Tip & How-To about Computers & Internet
How to print a printer test page from Ubuntu?
The procedure is as follows:-- 1. Go to system > Administration and Printing2. Right click on your printer and select its properties.
3. Click on the "Print a Test Page" button. You will get a printer test page that includes the Ubuntu logo and eight different color bars.
Computers & Internet Logo
how to reinstall?
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer driver software- if you dont have the driver download from the HP site- and then connect the Printer to be detected as a new hardware and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken .
Mar 24, 2011 | HP LaserJet 1300 Printer
the document cannot be printed due to a system
To resolve the issue, follow the steps below.
1. Right-click on My Computer, and select Properties.
2. Click on the Advanced tab.
3. Under Performance, click Settings.
4. Click the Data Execution Prevention tab.
5. Select the Turn on DEP for all programs and services except those I select: option.
6. Click Add....
7. Browse to C:\WINDOWS\system32\spool\drivers\w32x86\3\hpzeng07.exe and click Open.
8. Click Apply.
9. Click OK, and OK again.
Nov 12, 2009 | HP DeskJet 3320 InkJet Printer
My printer will not print. it is a z611 lexmark. it says its communicating, but it will not print. the documents are in the printer queue.
try to check if you have connected properly your printer cable into your computer. check if you are using the right port in the printer configuration .
If you are using a windows xp system.
Check the printers and faxes control panel .
then
right click and click properties.
You can see a panel there in which you can set the default port you are using..
Aug 29, 2009 | Lexmark Z611 InkJet Photo Printer
printer says "offline"
Plerform the following steps:
1. Right click on the Printer icon (Start-> Printers and faxes)
2. Select the option "Use Printer online".
3. Also select "Set as default printer".
if the issue persists, perform the following:
Note: Unit should not be connected to the computer.
1. Click on "Start" and select "Printers and Faxes".
2. Right-click on the DeskJet F380 All-In-One Printer printer and select "Delete" option.
3. Click on "File" in the menu bar and select "Server Properties".
4. Click on the "Drivers" tab.
5. Highlight the entry related to the DeskJet F380 All-In-One Printer printer and click on "Remove" button.
6. Click on "apply" the click "OK".
7. Restart the computer.
8. Reconnect teh printer.
9. "Found New Hardware" Wizard appears on the screen. Follow the onscreen instructions and complete the setup.
Jun 27, 2009 | HP DeskJet F380 All-In-One Printer
printer properties page displaying arabic tabs printer properties page displaying arabic - everything is okay, in english
Follow the procedure :-
Printer printing in different language
1. Go to the Start Menu
2. Go to Printers and Faxes
3. Right Click on the printer
4. Go to Properties
5. Select the Advanced Tab
6. Click on New Driver
7. The add printer Driver Wizard will come up
8. Click next
9. Click on have Disk
10. Click on browse to locate the disk
11. Cliclk OK
12. Reinstall driver from the English folder in the printer disk. (you will need the printer disk)
Thanks for using Fixya.
Apr 16, 2009 | Konica Minolta Di1610 Copier
712 people viewed this tip
David Payne
David Payne
