Tip & How-To about Cell Phones
Iphone tips
1) Get URL HintsIn Safari, you can press and hold any links in order to see the URL and site name of the link
2) Dismiss Keyboard Suggested WordTo dismiss the keyboard
suggested spelling of a word, you can tap on anywhere of the screen. You do not have to press “x” button at the end of the word.
3) Scroll to the Top of the PageWhen you are using iPhone applications you can automatically scroll to the top of the page by tapping on the “top bar”, which has the time, service bars and the battery information. In Safari, this will also brings up the URL addressbar as well.
4) Different Domain SuffixHold down the “.com” button, you can see a popup comes up with “.net, .edu and .org” buttons. Slide your finger from them and then release your finger to choose
6) Take Screenshots AnytimeYou can take any screenshots at anytime easily on your iPhone. First of all, press and hold the “Home” button and then click the “Sleep” button once. The screen will flash white and the screenshot will be stored in your camera roll immediately.
7) Save Images in SafariWhen you are browsing any web pages on Safari. You simply touch the image and hold your finger until a menu show up, select Save Image.The downloaded image is located under your Photo / Camera Roll.
8 ) Inserting a PeriodWhen you are typing on you iPhone, simply double tapping the “Space Bar” button at the end of a sentence, it will automatically insert a period followed by a space. It saves you a lot of time instead of pressing “124′ to get the numbers and symbols page where the period located in.
9) Alternative Way to Navigate ScreensYou can tab the bottom right or left corner to switch between different screens instead of swiping your finger across the screen.
10) Alternate CharactersHold down a letter on the keyboard, you can see popup comes up with various versions of the character.
11) Move Dock IconsJust press and hold any icons
on the screen, then drag them while they are shaking. You can put any 4 icons on your dock (grey bar at the bottom of your iPhone).
12) Fit-to-page Column, word and PictureWhen browsing web pages on Safari, you can double tap on a column, word or picture to fit it’s width to your iPhone’s screen.
13) Select Icon for Bookmarked WebpageWhen you are browsing a web page on Safari and add its icon to your home screen by pressing the “+” button and select “Add to Home Screen”. The icon is a screenshot of the page you were on. You can have a different icon by zooming in a particular item on the page. It can be the website’s logo or any picture.
14) Scrolling with Two FingersSome web pages contains separate text boxes with their own scroll bars. If you are trying to move around in one, you can scroll it with two fingers instead of one. That will let you scroll just inside the box and not affect the position of the entire page.
15) Maximize Battery LifeThere is a separate sensor situated right above the earpiece, that detects ambient light. The iPhone uses this sensor only once per session, just as you unlock the handset. But if you cover the sensor as you unlock the phone, you will trikc the handset into thinking it’s in a dark room, and it will power down the screen brightness. You can Also turn off bluetooth and WiFi if you don’t expect to use them for a while. You can also set email fetch time to “Hourly” or “Manually”, and turn the “Push” off in order to save energy.
16) Reset Your iPhonePress and hold the “Home” Button and the “Sleep” Button to Reset your iPhone. A white light will flash, the screen will shut off and then turn back on. Please keep holding both buttons until the screen turns back on.
17) Insert Punctuation QuicklyTo enter any punctuations while using iPhone keyboard, you can press and hold the “123′ button and slide your finger over to any punctuation button. And then the punctuation will be inserted after you have released the button.
18) Get a Bigger KeyboardWhen you are using the on-screen keyboard on Safari, you can rotate the iPhone horizontally before tapping on the address bar, the Safari window will switch to horizontal mode. Now you can have a much larger keyboard, making data entry a little easier.
19) Changing iPod IconsBy the default, the buttons at the bottom of the iPod scren are “Playlists”, “Artists”, “Songs”, “Videos”, and “More”. You can change them by pressing the “More” button, and then tap on the “Edit” button in the upper left corner. A Configure screen will appear with icons for “Albums”, “Podcasts”, “Audiobooks”, “Genres”, “Composers”, “Compilations”, “Playlists”, “Artists”, “Songs”, and “Videos”. To substitute one of these icons for one that appears at the bottom of the iPod screen, just tap and hold on the icon you prefer and drag it over the icon you want to replace. Tap on Done when you’re finished
20) Make a Call from SafariIf you find any phone numbers in Safari you would like to call, you do not need to jump to the phone component. Just tap on the number, and the iPhone will dial it for you immediately
Cell Phones Logo
How to unlock the lock screen on my HP
To unlock the lock screen on your HP desktop running Windows 8.1, you can follow the steps below:
1. Swipe in from the bottom edge of the screen to dismiss the lock screen. Alternatively, you can also press any key on your keyboard to dismiss the screen.
2. In the sign-in screen that comes up, you can sign-in to your computer using the method of your choice.
To know more about this, you can refer to the link below:
http://windows.microsoft.com/en-IN/windows-8/lock-unlock-pc
GuruAid.com
Oct 18, 2014 | Computers & Internet
Ipod trick and tips Through using your iPod Touch you invariably pick up little tricks to get things done quicker, or make life easier. Or maybe a cool unknown feature. 1. If you're scrolling through a long document/page in Safari - if you tap the bar at the top of your screen containing the time and battery, Safari will automatically scroll up to the top of the document/page and the show address bar. 2. Turn off WiFi and SSH (using Services from Installer) to save battery power when not in use. 3. Double clicking the home button in any application, or with the screen off will bring up the music controls. 4. Make sure to completely close apps when you are done with them to save battery power. This is accomplished by pressing and holding the home button for approximately five seconds. This boosts battery life big time if you run lots of different apps all the time. 5. Holding down letters on the keyboard will pop up the accents/symbols associated with those letters. Once it pops up, slide your finger over to the accent/symbol you like. 6. Whilst in Mail's inbox view, sliding your finger from left to right on a message the 'delete' button will appear. This also applies in the list view of the Videos application. 7. In Safari double tap to zoom in. You can also "pinch" (putting your thumb and index finger on the screen and pinching in and out) to zoom in Safari and in Pictures. 8. You can charge your iPod Touch from any powered USB port. Such as a computer, printer, media centre. The device does not have to have iTunes installed to provide power to your iPod Touch. 9. Need a spare cleaning cloth for your touch, or an extra cloth to rest your iPod touch on while at work or school? Just go to your local vision care store (or pharmacy) and get an eyeglass/sunglass "cleaning cloth". Cheap and works great! 10. When watching a video, tap to bring up the onscreen controls. When you are done watching a video make sure you press done so your progress will be saved. 11. If you want to set a picture as a permanent background (and not only in the "wake" screen) Set the picture as a background in settings or directly from the picture gallery then off the theme wallpaper in the SummerBoard settings. 12. When typing a lot of text in Safari turn it to horizontal view. The keyboard will be bigger and you can get a better grip of the Touch while typing with two thumbs. 13. When typing if you want to add something from the numbers keyboard just hold down the numbers and slide your finger to the number or symbol you want, and release. It will take you back to your letters keyboard. This way you dont have to tap numbers, tap your number, then tap numbers again to go back. This also applies for using the 'shift' key to apply capital letters. 14. When in Safari, if you are presented with a link, hold your finger over the link, and a bubble will appear showing the URL that the link is tied to. 15. In Safari since you can't open links in a new windows, you can open a new page, tap the bookmarks icon, tap the history folder and direct yourself to the last page you were just on and tap the link from there. 16. When listening to an audiobook, iTunes and your iPod create a new chapter list unrelated to the subject of the book. It's accessible using the same control used for viewing audio tracks (upper right of screen). 17. Make a spelling mistake? Press and hold the word you spelt wrong and a magnifying glass will appear. Slide your finger back and forwth to move the cursor. 18. When you're on a website that has a frame or an iframe with scrollbars in it, use two fingers on that frame to scroll that window and back to a single finger to scroll the whole page. 19. When typing, if you press the space bar twice after a word it will insert a period and another space. 20. If you wish to use the professional ipod video converter,go to this site http://www.wmatomp3-converter.com/media-to-ipod-converter.html#135 I?v all through used it for many yrs,Steady and legal .
Dec 17, 2008 | Apple iPod touch
I can not get to the router - the ip address(192.168.0.1) will not come to the web browser - i am on a mac book pro - have tried in Safari and Firefox have tried on the pc as well. HAve reset router and separate modem - can you help?
If the default password has been changed then -
To reset the D-Link back to the default settings -
Press and hold the RESET button at the back of the router with the power ONuntil the LEDs flash at the time the release the RESET button.
Connect a LAN cable from the D-Link to your computer's LAN port, open a browserand enter the D-Link's configuration URL. OR open the browser on your laptopand enter the D-Link's configuration URL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter)
You can now configure the wireless settings.
Mar 20, 2011 | D-Link AirPlus Xtreme G DI-624 Wireless...
I can't log on to change my wep password or name my wireless router name
Press and hold the RESET button at the back of the router with the power ON until the LEDs flash at the time the release the RESET button.
Connect a LAN cable from the D-Link to your computer's LAN port, open a browser and enter the D-Link's configuration URL. OR open the browser on your laptop and enter the D-Link's configuration URL..
http://192.168.0.1
You can now go to the wireless settings.
Feb 25, 2011 | D-Link AirPlus Xtreme G DI-624 Wireless...
url blocking on dfl-200
Hi Mohan143,
Zupertails here,
you probably overlooked one small thing.
In order to actually activate the blacklist, you need to add a rule in The Firwall, LAN->Wan filter.
1) Just add a new filter, name it what you want.
2) In 'Action' select 'Allow'
3) In 'Service' select 'http-outbound'
4) Click The green Apply icon
5) Click the Yellow Apply button right
6) Click 'Activate changes'
7) Wait a couple of seconds and click on the activation link
tadaah
Jan 05, 2008 | D-Link NetDefend DFL-200 Firewall
439 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
