Tip & How-To about Office Equipment & Supplies
How to reset Canon MP600 printer to the factory settings?
1. Press the HOME button.2. Use the Easy-Scroll Wheel or the right / left arrow to select [Settings], then press the button.
3. Use the Easy-Scroll Wheel or the right / left arrow to select [Device settings], then press the button.
4. Use the Easy-Scroll Wheel (B) or the up / down arrow to select [Reset settings], then press the button.
5. Use the Easy-Scroll wheel or the up / down arrow to select [Yes] on the confirmation screen and then press .
6. Press the button to return to the HOME menu.
This will help.Good Luck
i have a canon MP600 printer and the language has changed and i can't read it now and do not no how to change the language back to english
Jun 22, 2011 | Computers & Internet
playstation 3 bluetooth to canon pixma mp 610 printer
Issue: How do I access / change the bluetooth settings on the printer?
Solution: Change the machine settings (MP610)
Change the machine settings Instructions to change the settings on the machine. Displaying each setting screen
  1. Press the <HOME> (A) button.
  2. Use the Easy-Scroll Wheel (B) or the right / left arrow to select [Settings], then press the <OK> button.
  3. Use the Easy-Scroll Wheel (B) or the right / left arrow to select [Device settings], then press the <OK> button.
  4. Use the Easy-Scroll Wheel (B) or the up / down arrow to select the item to set, then press the <OK> button.
    < 1 > Print settings
    < 2 > Wireless print settings
    < 3 > Bluetooth settings
    < 4 > PictBridge settings
    < 5 > Other settings
    < 6 > Language selection
    < 7 > Reset setting
  5. Use the Easy-Scroll Wheel (B) or the up / down arrow to select the applicable one from the list, then press the <OK> button.
Print settings
< 1 > Prevent paper abrasion
Use this setting only if the print surface becomes smudged.
Note: When continuing to print with this setting, excess ink may smear inside the machine. After printing is completed, return this setting to OFF.
< 2 > Extended copy amount
Select the amount of image that extends off the paper when printing in borderless.
Note: When setting LARGE, more amount of the edges of an image is reduced.
Apr 28, 2008 | Video Game Consoles & Games
how do i reset canon mp540 printer?/disable ink monitoring levels?
These are instructions for the Pixma mp560 printer, I couldn't find the mp540 printer on the canonusa.com website.
I do not know how to disable ink monitoring levels.
Default Settings Instructions to change the machine back to its default settings.
  1. Press the <HOME> button.
  2. Use the Easy-Scroll Wheel or the right / left arrow to select [Settings], then press the <OK> button.
  3. Use the Easy-Scroll Wheel or the right / left arrow to select [Device settings], then press the <OK> button.
  4. Use the Easy-Scroll Wheel or the up / down arrow to select [Reset settings], then press the <OK> button.
  5. Use the Easy-Scroll wheel or the up / down arrow to select [Yes] on the confirmation screen and then press <OK>.
  6. Press the <HOME> button to return to the HOME menu.
Note: Changes the settings back to the default (factory settings), except for the language for LCD messages and the position of the print head.
Aug 21, 2010 | Canon PIXMA MP540 All-In-One InkJet...
install the correct print head
You can clear the errors in your printer in three reset procedures.
Reset it manually
1. Turn off the printer
2. Press and hold the Resume Button, an indicator light green
3. Press and hold the Power button
4. While holding the Power button, release the Resume button
5. While holding the Power button, press the Resume button twice
6. Release the Power button
7. Press the Resume buttons four times
8. Press the Power button to confirm the operation
9. Turn off the printer
Reset canon mp600 to factory setting (if the first procedure did not work)
1. Press the Home button
2. Use the Easy-Scroll Wheel or the right/left arrow to select Settings, and then press OK button.
3. Use the Easy-Scroll Wheel or the right/left arrow to select Device settings, then press OK button.
4. Use the Easy-Scroll Wheel (B) or the up/down arrow to select Reset Settings, then press the OK button.
5. Use the Easy-Scroll Wheel or the up/down arrow to select Yes on the confirmation screen and then press OK
6. Press the HOME button to return to the Home Menu
Final reset (If errors did not clear and or another error appears this will clear it)
1. Press and Hold the Resume button and wait until the printer self restart.
2. Release the Resume button when the printer restart
3. Wait until the printer fully initialize and try printing again.
That will solve it.
Please comeback and give some ratings.
thank you for using Fixya.
Aug 18, 2010 | Canon PIXMA MP600 all-In-One InkJet...
i want to connect via a bluetooth bu20 a canon pixma mp610 printer to a playstation 3. the ps3 recognizes the printer but will not rgister the passcode. I am caught between sony and canon. can you help.
    < 7 > Reset setting
Print settings
699 people viewed this tip
k24674
