Tip & How-To about Audio Players & Recorders
How to make songs play randomly on GPX ML638B MP3 Player?
Try this procedure as follows. When a song is playing, press the Menu button - select Play Mode - and take it off of Repeat. This will help.Good Luck.
only playing a few sec of the song and then going to the next song
your player is in the "intro mode" , to change this follow these steps.
  1. play a song and while the song is playing
  2. press the menu/mode button and then with repeat highlighted,
  3. press the menu/mode button again to enter the repeat settings sub-menu
  4. press the right/left keys to change and highlight the repeat setting from "intro" to the mode of your choice like "repeat all"
  5. press the menu/mode key to save your setting...
Since this is a free answer,please take the time to rate my response,thanks.
Oct 09, 2010 | Toymax Impecca MP-1825 MP3 Player
wont play the whole song
Sounds like the player is running in INTRO mode, only playing the first part of each song. To change playback mode, follow the steps as described below.
Switch the player ON and start music playback:
1. Press PLAY button to START music to play
2. Press PLAY button again to PAUSE the playback
3. Press MODE button to enter playback mode selection
4. Scroll with MODE button through selections
5. Press MODE button when selection REPEAT is in the display
6. Use MODE button to select from: Normal, Repeat One, Repeat
within current Folder (if any), Repeat Folders (if any), Repeat
All songs, Random Play back, and Intro
7. Press MODE button to confirm selection
May 02, 2010 | Element Electronics GC823 MP3 Player
How can I ''shuffle''my songs on sylvania's smpk4083 model?
The SMPK4083 can shuflle songs, selecting Random:
Follow next procedure:
In PLAYING mode, press M while playing music to enter
the selection menu screen.
Choose Repeat and press M to enter the Repeat menu screen.
Next go to Random using |<< / >>| buttons, while selected Random, press M to choose for random play.
Jan 23, 2010 | Sylvania Audio Players & Recorders
songs wont change
It is stuck on "Repeat One" - refer to p.23 of your user's manual -
You can set your player to play music tracks randomly (Shuffle All ) or repeatedly (Repeat One or
Repeat All ).
1. From the main menu, select Settings > Play mode.
2. Use the VERTICAL TOUCH STRIP to scroll up or down the options.
3. Press § to select an option.
4. Press § again to deselect an option.
While you are playing music you can see the following active play mode screen.
-Tha Mp3 Doctor
Oct 30, 2007 | Philips HDD1630 MP3 Player
samsung yp-u2j shuffle
Hold Down The M (Menu button) Scroll down to settings, select play mode. Exit out of he menu, press the user button until the squiggly cross with the A appears. Whalaaa you're in shuffle Mode. I hope this was a detailed solution.
Jun 14, 2007 | Samsung YP-U2JQB MP3 Player
143 people viewed this tip
 Grubhead
Grubhead
