Tip & How-To about Televison & Video
Play Blu-ray movie with HDTV DVD Combo ? Burning Blu-ray to DVD
HDTV DVD Combo features a built-in slot-loading DVD player, which provides an optimum way to save space. With the slim profile, it’s really an amazing experience to watch favorites TV shows and DVD movies on this device in your bedroom. But if your TV only has a standard DVD player but not the Blu-ray disc player, what is your solution to play Blu-ray movies on it? I'd like to know your ideas. I believe my way is somewhat helpful, just convert BD to a DVD format, and then burn it to a blank DVD for playback on the TV/DVD Combo, so share it here, and also be glad to hearing from you guys.
The software I used is as below:
- (http://www.pavtube.com/blu-ray-ripper/ ) Pavtube Blu-Ray Ripper
- (http://www.videohelp.com/tools/ReJig) ReJig (freeware)
- (http://fileforum.betanews.com/detail/ImgBurn/1128426215/) ImgBurn(freeware)
HOW-TO:
Part 1:
Firstly, use Pavtube Blu-Ray Ripper to remove copy protections of Blu-ray movies, and meanwhile convert it to the DVD vob format.
1. Run Pavtube Blu-Ray Ripper and click "DVD Rom", "DVD Folder" or "IFO/ISO" to load Blu-ray movies. Generally speaking, the file with the longest duration time would be the main movie, if you just need back up the main movie, tick off this one only.
Each file will be checked by default after imported, right click on any one of the files, and then there will be a popup window to let you uncheck all, just do it, and afterwards to tick off the checkbox before the file you need converted.
2. Click on the drop-down menus after "Subtitle" and "Audio" respectively to select your required languages and sound effect.
3. Select VOB as output format and specify destination folder
Click on the pull down list of "Format" to select VOB as output format and click on the folder icon at the opposite side of "Output" to specify destination folder.
4. Customize output settings
The popup window will allow you to adjust audio and video parameters including codec, bit rate, aspect ratio, frame rate, sample rate, and audio channels to optimize the output file quality.
5. Click on "Convert" button to start BD ripping
Once finished, you can find out the output files via clicking on "Open" button with ease.
Part 2:
Then use ReJig to do DVD authoring.
It's pretty simple with ReJig. Press "File Mode"; add your vob files and Demux.
When it's finished, close that box and then select DVD Author. Add the video and audio files you've just created, and choose output destination folder, and click Create.
After DVD authoring is completed, you can open the destination folder to see that the output files are AUDIO-TS and VIDEO-TS folders, which are the correct structure for DVD burning.
Part 3:
Use ImgBurn to burn DVD
We have got VIDEO-TS folder in part two, so the DVD burning process with ImgBurn is pretty simple. Here give you two links to check the detailed steps:
(http://forum.imgburn.com/index.php?showtopic=4632 ) How to write DVD Video files directly to single layer media using ImgBurn (DVD±R/RW)
(http://forum.imgburn.com/index.php?showtopic=4643) How to write a DVD Video double layer disc using ImgBurn (Verbatim DVD+R DL) – just check the contents that start from adding VIDEO-TS folder of this guide.
The end! Hope this helps.
Televison & Video Logo
what is Sansui 24" LED TV/DVD Combo
LED TV/DVD technology is one of the latest innovations from Sansui. The SLEDVD249 features a super slim LED display that can be placed virtually anywhere in your home.The SLEDVD249 combines the clarity of our LED TV series with the entertainment experience of an integrated slot-loading DVD player. LED technology features a stunning picture quality, a wide range of colors, and an incredible range of brightness. LED technology also features a significantly lower use of electrical energy, which means you'll save money on that costly electric bill.
Jul 07, 2014 | Sansui 22" 720p LED HDTV DVD Combo
Give me some idea about online provider.
Its a good idea that you want to use provider.Its the best way.You just give them your paper they will proofread it for you.But you need to pay some money for it.In online have many provider.I am suggesting you a provider which is good about proofread.Try it http://www.smartcustomwriting.com/ Hope it can help you best.Good luck.
Dec 10, 2013 | Toshiba BDX2500 Wi-Fi Ready Blu-ray...
Do they make a DVD/VHS Combo with a built in decoder that will connect to my Analog TV using only a coaxil cable?
99.99% of the combo units that have a tuner inside have been phased out.
You do need an external tuner to get cable through to the combo unit. The only combo units that I have seen that has a tuner in it already and hooks up to the coax is one that is a vhs/dvd RECORDER and not just a vhs/dvd PLAYER. You pay extra for the built in tuner and also for the dvd recording features.
Dec 27, 2009 | Televison & Video
Toshiba 32'' Model 32HLV66 DVD/TV Combo - DVD won't play
you must do a optical head cleaning on the unit, could be the optical lens was dirty thats why it can't read any disc inserted.
you Lens cleaner for CD & CD-ROM player
With Voice instruction (English), Music and Automatic stop
Scientifically designed, easy to use and keeps your player's sound at optimum condition
Nov 23, 2008 | Toshiba MD13N3 13 in. TV/DVD Combo
Ii own a minteck lcd dvd combo
I have a Mintek lcd/dvd combo which when turned on , comes on with picture and sound but the picture goes off in about one second. I removed the back and can see that the back lighting is going off. I measured some voltages at a terminal strip that i believe provider the back lighting for the set. The results seemed to be normal to me. Can you suggest where I should look further.
Nov 24, 2007 | Philips 42PF7220A 42 in. Plasma Television
140 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
