Tip & How-To about Office Equipment & Supplies
How to perform cold reset on HP 2200 printer?
Cold reset: 1. Turn the printer power off.
2. Press and hold GO.
3. Turn the printer power back on and continue to hold GO until the Attention light turns on.
4. Release GO.
5. The device lights will begin cycling from front to rear. The cold-reset process will run until completion and the device will go to the ready state.
This will help.Good Luck
Cannot connect to network. It show IP address 0.0.0.0
contact your service provide for assistance on how to set it up
Apr 28, 2015 | HP LaserJet P2015n Printer
When printing, lines are not evenly aligned. This is a recent problem as the printer has worked beautifully for years. Is there a way I can adjust this?
Try reset your printer by following this procedure to reset it,
1. Without turning the unit off, unplug the power cord from the back of the product.
2. Press and hold # and 6 keys.
3. While holding those keys plug the power cord back in.
4. Wait until the screen goes blank before you release those keys.
5. Follow on printer screen instructions.
Or
4. Release GO.
5. The device lights will begin cycling from front to rear. The cold-reset process will run until completion and the device will go to the ready state. This should fix the problem.
Sep 16, 2011 | HP PSC 1210 All-In-One InkJet Printer
13.20 error problem
Or
4. Release GO.
Sep 16, 2011 | HP LaserJet P4014n Printer
error 51.2 y hp color laserjet 4600
Hi There, Please follow the below steps to fix this issue :
Action : 1. Press the green (Select) button to continue. 2. Turn the printer off, and turn it on again.
3. Perform a cold reset : a.Turn on the printer. b.Watch the control panel. c.When the memory starts counting, press and hold the (Select) button. d.Continue holding the (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady. e.Release the (Select) button when the Ready, Data, and Attention light are on steady. f.The control panel will display SELECT LANGUAGE . g.Press (Down Arrow) button once. The control panel will display COLD RESET . h. Press (Select). The printer will perform a cold reset and then continue its power-on sequence. 4. If this message persists, contact an HP-authorized service or support provider.
Nov 08, 2010 | HP LaserJet 4600dn Color Printer
hp deskjet 5552 how to reset?
HP LaserJets - Cold Reset Instructions Cold resetting a printer resets the printer to factory defaults. Please note: Any settings you make at the printers control panel will be reset to factory defaults, including the IP address if you have a JetDirect card installed. Remove the JetDirect card while you cold reset the printer if you don't want to erase the JetDirect card's settings.
You can also reset the NVRAM. Resetting the NVRAM will clear the page count and reset the service mode settings to factory defaults. On printers with a display panel you need to enter service mode to manually change the information stored in NVRAM. On printers that don't have a display panel, such as a 5P, 6P, 2100, 2200 there is a different procedure outlined below.
"Older" printers with a display panel. (e.g. 4000, 4100, 5si, 8000, etc.)
Cold resetting the printer is simply a matter of turning the power off, holding down the GO or Online button while turning the printer on.
Resetting NVRAM settings must be done manually through service mode. See entering service mode.
"Newer" printers with a display panel. (e.g. 2300, 2400, 4200, 4250/4350, 4300, etc.)
Turn the printer off and then on. When the printer begins its memory count, press and hold down the Checkmark button until all the main LED signal lights illuminate and stay illuminated. Then release the Checkmark button, and use the Up/Down arrow keys to find the Cold Reset option, then press the Checkmark button again to choose that option.
Printers with no display panel.
HP 1100, 1200 - While the printer is on, press and hold the Go button for 5 seconds. This will reset the printer.
To reset the NVRAM. Turn the printer off. Press and hold the Go button for 20 seconds while powering on the printer.
HP 2100 - To perform a cold reset, turn the printer power off, then press and hold the JOB CANCEL button. Turn the printer power back on and after all the LEDs come on release the JOB CANCEL button. A cold reset changes most system parameters in NVRAM to the factory defaults. The JOB CANCEL button must be released within 20 seconds after all of the LEDs come on; otherwise, an NVRAM initialization is performed instead of a cold reset.
HP 2200 -
Cold reset:
4. Release GO.
NVRAM Reset:
3. Turn the printer power back on and continue to hold GO until the Attention, Ready, and Go lights turn on.
4. Release GO.
5. The device lights will begin cycling from font to rear. The NVRAM initialization will run until completion and the device will go to the ready state.
HP 5P & 6P
Cold reset:
Turn the power off and hold the reset button (button closest to the back of the printer) for LESS than 20 seconds while turning the printer on.
Reset the NVRAM:
Turn the power off and hold the reset button for MORE than 20 seconds while turning the printer on..
Dec 02, 2008 | HP DeskJet 5550 InkJet Printer
222 people viewed this tip
k24674
jasbo
jasbo
