Tip & How-To about Office Equipment & Supplies
How to reset Canon S9000 printer ?
the procedure is as follows:--
  1. Turn off printer
  2. Hold down Resume button and press Power button.
  3. Keep holding down Power button and let Resume button go.
  4. Press Resume button 2 times then let BOTH buttons go.
  5. Green lights will flash and then stop blinking.
  6. When green lights are solid, press the Resume button 4 times.
  7. Press the Power button and the printer should turn off, if not, press the Power button once more.
  8. Your printer should respond as normal. This will help.
thanks
canon ir 2022 - waste toner full message
The waste ink absorber is actually a pad/sponge that absorbs left over ink spray. There's really no precise way to measure the amount of ink these pads hold so when the message first appears, "waste ink absorber is almost full" it's just an estimate.
The workaround for the message is as follows:
Reset ip2000 / 3000
1. Turn off printer
Using the above procedure should clear the message and your printer should function normally afterward. Best of luck and thanks for using Fixya!
Greg
Nov 18, 2009 | Office Equipment & Supplies
waste ink absorber is full can i replace or clean this on my cannon pixma ip 3000 printer
Follow this:
1. Turn off printer
The waste ink absorber is on the back of printer.There is one cover who can open from the left side.You can replace it or clean it but the procedure is dirty and prepare yourself to get dirty.
Nov 09, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Canon PIXMA iP3000 waste ink tank showing nealry full..
Follow this procedure:
1. Turn off printer
Nov 04, 2009 | Canon Office Equipment & Supplies
286 people viewed this tip
k24674
