Tip & How-To about Audio Players & Recorders
What is the reset procedure for Philips GoGear mp3 player?
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off.Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab.Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
philips gogear
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
-Tha Mp3 Doctor
Jan 31, 2009 | Philips GOGEAR SA6045 MP3 Player
phillips gogear will not work turn on and the pc dosnt even show its there
-Tha Mp3 Doctor
Jan 30, 2009 | Philips GOGEAR SA6045 MP3 Player
my philips gogear 8 GB media player won't take a charge or nothing
Make sure the hold/lock is not engaged.
Try a different USB port.
-Tha Mp3 Doctor
Jan 06, 2009 | Philips GoGear SA5285/37 Digital Media...
i cant get my computer to reconize my 4gb phillips gogear
-Tha Mp3 Doctor
Dec 14, 2008 | Philips GOGEAR SA6045 MP3 Player
how should i connect philips gogear mp3 player to the computer
Software is available from Philips website.
-Tha Mp3 Doctor
Nov 15, 2008 | Philips GOGEAR SA6045 MP3 Player
159 people viewed this tip
 Grubhead
Grubhead
