Tip & How-To about Computers & Internet
Dual Boot Xp & windows 7
First you have to create partition.You need at least two partition. One in which you intall Xp and other for win 7. WARNIG BACK UP YOUR DATA BEFORE THIS.*(You can create partion by any hard drive manager you can make a hard drive partition in control panel>administrative tool>create & manage hard drive partition)
Now install xp first in one partition. If you have pre installed then avoid this step.
Now install Win 7 in another partition.
After you restart the machine will ask to chose your os. & just select the required OS.
If any problem appears then just put win XP disk & repair it.
You cant install win Xp after windows 7.
You have to format win 7 before installing Xp.
Commiting any of trick or Tweak you need to backup your data in another HD partition
Computers & Internet Logo
filmscan 1800 i need drivers for windows 7
Hello doctordavero ,
Probably the manufacturer does not provide support for Windows 7. If you absolutely need to keep using this device , the only way under windows 7 is a workaround :
solution one:
If you have the W XP install disc , you can install a virtual version of W XP on your machine from http://www.vmware.com/products/player/ . It's easy and user's friendly . No specific knowledge required .
solution two :
If you still have the install disc , you can also partition your primary and install W XP on the new partition from http://download.cnet.com/Partition-Wizard-Home-Edition/3000-2094_4-10962200.html.
Back up your data first.
solution three:
I have Win 7 on my primary and installed Win XP on my secundary . Works like a charm .
Have a nice day ,
Best regards,
fanaudi .
Mar 29, 2011 | Microtek FilmScan 1800 Film Scanner (35...
i have ibm deskstar 20GB. Problem is that i want to connect it as an external drive through usb connector. It detects but no partition is shown in my computer. i try all jumper setting define in manual guide but it can not work. what can i do? i try it on win xp and win 7 both. i want to copy my important data from that drive. Kindly give me the solution if u have. Thanks, Waqas Nizam
In Windows 7, you can use Disk management to detect and create a partition on this drive if necessary.
Steps: 1. Connect your external drive through a USB port.
2. Click Control Panel - System and Security - Create and format hard disk partitions (under Administrative tools)
3. Your drive should appear in the table below. Select the external disk and Right Click on it. You will be presented with several options (Create partition, Format, etc.). Select whatever is applicable in your case.
4. Your external drive should now be detected by Windows 7.
Mar 23, 2011 | IBM Deskstar 40GV (DTLA-305020) 20 GB Hard...
In my lenovo z560 laptop win 7 working good but win xp not installing. it is very hard problem with me please solve this problem thank you contacat no. 9891870025(Delhi 53)
Enter Bios , Disable AHCI and Enable IDE if you want to install XP
(You may find that configuration in advance settings in BIOS)
Dec 30, 2010 | Computers & Internet
Will not run xp pro i'm stuck in 2000 mode mother board is ak77 pro 133 vt8233 will not run xp pro i've been told im pretty much sol. Is this true?
If you have a valid Win XP Pro CD and want to install the operating system you'll need to format your hard disk drive. If you have allot of data on you're hard disk drive, (In Win 2000) Suggest you create a second partition within the free space of you're hdd and install windows XP Pro. Boot you're system with the XP CD. Pay close attention to the display screens. Follow the instructions for creating a second partition.
Format the new partition. (Quick). Install windows XP on the new partition. Once completed you can copy your personal data to win XP.
If you choose to keep the win 2000 partition and you do not wish to have a dual boot system than remove/delete the root files from the 2000 partition. These files; Autoexec.bat and Boot.ini. You're new XP Boot.ini should read like this;
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect /usepmtimer
Once you're satisfied an no longer need win 2000 use windows diskmgmt.msc from the run command to delete the win 2000 partition.
Win 2000 uses a FAT16 where Win XP uses the FAT NTFS.
Cheers!
Mike
Jan 07, 2010 | Acer AOpen AK77 Pro(A) (91.89A10.104)...
192 people viewed this tip
David Payne
David Payne
