Tip & How-To about Dishwashers
My dishwasher will not drain the water.
This can be one of the most common faults with dishwashers i find that i get called out for. Generally there is nothing actually wrong with the mechanics of the unit.
Most dishwashers have a certain time to drain the water away and any restrictions in the waste hose or the drain pump not turning causes the unit to fault.
1. Firstly Check and clean the filter in the base of the unit as this may be blocked.
2. Then check for any kinked hoses from the sink end to behind the unit. Sometimes extension hoses are attached to the existing hose which are not the correct type of hose and this can then sag and then cause a restriction in the hose.
3. Remove the drain hose from the U bend under the sink. Check the drain spigot where the drain hose connects into the u bend. Usually this is where food gets trapped due to the spigot hole not being drilled out large enough. This then causes a blockage. Or a foreign particle too large to go through the hole gets trapped here. If you find it blocked clear the blockage and open up the hole so there is no shoulder for blockages to start forming again.
4. Also check the non return valve under the filter and make sure the drain pump can turn freely if your model has access to this. You may just have something trapped in the drain pump. Glass or plates are a common thing to break in a dishwasher and get trapped here in the drain pump. The pump then cannot freely turn and drain the water away. Glass is also hard to see with water in the sump so use a torch.
5.Lastly see if you can hear the drain pump switching on when the unit first starts up. This is before the unit fills with water, If it doesn't then the pump may be defective.
Hope this helps.
Dishwashers Logo
Watertap message on Bosch dishwasher
Hi.
Check the water supply first. Make sure water is actually flowing through the tap. Also check the inlet hose has not been squashed on installation as this is a common fault. All hoses should be routed along the bottom of the machine in the back where clearance is provided.
Regards Sam
Nov 16, 2013 | Bosch Dishwashers
I had a 125 Cutler Breaker box put in a few years ago but I never realized that they never mark which braker was for what.I want to install a dishwasher but can not identify the breaker. Do I need to call in an electrian?
Generally you get someone to stand and watch the lights in a room while you go through and turn each breaker on and off until you find the one you're looking for. Nothing at all wrong with going through and marking them too.
It's also good to cycle breakers once a year. Flip them on and off a couple of times, if cleans the contacts and it's good for them.
lp
Jan 11, 2011 | Dishwashers
Dishwasher fills-up with water, cycles and empties, but nothing is clean. The pump might be bad as it doesn't spray the water around? What else could it be? Sean
if no water spray, indicates a fault with pump. but a common fault with pump is pump capacitor so worth checking this. capacitor is a cheap part. if pump is hot to touch or humming then this indicates capacitor fault
Jul 20, 2008 | Jenn-Air Dishwashers
dishwasher problem
there is a fault obviously, start to check for things in this order
water supply to unit
door catch
heater element
waste pump,
actually i think it could be the water supply as you said it does nothing before beeping, if the water supply is going to the machine it could be the solenoid, thats the part thats let the water in to the machine, this part is difficult to replace on most models
Oct 13, 2007 | Kenmore 24 in. 16222 Built-in Dishwasher
Candy CDI 1012 Dishwasher
providing its not under guarantee remove mains plug and remove door skin from front of door carefully, as it has to go back on, look for any broken wires just above the door hinge, there will be about 10 or 15 wires, its possible that if you have checked what you said have checked properly that one of these wires has got hot and broken (very common fault of all dishwashers aver 3 year old) replace wire with care etc, work safely,
Oct 06, 2007 | Candy 17 in. CS455 Built-in Dishwasher
2,099 people viewed this tip
Top Dishwashers Experts
Owen Barnes
