Tip & How-To about Cell Phones
HARD RESET Toshiba e310 e330 e335 e350 e355 e400 e405 e570 e740 e750 e755 e800 e805
Make sure your device is off before performing hard reset. While holding the power button press in on the reset switch with your stylus then release the power button. When a screen appears release the reset switch.
Cell Phones Logo
formatting the phone
To perform a soft reset
Use the stylus to press the RESET button found on the lower left side of your device. Your device restarts and displays the Today screen.
To perform a hard reset
  1. Press and hold the Left SOFT KEY and the Right SOFT KEY, and at the same time, use the stylus to press the RESET button at the lower left side of your device.
  2. Release the stylus, but continue pressing the two soft key buttons. Release them only when you see the following message on your device screen: “Press Send to restore manufacturer default, or press other keys to cancel.“
  3. Press on your device. Warning! Your device will be set back to factory default settings. Please ensure any additional installed programs and/or user data have been backed up before a hard reset is performed.
Aug 05, 2010 | HTC P3300 Smartphone
touch screen not working. mobile getting automatically restarted time to time.
It needs a reset.
This can be useful when your device is running slower than normal, or a program is not performing properly. A soft reset is also necessary after theinstallation of some programs. If a soft reset is performed when programs are running, unsaved work will be lost.
Use the stylus to press the RESET button found at the bottom of your device. Your device restarts and displays the Today screen.
Hard reset
You can also perform a hard reset (also known as a full reset). A hard reset should be performed only if a normal reset does not solve a system problem. After a hard reset, the device is restored to its default settings - the way it was when you first purchased it and turned it on. Any programs you installed, data you entered, and settings you customized on your device will be lost.
  1. Press and hold the TALK and END buttons, and at the same time, use the stylus to press the RESET button at the bottom of your device.
  2. Release the stylus, but continue pressing the TALK and END buttons until you see the following message on the screen:This operation will delete all your personal data, and reset all settings to manufacturer default. Press Action to restore manufacturer default, or press other keys to cancel.
  3. Release the TALK and END buttons, and then press ENTER on your device.
Aug 03, 2010 | HTC Touch P3450 Smartphone
After soft reset ( with stylus) my Touch Pro don't go up. All what it do, is to show black screen with TOUCH PRO and prom version in right bottom corner. Nothing more. Also not possible to switch it off. Please help!
Maybe a program or virus harm the system.This is how to hard reset your device
First pull out the stylus.
2. With the device turned on, press and hold the VOLUME DOWN and ENTER
buttons, then press the RESET button with the stylus tip.
3. Release the RESET button, but continue pressing the VOLUME DOWN and
ENTER buttons until you see a message on the screen
4. Release the VOLUME DOWN and ENTER buttons, then press the VOLUME UP
button to perform the hard reset, or press any other button to cancel the
reset.
In case this don't works either you should try to reinstall the firmware
Good luck
Jan 23, 2010 | Computers & Internet
i cant use my camara it says failure to set up camra device
Perform a soft reset of your phone and then check if the camera works again or not? To perform the soft reset, insert the stylus in the reset pinhole. In case you get the same error after the soft reset, then you might need to perform the hard reset, but before hard resetting the device, bakup all the information (contacts, messages, appointments, calender entries) as all the data would be lost and phone would return to factory defaults. To perform Hard Reset:
Oct 28, 2009 | HTC Touch Cell Phone (Unlocked) - Soft...
I have been having problems with the alignment on my touch screen. Just reset it and have been tapping the target repeatedly but it continues to move diagonally across the screen ad nauseum. What can I do?
Remove the Screen protector from the device screen and then calibrate the screen with the stylus.
If the issue still persists, perform the Soft Reset on the device.
1. Use an unfolded paper clip, or the reset tool at the tip of your stylus.
2. Gently press and release the RESET button inside the hole on the back panel of your device .
3. After a soft reset, a logo screen appears, followed shortly by a Preferences screen asking you to set time and date.
4. All data on your device should be retained.
If the issue still persists, perform the Hard Reset on the device.
1. Press and hold the Power (on/off) button on the front panel of your device.
2. While holding Power, use an unfolded paper clip, or the reset tool at the tip of your stylus. Gently press and release the RESET button inside the hole on the back panel of your device.
3. If you see a progress bar, keep holding the Power button.
4. Next, the Palm Powered screen will appear. Release the Power button when you see it.
5. You'll see a screen that asks: Erase all data? YES = "up" button NO = any other button. Press UP on your 5-way navigator to complete the hard reset.
Your device will then take you through a series of screens to calibrate the digitizer and verify the time and date.
Note: A hard reset does not delete the current date and time. It does restore other settings to the factory default.
Sep 22, 2009 | Palm Tungsten E2 Handheld
340 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
