Tip & How-To about Office Equipment & Supplies
How to reset Canon S820 printer ?
  1. Turn off the printer.
  2. Press and hold the RESUME button, then press and hold the POWER button.
  3. While still holding the POWER button, Release the RESUME button, then press and release the RESUME button two more times in succession.
  4. The printer mechanics will move momentarily. You are now in Service mode. Release the Power Button.
  5. Pressing the RESUME key will select a function; for example, pressing RESUME 4 times will select the clear waste ink counter function. The lamp will alternate color with each key press.
    1. Service/factory test printout, including ink sensor check
    2. EEPROM info printout
    3. EEPROM initialization
    4. Clear the waste-ink counter
    5. Printer model setting. (more selections beyond this- leave this alone)
  6. After selecting mode, press the POWER button to commit the change, and return to the top of the function selection menu. Pressing the POWER button again turns off the printer for a restart.
how do i reset my pixma 1990 printer the ink receptacle is full message keeps on appearing?
To reset the printer follow these steps : 1. Turn off the printer and hold the "RESUME" button located on top of the MP220. While holding the "RESUME" button, press the "POWER" button and wait for the machine's green LED to illuminate.
2. Release the "RESUME" button while holding the "POWER" button. Press the "RESUME" button twice and release the "POWER" button.
3. Press the "RESUME" button four times followed by the "POWER" button. Turn the printer off and then on to complete the reset process.
As per your error follow the below mentioned steps :
1. Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2. While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3. While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4. When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5. Press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6. Power off then check it.
In case if the problem persists please revert back.
May 22, 2011 | Office Equipment & Supplies
emty thank
Turn off your printer. Press and hold the "Resume" button, then press and hold the "Power" button. Release the "Resume" button. Press and release the "Resume" button twice. Release the "Power" button. Your printer's print head and ink assembly will start moving and the green indicator will blink. Once the print head stops moving, press and release the "Resume" button three times. Press the "Power" button to finalize the waste ink tank reset process.
Regards,
Ron
Mar 09, 2011 | Canon i850 InkJet Photo Printer
ausbau von ink-absorber - canon pixma 4200ip
  1. With the printer plugged in and powered off, press and hold the Resume/Cancel button, then press and hold the Power button. (DO NOT release the buttons. The LED light should be green to indicate that a function is selectable.).
  2. While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.).
  3. While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.).
  4. When the LED light is green, press the Resume/Cancel button 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.).
  5. Press the Power button. The LED lights in green, and the reset is performed. (When the operation completes, the printer returns to the menu selection mode automatically.).
  6. Press the power button to exit service mode.
Note: if you accidentally press the Resume/Cancel button more than 4 times in step 4 then just press the Resume/Cancel button at least 10 times and the printer will be returned to step 4 automatically
Canon Pixma iP4200, iP5200, iP6000, iP8500 Reset Procedure
  1. Turn off the Printers.
  2. Hold Resume button click POWER.
  3. Hold button RESUME, release POWER
  4. Then press the button again twice RESUME.
  5. Release all the buttons.
  6. Indicator led in green and stay green.
  7. Click the button 4 times RESUME, if you want to make another transaction.
Feb 20, 2010 | Canon PIXMA MP150 All-In-One InkJet...
error number 1700 canon s9000 printer
knowing printer manufacturers I doubt they even have a sensor to detect that its full at all, they probably based on something crumby like print count. here are some instructions to reset the waste ink tank, the instructions vary so try them until one does the job :
Waste Ink Tank Reset
1: Power off printer
2: Hold Resume button then press and hold POWER, the beeper will sound once.
3: Hold POWER and release RESUME
4: Press RESUME twice, then release all buttons
5: When the indicator lights steady, press RESUME three or four times. The indicator should be orange.
6: Press Power to set data
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
1. power off Printer
2. Push and hold resume button and push power button
3. Hold Power button and release Resume button
4. Push Resume button twice ( 2x ), and now release resume button and power button
5. Green light will blinking and stop.
6. When green light on, push resume button 4 x
7. Push Power button and printer will off, if that isn't off, push power butto again until print off position.
Aug 20, 2008 | Office Equipment & Supplies
PROBLEM COPYING WITH MY ALL- IN- ONE
This message is inbuilt into most Canon printers, there is spongy thing in the printer which when fills up fires the message (it's mostly a counter in the printer, which can be reset more later...), per Canon this can only be dealt with in a lab but some of the more adventurous have tried cleaning it by themselves. Note that in a lab they won't clean it, it's a part that needs replacing and it might cost around $60. In most Canon printers there is a reset procedure that can reset the error and allow you to print some more before handling it again. Following are the reset procedures for some of the Printers: (not that F60 isn't listed here) Canon GENERIC "S" SERIES RESET CODE Waste Ink Counter Reset. (1) Turn off the printer. (2) Press and hold the RESUME button, then press and hold the POWER button. (3) Release the RESUME button, Next press and release the RESUME button two(2) more times in succession. Note: you are still holding the POWER button). The printer's carriage will "reset" or move momentarily. If the above was properly performed the printer will enter the "Service Mode". (4) Press the RESUME button 4 times, this will select the clear waste ink counter function. The lamp will alternate (change) color with each key press. 1. Service/Factory test printout, including ink sensor check. 2. EEPROM - Info printout. 3. EEPROM - Initialization. 4. Reset the Waste ink counter. 5. Printer model setting. (More selections beyond this point - However it is best leave them unaltered - You have been warned!) After selecting the desired mode (eg 4), press the POWER button to "set" the change, and return to the top of the function selection menu. Press the POWER button again to restart the printer. ++++++++++++++++++++++++++++++++++++++++++++++++++ Canon PIXMA iP1000 Waste Ink Counter Reset Manual for Service mode 1. Turn off the printer. And disconnect the printer cable. 2. Press and hold the POWER button, turn on the printer. 3. The indicator (L.E.D.) should be green. 4. Press and release the RESUME button , the indicator (L.E.D.) should be orange. 5. Press and release the RESUME button again, the indicator (L.E.D.) should be green. 6. Release both buttons. ++++++++++++++++++++++++++++++++++++++++++++++++++ Canon PIXMA iP1500 Waste Ink Counter Reset. Manual for Service mode 1. Turn off the printer. And disconnect the printer cable. 2. Press and hold the POWER button, turn on the printer. 3. The indicator (L.E.D.) should be green. 4. Press and release the RESUME button , the indicator (L.E.D.) should be orange. 5. Press and release the RESUME button again, the indicator (L.E.D.) should be green 6. Release both buttons ++++++++++ ++++++++++ ++++++++++ ++++++++++ ++++++++++ Canon i320, i255 Waste Ink Counter Reset. Step 1 : Manual Temporary 1. Unplug power and USB. 2. Open door and hold power button. 3. Connect power. 4. Close door, then release power button. or Step 1: Manual Temporary 1. Turn off the printer. And disconnect the printer cable. 2. Press and hold the POWER button, turn on the printer. 3. The indicator (L.E.D.) should be green. 4. Press and release the RESUME button , the indicator (L.E.D.) should be orange. 5. Press and release the RESUME button again, the indicator (L.E.D.) should be green. 6. Release both buttons. step 2 : Software for Permanant 1. Reconnect the printer cable. 2.Open General Tools software and select (USB PORT) 3 .Choose (SET DESTINATION 1) And it should be reset. Remark "After service mode Pls use software for permanent reset" ++++++++++ Canon i850, i950, S600 Start with the printer OFF 1. Hold down RESUME and then hold down POWER 2. release RESUME 3. press RESUME twice, then release POWER 4. Let green light blink until printer is done futzing Select function with RESUME press POWER to execute: presses - light color - function Number of presses - light color - function 0 presses - green - Test print (or exit service mode on i960) 1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i960) 2 presses - green - EEPROM initialize 3 presses - orange - Reset waste ink counter ++++++++++ Canon S450 Printer 1: Power off printer 2: Hold Resume button then press and hold POWER, the beeper will sound once. 3: Hold POWER and release RESUME 4: Press RESUME twice 5. Release Power button 6: When the indicator lights steady, press RESUME three(3) times. The indicator should be orange. 7: Press Power to set data ++++++++++ Canon BJC 1000 Serie 1: Remove Cartridge 2: Unplug the AC Power Cord 3: Hold down the RESUME button 4: Release RESUME after plugging in the AC Power cord. 5: Press the RESUME once within 5 seconds and release the RESUME . 6: Press and HOLD RESUME for two seconds or more and release it. 7: Press and HOLD RESUME for two seconds or more and release it. 8: Unplug AC Power Cord to set data. ++++++++++ Canon BJC-2000 BJC-2100 Serie 1: Remove the Cartridge 2: Unplug the AC Power Cord 3: Close Front access panel 3: Hold down the RESUME/RESET button and plug in the AC power cord 4: Release RESUME/RESET after plugging in the AC Power cord. 5: Press the RESUME/RESET once within 5 seconds and release the RESUME/RESET . 6: Press and HOLD RESUME/RESET for two seconds or more and release it. 7: Press and HOLD RESUME/RESET for two seconds or more and release it. 8: Unplug AC Power Cord to set data. ++++++++++ Canon BJC-210 BJC-240 BJC-250 BJC-255 BJC-265 Canon BJC-4100 BJC-4200 BJC-4300 BJC-4400 BJC-4550 BJC-4650 Unplug Power Cord Hold POWER and RESUME buttons Plug in Power Cord Release buttons Open front door of printer Hold the CARTRIDGE and RESUME buttons Press POWER Release all buttons after the beeps Press CARTRIDGE once Press RESUME ++++++++++ Canon BJC-5000 1: Power off printer 2: Press and hold RESUME then press POWER, The indicator will start blinking. 3: While the indicator is blinking , Press RESUME twice then Wait until the printer beeps to indicate service mode 5: When the indicator lights steady GREEN, press RESUME four(4)times. The indicator should be GREEN. 6: Press Power to set data Service Test Print 1: Power off printer 2: Press and hold RESUME then press POWER, The indicator will start blinking. 3: While the indicator is blinking , Press RESUME twice then Wait until the printer beeps to indicate service mode 5: When the indicator lights steady GREEN, press RESUME two(2)times. The indicator should be GREEN. 6: Press Power to Print Nozzle Print 1: Power off printer 2: Press and POWER, until the printer beeps and release. Demonstration Print 1: While the printer in ON , , Press and hold RESUME until the printer plays a melody of beeps. ++++++++++ Canon BJC-5100 Self Test Switch Printer off. Hold Power for 1 beep. Waste Counter Reset 1: Power off printer 2: Press and hold RESUME then press POWER, The indicator will start blinking. 3: While the indicator is blinking , Press RESUME twice then Wait until the printer beeps to indicate service mode 5: When the indicator lights steady GREEN, press RESUME four(4)times. The indicator should be GREEN. 6: Press Power to set data Service Test Print 1: Power off printer 2: Press and hold RESUME then press POWER, The indicator will start blinking. 3: While the indicator is blinking , Press RESUME twice then Wait until the printer beeps to indicate service mode 5: When the indicator lights steady GREEN, press RESUME two(2)times. The indicator should be GREEN. 6: Press Power to Print Nozzle Print 1: Power off printer 2: Press and POWER, until the printer beeps and release. Demonstration Print 1: While the printer in ON , , Press and hold RESUME until the printer plays a melody of beeps. ++++++++++ Canon BJC-3000 BJC-6000 BJC-6100 BJC-6200 S400 S450 F300 F600 F620 Canon BJC-7000 BJC-7100 BJC-8000 BJ-F800 i6500 1: Power off printer 2: Hold Resume button then press and hold POWER, the beeper will sound once. 3: Hold POWER and release RESUME 4: Press RESUME twice 5: When the indicator lights steady, press RESUME three(3) times. The indicator should be orange. 6: Press Power to set data ++++++++++ Canon BJC-600 BJC-600e BJC-610 BJC-620 1: Unplug Power Cord 2: Hold POWER and FF and Print Mode buttons 3: Plug in Power Cord 4: Release after the beeps ++++++++++ Canon BJC-50 BJC-55 BJC-80 BJC-85 M40 M70 1: Unplug Power Cord 2: Hold POWER and RESUME buttons 3: Plug in Power Cord 4: Release buttons after the printers starts up 5: Hold CARTRIDGE and RESUME 6: Press POWER 7: Release all buttons after the beeps 8: Press CARTRIDGE 16 times 9: Press RESUME 10: Unplug the Power cord ++++++++++ Canon BJ-30 BJC-35v BJC-70 F14 Error Reset 1: Unplug adapter 2: Hold POWER 3: Plug in ADAPTER 4: Release POWER after printer starts 5: Hold FF and MENU and press POWER 6: Release after beeps 7: Press <> Cartridge until 1A is displayed 8: Press ONLINE 9: Press POWER to shutoff printer 10: Unplug printer then re-plug printer ++++++++++ Canon BJ F900, F890, F700, F500, S900, S820, S750 and S520 Turn off the printer. Press and hold the RESUME button, then press and hold the POWER button. Release the RESUME button, then press and release the RESUME button two more times in succession. (youre still holding the POWER button during this). The printer mechanics will move momentarily. You are now in Service mode. Pressing the RESUME key will select a function; for example, pressing RESUME 4 times will select the clear waste ink counter function. The lamp will alternate color with each key press. 1. service/factory test printout, including ink sensor check 2. EEPROM info printout 3. EEPROM initialization 4. Clear the waste-ink counter 5. Printer model setting. (more selections beyond this- leave this alone) After selecting mode, press the POWER button to commit the change, and return to the top of the function selection menu. Pressing the POWER button again turns off the printer for a resta ++++++++++ Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA IP3000 above, 1. Turn off printer 2. Hold down Resume button and press Power button. 3. Keep holding down Power button and let Resume button go. 4. Press Resume button 2 times then let BOTH buttons go. 5. Green lights will flash and then stop blinking. 6. When green lights are solid, press the Resume button 4 times. 7. Press the Power button and the printer should turn off, if not, press the Power button once more. 8. Your printer should respond as normal. +++++++++ Canon S900, S820, S750, S520 Turn off the printer. Press and hold the RESUME button, then press and hold the POWER button. While still holding the POWER button, Release the RESUME button, then press and release the RESUME button two more times in succession. The printer mechanics will move momentarily. You are now in Service mode. Release the Power Button. Pressing the RESUME key will select a function; for example, pressing RESUME 4 times will select the clear waste ink counter function. The lamp will alternate color with each key press. 1. Service/factory test printout, including ink sensor check 2. EEPROM info printout 3. EEPROM initialization 4. Clear the waste-ink counter 5. Printer model setting. (more selections beyond this- leave this alone) After selecting mode, press the POWER button to commit the change, and return to the top of the function selection menu. Pressing the POWER button again turns off the printer for a restart. ++++++++++ Canon S9000 Turn off printer Hold down Resume button and press Power button. Keep holding down Power button and let Resume button go. Press Resume button 2 times then let BOTH buttons go. Green lights will flash and then stop blinking. When green lights are solid, press the Resume button 4 times. Press the Power button and the printer should turn off, if not, press the Power button once more. Your printer should respond as normal. +++++++++ Canon MPC190 Reset Waste Ink 1) Enter SERVICE MODE. By pressing Menu Copy Scan Copy Copy 2) Select TEST MODE. 3) Select [8] PRINTER TEST in TEST MODE. 4) Select 3. [EEPROM CLEAR]. 5) Select 0. [INK COUNT]. 6) Press the [Set] key. 7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
Jul 26, 2006 | Canon MultiPASS F60 All-In-One InkJet...
239 people viewed this tip
jasbo
jasbo
