Tip & How-To about Cell Phones
HARD RESET Palm Treo 700w
Make sure that the Treo isn’t connected to AC power. To perform a hard reset press and hold the Power/End button. While holding the Power/End button press in and release the reset button. When you see the confirmation screen asking you if you want to erase all data, you can release the Power/End button and press the up button on the directional pad to confirm the hard reset
Cell Phones Logo
when my boyfriend was using my treo pro he put a security password on it and now he doesn't remember the password. how can i reset it?
These steps will erase all data from the device. You may want to synchronize if possible before trying these steps.
1. Take the back panel off to expose the reset hole.
2. Press Power to turn on the screen.
3. While pressing and holding End, use the tip of the stylus or a small paper clip to press and release the Reset button.
4. Continue pressing and holding End until the Erase all data? prompt appears.
5. Press Up.
6. Wait for the progress bar on to fill up, then you can use the device again.
hard reset Palm Treo 680,755,700p,800w,...etc
There is no reset button on this models like other Palm devices, so performing a hard reset can be tricky.
How to hard reset your this types ?
1. Disconnect the Treo from a charger or USB cable.
2. Remove the battery cover and take out the battery.
3. Press and hold Power/End while you insert the battery.
4. When the screen lights up with the logo appears, release Power/End.
5. Press Up when the Erase all data? prompt appears.
6. Press Up to confirm the hard reset.
7. Go through the steps of setting up the device again by picking a language and calibrating the stylus.
Now your Treo is hard reset.
Sep 06, 2012 | Palm Treo Pro Smartphone
Is there a way I can revert my Palm Treo 650 back to original factory settings
Factory Reset for Treo 700p and 680 smartphones
If you've set a password on your smartphone, any hard reset will automatically become a Factory Reset. With this method, you'll enter a password and then perform a hard reset.
On your smartphone, launch the Security application.
2.If the Password box says "Unassigned," tap the box and create a password for your smartphone.
3.Once the password has been set, disconnect your smartphone from the AC charger and take off the battery cover. Do not remove the battery yet.
4.Hold down Power/End .
5.While holding down Power/End , remove the battery. Then insert it again.
6.While still holding Power/End , the screen will show the Palm logo and a progress bar. Then the circular Palm Powered logo will appear. Release the power button when you see the Palm Powered logo.
Keep holding the Power button during this screen. When you see this screen, you can release the Power button.
7.A message will appear warning that you are about to erase all the data stored on your smartphone. Press UP.
8.If you performed this reset correctly, the screen will go blank after several minutes, and you will not be able to turn on your device. The charging LED will not light up. (any other activity - such as the Palm OS logo and then the Applications launcher appearing - means the reset was performed incorrectly; try again) 9.Your device will appear "dead." To wake up your smartphone, perform a soft reset.
if u like plz comment
Mar 11, 2010 | Palm Treo 650 Handheld
palm treo reset
You want to perform what is called a "Hard Reset"
It's pretty easy. You hold the power button while you push the reset button on the back. The treo will ask you if you want to erase all the data.
  • Unscrew the tip from your stylus
  • Locate the "RESET" hole on the back of your Treo 600
  • Press and hold the power button on the top of your Treo and then press the reset button with the stylus pin
  • Remove the pin from the reset hole FIRST, hold both for a few seconds, and then release the power button.
  • The screen will say "erase all data?", tap the up arrow to answer yes
  • Here is a explaining what I just said above:
    http://mytreo.net/archives/2004/05/hard-reset-the-treo-600.html
    Sep 22, 2007 | Palm Treo 600 Handheld
    167 people viewed this tip
    Top Cell Phones Experts
    Computer Repairing
    Computer Repairing
    William Alequin
    Are you a Cell Phone Expert? Answer questions, earn points and help others
