sync feature in the Player is displayed.
  4. Select the Library option. On the left pane select Sync List.
  5. From the left pane you can select All Music or My Playlists and you will see the songs located within these folders in the center pane.
  6. Select the songs from the center pane, and drag them to the Sync List.
  9. Good Luck, I hope this helps
  10. Please rate me, Thank you
Dec 09, 2009 | GPX MW3836 MP3 Player
HOW DO i DELETE WHATS ON MY WALKMAN AND i CAN'T OR DON'T KNOW HOW TO DOWNLOAD MUSIC
1. Plug the MP3 player into the USB port. Open Windows Media Player, which will recognize that the device is plugged in and register under the "Sync" tab at the top.
2. Click on the "Sync" tab and the library that is on your MP3 player will be displayed.
3. You can select individual songs or albums for deletion. Simply right click on the song or album to be deleted and scroll down to the "Delete" option.
4. After selecting "Delete," another window will come up which says "Are you sure you want to delete [title of song]?" There are two options at this point--you can delete from the library only or from the library and your computer. Select the one or the other and click "OK." The song will be deleted. The change will be displayed within the library onscreen.
5. When you unplug the player from the port, the library will adjust the files to reflect the change. The player will say "configuring library" or some other message to that effect. Once this has finished, the main screen will be displayed. Depending on the model of the MP3 player, there may be a message stating "library updated."
Oct 24, 2009 | Sony NWZ-E438F Digital Media Player
how to sync a 1tgb hard drive to windows media player. To all my music on it
Launch Windows Media Player. Point mouse pointer to any of the buttons (Rip, Burn, ...) Click the down arrow that appears under button. Choose More Options... Click Library tab and then Monitor Folders button. Add the drive letter and any folder paths on the external drive you want to be included when WMP locates music files.
Also, click Rip Music tab and then Change button under the title, 'rip music to this location'. Locate the folder on new drive where you want ripped music to be placed.
Oct 23, 2009 | Microsoft Windows Media Player
I just purchased a RCA flash mp3 player. I
2. Click on the "Sync" tab and and the library that is on your MP3 player will be displayed.
Oct 01, 2009 | SanDisk Sansa c140 MP3 Player
how do you delete photos?
connection
Feb 21, 2009 | SanDisk Sansa E280 MP3 Player
290 people viewed this tip
 Grubhead
Grubhead
