Tip & How-To about Cell Phones
Apple iPhone hard reset If iPhone won?t turn on, or if the display freezes or doesn?t respond ?Press and hold the Home button below the screen for at least six seconds, until the application you were using quits. ?If that doesn?t work, turn iPhone off and turn it on again. Press and hold the Sleep/ Wake button on top of iPhone for a few seconds until a red slider appears, and then drag the slider. Then press and hold the Sleep/Wake button until the Apple logo appears. ?If that doesn?t work, reset iPhone. Press and hold both the Sleep/Wake button and the Home button for at least ten seconds, until the Apple logo appears. Updating and Restoring iPhone Software You can use iTunes to update or restore iPhone software. You should always update iPhone to use the latest software. You can also restore the software, which returns iPhone to its original state. If you restore, all data is erased from iPhone, including songs, videos, contacts, photos, calendar information, and any other data. All iPhone settings are restored to their original state. 1.Make sure you have an Internet connection and have installed the latest version of iTunes from www.apple.com/itunes. 2.Connect iPhone to your computer. 3.In iTunes, select iPhone in the Source pane and click the Summary tab. 4.Click ?Check for Update.? iTunes tells you if there?s a newer version of the iPhone software available. 5.Click Update to install the latest version of the software. Or click Restore to restore iPhone to its original settings and erase all data on iPhone. Follow the onscreen instructions to complete the restore process. Resetting iPhone Settings Reset all settings Choose General > Reset and tap Reset All Settings. ?All your preferences and settings are reset. Information, such as your contacts and calendars, and media, such as your songs and videos, are not deleted. Erase all content and settings Choose General > Reset and tap ?Erase All Content and Settings.? ?All your information and media are deleted. You must sync iPhone with your computer to restore contacts, songs, videos, and other information and media. Reset the keyboard dictionary Choose General > Reset and tap Reset Keyboard Dictionary. ?You add words to the keyboard dictionary by rejecting words iPhone suggests as you type. Tap a word to reject the correction and add the word to the keyboard dictionary. Resetting the keyboard dictionary erases all words you?ve added. Reset Network Settings Choose General > Reset and tap Reset Network Settings.
Cell Phones Logo
i think the display screen on my iphone 3g went out. how do i check?
Reset the phone:
To reset iPhone, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds. During this time, a red "power off" slider may appear and the screen may go black, but do not release Sleep/Wake and Home buttons until the Apple logo appears.
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a 10 seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
Dec 12, 2010 | Apple iPhone 3G
I cant get my phone to turn on everytime I hold the reset button the apple logo appears for 5 secs then the screen turns black.
Download the latest iTunes to your computer and reset the iPhone. Then re-sync it.
Reset
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
Nov 30, 2010 | Apple iPhone 3G
i unlocked my i phone. but now its not responding to itunes
Reset
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
Sep 11, 2009 | Apple iPhone Smartphone
my phone screen won't come on, it will ring if I call it, but the screen stays dark so I can't answer it... I have tried the small button on the top and the round button below the screen.
Try these resets:
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jul 27, 2009 | Apple iPhone 3G
Unlocked Iphone reset
Holding down the Power and Home buttons to do a hard reset will not harm your phone. You will lose the call you're on though. I am having the same issue where I'm on a call and after I'm done have a hard time getting the display to turn back on. Usually hitting Home a million times works, but so will a hard reset. Failing that, call up Apple to see if they can look at it/replace it.
Jan 08, 2009 | Apple iPhone Smartphone
192 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
