Tip & How-To about Cell Phones
Htc hard reset
1.Press and hold the TALK and END buttons, and at the same time, use the stylus to press the RESET button at the bottom of your device.2.Release the stylus, but continue pressing the TALK and END buttons until you see the following message on the screen:This operation will delete all your personal data, and reset all settings to manufacturer default. Press Action to restore manufacturer default, or press other keys to cancel.
3.Release the TALK and END buttons, and then press ENTER on your device
Cell Phones Logo
HTC TOUCH HANG WHEN I BOOT
Dear mate try to reset your phone hard i.e"Hard Reset",
Release the TALK and END buttons, and then press ENTER on your device.
Jan 27, 2013 | HTC Touch P3450 Smartphone
all our contact phone number seem to be on the sim card and on the phone hpw do I delete them from the phone
There are two ways, by clearing the Device Storage or you can try a hard reset, here are the steps:
To clear storage:
1. Tap Start > Settings > System Tab > Clear Storage
2. Enter "1234" now tap yes
To Hard reset:
1. Press and hold the TALK and END buttons, and at the same time, use the stylus to press the RESET button at the bottom of the device
2. Release the stylus and continue pressing the TALK and END buttons and you will see a message on the screen that says "This operation will delete all you personal data...." now press ACTION to proceed
3. Release the TALK and END buttons and then press ENTER on your device
GoodLuck!
eBookBoy
Jul 10, 2011 | HTC Touch P3450 Smartphone
my htc touch 2 doesn t start anymore... it does ask me to press send button to reset it but it doesn t go
  1. Press and hold the TALK and END buttons, and at the same time, use the stylus to press the RESET button at the bottom of your device.
  2. Release the stylus, but continue pressing the TALK and END buttons until you see the following message on the screen:This operation will delete all your personal data, and reset all settings to manufacturer default. Press Action to restore manufacturer default, or press other keys to cancel.
  3. Release the TALK and END buttons, and then press ENTER on your device.
Mar 11, 2010 | HTC Touch P3450 Smartphone
Turns OFF CONTINUOUSLY
do hard reset the problem will be solved here is the solution
Mar 08, 2010 | HTC Touch P3452 Smartphone
i cant use my camara it says failure to set up camra device
Perform a soft reset of your phone and then check if the camera works again or not? To perform the soft reset, insert the stylus in the reset pinhole. In case you get the same error after the soft reset, then you might need to perform the hard reset, but before hard resetting the device, bakup all the information (contacts, messages, appointments, calender entries) as all the data would be lost and phone would return to factory defaults. To perform Hard Reset:
Oct 28, 2009 | HTC Touch Cell Phone (Unlocked) - Soft...
154 people viewed this tip
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
