Tip & How-To about Office Equipment & Supplies
How to reset Canon S900 printer?
The procedure is as follows:
  1. Turn off the printer.
  2. Press and hold the RESUME button, then press and hold the POWER button.
  3. While still holding the POWER button, Release the RESUME button, then press and release the RESUME button two more times in succession.
  4. The printer mechanics will move momentarily. You are now in Service mode. Release the Power Button.
  5. Pressing the RESUME key will select a function; for example, pressing RESUME 4 times will select the clear waste ink counter function. The lamp will alternate color with each key press.
    1. Service/factory test printout, including ink sensor check
    2. EEPROM info printout
    3. EEPROM initialization
    4. Clear the waste-ink counter
    5. Printer model setting. (more selections beyond this- leave this alone)
  6. After selecting mode, press the POWER button to commit the change, and return to the top of the function selection menu. Pressing the POWER button again turns off the printer for a restart.
WASTE TANK ALMOST FULL
Try following reset procedure:
1. Turn off printer.
2. retaining button Resume/Cancel press button POWER - indicator it will catch fire by green color.
3. let go button Resume/Cancel, continuing to retain POWER.
4. press button Resume/Cancel of 2 times, retaining POWER, after which let go all buttons.
5. when indicator will be lit BY GREEN - press button Resume/Cancel of 4 times!!!
6. turn off printer by button POWER.
If reset does not work, you have to take apart the printer and empty the ink tank located at the back bottom right corner of your printer, replacing the sponge inside.
Here is an alternative procedure
1) With the printer power turned off, while pressing the Resume/Cancelbutton, press and hold the Power button. (DO NOT release the buttons.The LED lights in
green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.)
3)While holding the Power button, press the Resume/Cancel button 2 times,and then release both the Power and Resume/Cancel buttons. (Each timethe
Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.)
4) When the LED lights in green, press the Resume/Cancel button 4 times (Each time
the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.)
5)After the function (menu) is selected, press the Power button. The LEDlights in green, and the selected function is performed. (When theoperation completes,
the printer returns to the menu selection mode automatically.)
You find reset procedure here.
Here is also a reset software, http://rm1.biz/resetprinter .
2answers
Canon IP8500 Ink Absorber is Full
To reset the ink absorber is almost full:
1. Remove print head by following manufacturer procedure (available at www.canon.usa.com.
2. Turn off printer.
3. While pressing the Resume/Cancel button, press and hold the Power button. (Do not release the buttons. The Power LED lights in green to indicate that a function is selectable.)
4. While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
5. While holding the Power button, press the Resume/Cancel button 2 times. Then release both the Power and Resume/Control button.
6. When the Power LED lights in green, press the Resume/Cancel button 4 times.
7. Turn printer off. Then replace the printer head using manufacturer's procedure available on line.
8. The printer is now reset and you are ready to print.
Larry
k24674
ADMIN Andrew
ADMIN Andrew
