Tip & How-To about Audio Players & Recorders
How to link gpx mp3 player to pc?
1. Connect your ML648B to your computer with Windows XP or later.2. By default your computer will recognize ML648B as GPX MTP Device. (Wait for few seconds to a minute allowing your Windows computer to recognize and install necessary drivers for the device for first time as MTP Device.)
3. Press the POWER button from top of your ML648B, to change it to USB mode connection. You will also see USB on the screen of ML648B.(Wait for few seconds to a minute allowing your Windows computer to recognize and install necessary drivers for the device for first time as USB device.)
4. ML648B will now mount 2 drives, one as Tools (as CD-Drive) and second as Removable Disk (Drive) – under My Computer on your windows desktop.
5. Double click & open Tools, and run Setup.exe to start installing Video Conversion Software tool.
6. Select defaults options and finish the installation by clicking on Close or Finish.
7. If asked, click on Continue Anyway on Windows XP or Install this driver software anyway on windows vista.
This will help.Good Luck.
space on device.
If this problem occurs then your ML648B needs to be formatted.
2. By default your computer will recognize ML648B as GPX MTP Device. Press the POWER button from top of your ML648B, to change it to USB mode connection. You will also see USB on the screen of ML648B.
3. ML648B will now mount 2 drives, one as Tools (as CD-Drive) and second as Removable Disk (Drive) – under My Computer on your Windows Desktop.
4. Right click your mouse and then select the Format option. When the Format Removable Disk window appears select the Start button to start formatting your MP3 player.
-Tha Mp3 Doctor
Feb 10, 2009 | GPX ML648B MP3 Player
will not connect to my computer, shows zzz on screen
3. Press the POWER button from top of your ML648B, to change it to USB mode connection. You will also see USB on the screen of ML648B. (Wait for few seconds to a minute allowing your Windows computer to recognize and install necessary drivers for the device for first time as USB device.)
4. ML648B will now mount 2 drives, one as Tools (as CD-Drive) and second as Removable Disk (Drive) – under My Computer on your Windows Desktop.
7. If asked, click on Continue Anyway on Windows XP or Install this driver software anyway on Windows Vista.
Jan 23, 2009 | GPX ML648B MP3 Player
Error Installing Utilites Software
<!--[if !supportLineBreakNewLine]-->
<!--[endif]-->
Jan 15, 2009 | GPX ML648B MP3 Player
having problem adding this device to my computer
Dec 30, 2008 | GPX ML648B MP3 Player
unit doesn't link with pc
Dec 27, 2008 | GPX ML648B MP3 Player
268 people viewed this tip
 Grubhead
Grubhead
