Tip & How-To about Cell Phones
HARD RESET O2 XDA Atom / O2 XDA Atom Pure / HP rw6828
To perform a hard reset, use the stylus while pressing into the reset hole, press the power on/off button at the same time. Screen will prompt you to press the Green call and Red end call button together to confirm on hard resetting the device. *Note: Hard resetting the device will cause the device to be reset back to its original factory default settings and all data will be lost.
Cell Phones Logo
I have been having problems with the alignment on my touch screen. Just reset it and have been tapping the target repeatedly but it continues to move diagonally across the screen ad nauseum. What can I do?
Remove the Screen protector from the device screen and then calibrate the screen with the stylus.
If the issue still persists, perform the Soft Reset on the device.
1. Use an unfolded paper clip, or the reset tool at the tip of your stylus.
2. Gently press and release the RESET button inside the hole on the back panel of your device .
3. After a soft reset, a logo screen appears, followed shortly by a Preferences screen asking you to set time and date.
4. All data on your device should be retained.
If the issue still persists, perform the Hard Reset on the device.
1. Press and hold the Power (on/off) button on the front panel of your device.
2. While holding Power, use an unfolded paper clip, or the reset tool at the tip of your stylus. Gently press and release the RESET button inside the hole on the back panel of your device.
3. If you see a progress bar, keep holding the Power button.
4. Next, the Palm Powered screen will appear. Release the Power button when you see it.
5. You'll see a screen that asks: Erase all data? YES = "up" button NO = any other button. Press UP on your 5-way navigator to complete the hard reset.
Your device will then take you through a series of screens to calibrate the digitizer and verify the time and date.
Note: A hard reset does not delete the current date and time. It does restore other settings to the factory default.
Sep 22, 2009 | Palm Tungsten E2 Handheld
when i try to sync i get a Fatal Alert MemoryMgr.c,Line:3751,Free handle?
To get rid of the Fatal Alert, perform the Hard Reset on the device.
Note:
A hard reset will erase everything on your device. All your data will be removed, and formats, preferences and other settings are restored to their factory default settings.
Follow the steps below to perform a hard reset on your device.
  1. Open your handheld.
  2. Press and hold the power button on the top panel of the handheld.
  3. While holding the power button, use the tip of your stylus or an unfolded paper clip (or similar object without a sharp tip) to gently press and release the reset button. (The reset button is the tiny hole labeled Reset on the back of the handheld.)
  4. Wait for the Palm Powered logo to appear; then release the power button.
  5. When prompted that you are about to erase all the data stored on your handheld, press Up to complete the hard reset.
  6. When prompted, complete the steps to align the screen.
Sep 21, 2009 | Palm Tungsten E2 Handheld
factory reset O2 Xda Atom Exec Smartphone
To perform a hard reset, use the stylus while pressing into the reset hole, press the power on/off button at the same time. Screen will prompt you to press the Green call and Red end call button together to confirm on hard resetting the device. Hard resetting the device will cause the device to be reset back to its original factory default settings and all data will be lost.
Feb 08, 2009 | O2 Xda Atom Exec Smartphone
O2 xDA Atom Exec Screen Blank After SofReset
Couple of things you can try to fix the issue, firstly try a hard reset
Try that and if it doesnt resolve the issue then we can try another solution
Aug 23, 2008 | O2 Xda Atom Exec Smartphone
134 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
