Tip & How-To about Office Equipment & Supplies
How to reset waste ink counter in Canon MPC190 printer?
follow this steps properly as mentioned: 1) Enter SERVICE MODE.
By pressing Menu Copy Scan Copy Copy
2) Select TEST MODE.
3) Select [8] PRINTER TEST in TEST MODE.
4) Select 3. [EEPROM CLEAR].
5) Select 0. [INK COUNT].
6) Press the [Set] key.
7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
This will help.thanks.
how to resolve error 5 in printer canon pixma mp198
Please follow the below mentioned steps to Reset Canon Pixma MPC190 Printers.
1.Enter the service mode SERVICE MODE - pressing buttons Menu, Copy, Scan, Copy, Copy
2.Choose TEST MODE.
3.Select 8 PRINTER TEST TEST MODE.
4.Choose 3, EEPROM CLEAR
5.Select 0, INK COUNT
6.Press the Set button.
7.Click Stop / Reset button (return to item 3), and again press the ON / OFF
This should resolve the problem. For any further assistance please reply back.
Apr 17, 2011 | Office Equipment & Supplies
canon printer MPC600F machine gives error ##335
Reset Waste Ink
1. Turn off the printer. And disconnect the printer cable.
2. Press and hold the POWER button, turn on the printer.
3. The indicator (L.E.D.) should be green.
4. Press and release the RESUME button , the indicator (L.E.D.)
should be orange.
5. Press and hold the RESUME button again, the indicator
6. Release both buttons
Also you can try these steps if the first ones don't work for your model
By pressing Menu, Copy, Scan, Copy, Copy
Mar 06, 2011 | Canon Office Equipment & Supplies
waste ink tank full
try resetting printer as follows.
Reset Waste Ink
Jun 28, 2008 | Canon PIXMA MP780 All-In-One InkJet...
canon MP130
0.gif Re: CANON WASTE TANK RESET CODES for Canon MP130 by tac (2/15/07 1:52 PM) reply + / - CANON MP130
Discharge of the code of the error of the overcrowding of sump - "pampersa"
1. You will include printer.
2. press button MENU, then SCAN, COPY and again SCAN - they entered into the service regime.
3. select NVRAM ACCESS and further BY OK.
4. select SET Abs- m level and advance value equal to zero.
5. select SET Abs- r level (if there is) and also you will establish into zero.
6. you will turn off printer by button POWER.
Jun 27, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Printer problem
The error means waste ink absober is full, you must have been doing alot of printing,
Every Canon Pixma has a certain number of pages and/or cleaning cycles it can go through before the waste ink pads are considered to be full.
I have not been able to find the number of pages to fill the waste pad anywhere, it might be in the users manual.
An actual number of pages printed would be more helpful, how many reams of paper have you run through it?
If that machine has a self test page it might include a page count. try the follow steps:
Turn on your MP110.
After that press: Menu - Scan - Copy - Scan.
It will enter in Service Mode.
Here I don't know exactly the procedure but may be something like that for mpc190/200 that follow:
Resetting the Waste Ink Volume Counter
1) Enter SERVICE MODE.---
By pressing Menu-Copy-Scan-Copy-Copy
6) Press the [OK] key.
Vote for me if this answer is approriate
Feb 28, 2008 | Canon PIXMA MP130 All-In-One InkJet...
76 people viewed this tip
jasbo
jasbo
