Tip & How-To about Video Game Consoles & Games
How to hack a psp without pandora ?
Since ChickHEN is out PSP-2000 owners with a TA88v2 or less or a TA90v1 motherboard now have the option to now install Custom Firmware without the need of a Pandora battery.We have put together a Easy installer that contains everything you’ll need. Hellcats Recovery flasher, ChickHEN, PSP firmware update 5.00.
Warning make sure you only try this on a PSP that will accept PSP Custom Firmware flashing (Custom IPL) otherwise you will brick your PSP!!! PSP-3000’s will not take CFW. Check your PSP will take CFWhere. Or run ChickHEN first, then when ChickHEN is loaded run PSPident from the Game XMB menu. (PSPIdent with install with this easy installer)
Steps to install CFW on a PSP Slim without a Pandora battery.
1. Check and triple check you have a hackable PSP that will accept
custom firmware flashing without resulting in a BRICKED PSP. Make sure you have a PSP with a TA88v2 or below only + or TAv90v1. If your PSP has a TA88v3 or above or is a PSP-3000 DO NOT proceed!!! You will brick your PSP.
Run the installer and point it to your Memory stick Pro Duo root.
2. If you don’t have don’t have PSP firmware 5.03. Get that here: PSP Firmware 5.03 Make a folder called UPDATE in your PSP/GAME folder and place the eboot in there on your memory stick pro duo.
3. Now lets run ChickHEN to have a homebrew enabled environment. In your PSP go to photo then click the ChickHEN photo and wait. If the PSP jams, please retry. If it flashes colours and reboots you have loaded ChicKHEN. Check your system info to be sure it say’s 5.03 ChickHEN R2. If you need help getting ChickHEN to run please visit this post.
4. Now with your PSP rebooted in ChickHEN go to your PSP XMB game menu and run Hellcats Recovery and install 5.00 M33!!! Your PSP will reboot, follow the instuctions to install PSP Custom Firmware 5.00 M33. After your done you can update to 5.00 M33-6
Easy ChickHEN CFW installer (Without Pandora) (27.9 MiB,)
visit www.newzgadgets.co.nr
Video Game Consoles & Games Logo
how to download a firmware 5.55
If you're referring to Official S0ny Firmware, it's in your PSP menu. You should connect your PSP to internet to do this update. It's a guided procedure so you would not have difficulties in doing so.
If you're planning to install ChickHen and Custom Firmware to your PSP to play Homebrew games, think twice. You should know the consequences of possibly "Bricking" your PSP. Things to put into consideration are (a) Your PSP version, some 200 series and the all 3000 SHOULD not be installed with CFW because they cannot be fixed once bricked. (b) Your MotherBoard version, if you have PSP 2000, make sure that your MoBo is lower than TA088v3. If not, DO NOT try ChickHen. Just a warning though.
May 30, 2011 | Sony PlayStation Portable (PSP) Console
How to chicken?
Hello there Sir/Madam! My name is Alex and I work under FixYa.com expert team surveillance.
Firstly make sure your PSP-3000 or TA88v3 PSP-2000 has PSP Firmware 5.03 installed. Check in your PSP XMB go to Settings/ System Settings / System infomation. If you don't have PSP 5.03 installed download it here. Create a folder called UPDATE in PSP/GAME on your memory stick and place the eboot from the archive into the folder. Run the 5.03 Firmware update from GAME / Memory stick and you will have 5.03. The firmware required to run ChickHEN.
Now download the ChickHEN R2 release from here. Open the CHickHEN R2 archive and place the folder inside Slim with gif images into your PSP memory stick location like so PSP/PHOTO (later it will be PSP/PHOTO/ChickHEN). Now place the h.bin into the root of your memory stick pro duo. Where the folders PSP, MUSIC etc are located.
Ok next step place the memory stick into the PSP. We have found this step helps ChickHEN boot with less attempts, go your PSP XMB, to settings and Restore Default Settings. Your PSP will reset, now go back into settings and turn off UMD Auto-Start and UMD Cache. We found ChickHEN loads in 2-3 goes after doing this.
Now go into Photo / Memory Stick and ChickHEN. And wait, you will see five egg giff images, these will start to load thumbnails. Your PSP may freeze and reset. Just keep retrying and ChickHEN R2 will load up....But if you see flashing colors, your PSP will reboot into ChickHEN your homebrew ready!
With ChickHEN R2 loaded now starts the fun part. (P.S You can put your PSP into standby now so you don't have to go through the whole process again)
Hope this helped and/or advised you on your next move.Please rate my solution, thanks in advance. Wish you good day
Adzic A.
May 09, 2011 | Sony PlayStation Portable (PSP) Console
which softwareis used to install games from internet to psp
you need chickhen and a custom firmware to be able to install games in the psp. here is how to install custom firmware http://www.fixya.com/support/r7119752-install_cfw_5_03_gen_c_9_full_psp
Dec 23, 2010 | Video Game Consoles & Games
465 people viewed this tip
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
